Using the Batch Control Detail Panel
The batch control detail panel displays further information about the selected batch control.
In the batch control detail panel, you can navigate using the following options:
Click on the program name to view its source in the Java docs viewer.
If a To Do type references this batch control as its creation or routing process, click on the To Do type to view its detail in the To Do type viewer.
