Using the Batch Control Viewer List Panel
The list panel displays a list of batch controls. The list panel can display the list of batch controls sorted by their code or sorted by their description. Click the appropriate
button on the toolbar to switch between sorting by the code and description.
In the list panel, you can click the batch control to display information about the batch control in the detail panel.
Note:Not All Batch Controls Included. Note that the insertion and key generation programs for conversion (CIPV*) are not included.
Parent topic
