Using the Java Docs Viewer List Panel
The list panel displays a tree of Java packages where each package may be expanded to list the Java interfaces classes it includes.
In the list panel, you can navigate using the following options:
• Click the right arrow icon to expand a Java package to view the Java interfaces and classes it includes.
• Click the down arrow icon to collapse the list for a Java package. Optionally, collapse all lists by using the Collapse button.
• Click the Java interface or class name to display information about it in the detail panel.
The list details panel designates the interfaces and the classes as follows:
• A green dot indicates Java interfaces.
• A blue key indicates Java classes.
If you hover the cursor over the icon, the tool tip indicates whether it's an interface or a class.
Parent topic
