Option | Description | Option Name |
Default Email Sender | This is the default Message Sender used for sending e-mails when no explicit Message Sender is specified. | defaultEmailSender |
Default User | The default user is used by the system to access your product when no other user is explicitly specified. | defaultUser |
Email Attachment File Location | This is the default location of e-mail attachment files. If not specified, the e-mail service provided with the product assumes a full path is provided with each attachment file. | emailAttachmentFileLocation |
Email XSL File Location | This is the default location of e-mail XSL files. If not specified, the e-mail service provided with the product assumes a full path is provided to an XSL file as part of an e-mail request. | emailXSLFileLocation |
Messages Language | The default language to use for the messages. | language |
Outbound Message Schema Location | Enter the full path of the virtual directory where valid W3C schemas are stored if your implementation wants to validate outbound message schemas. For example: http:/localhost/cisxai/schemas. | xaiOuboundSchemaLoc |
Schema Validation Flag | xaiSchemaValidationCheck | |
To Do Type for Inbound JMS Message Errors | To Do type for inbound JMS message errors. The inbound message processor uses this To Do type when creating To Do entries for inbound JMS messages that cannot be successfully processed. The system provides the To Do type F1-INJMS that may be used here. | toDoTypeforInboundJMSMessageErrors |
To Do Type for Outbound Message Errors | To Do type for outbound message errors. The outbound message receiver uses this To Do type when creating To Do entries for outbound messages that cannot be successfully processed. The system provides the To Do type F1-OUTMS that may be used here. | outboundErrorTodo |
Option |
Automatically Attempt Resend to Unavailable Sender (Y/N) |
Default Response Character Encoding |
JDBC Connection Pool Max size |
Maximum Errors for a Sender |
Messages JDBC Connection |
MPL Administrator Port |
MPL HTTP Server Authentication Method |
MPL HTTP Server Password |
MPL HTTP Server User |
MPL Log File |
MPL Trace File |
MPL Trace Type |
Privileged Users |
Records MPL Receiver Will Process At a Time |
Schema Directory |
Send SOAP Fault as HTTP 500 |
Sender Retry Seconds |
System Error JDBC Connection |
System Error Max Retry |
System Error Retry Interval |
Thread Pool Initial Size |
Thread Pool Max Size |
Thread Pool Non Activity Time |
WSDL Service Address Location |
XAI Authentication Password |
XAI Authentication User |
XAI Trace File |
XAI Trace Type |
XSD Compliance |
XSL Directory |
