Defining Characteristic Mapping
This portal maps characteristic extensions to user defined fields provided for each characteristic table that is associated with an analytics dimension table.
These mappings may be directly maintained on the operational
Analytics Dimension portal. Refer to
Understanding Operational Analytics for more information.
If your system is integrated with the Oracle Utilities Analytics product refer to
Understanding Analytics Integration for more information about ETL based characteristic mapping.
You can access the portal from the > > You are brought to a query portal with options for searching for a specific mapping record. Once a record has been selected you are brought to the this portal to review the information for the selected record.
The Characteristic Mapping zone on the portal's Main tab page provides information about the mapping record.
Only Adhoc and Pre-defined characteristic types are supported.
Parent topic
