Calendar and Time Dimensions
This portal is used to view generated calendar and time dimension records.
Refer to
Understanding Operational Analytics for an overview of operational analytic functionality.
Navigate using > > .
• Calendar Dimension. This zone lists most recent calendar dimension records. You may filter the list to review records generated up to a specific date.
• Calendar Date. This zone provides information about a selected calendar date.
• Time Dimension. This zone lists all time dimension records.
Parent topic
