| Category | Supported in Expression | Description |
| Data types | Number | |
| String | ||
| Boolean | ||
| List | ||
| Literals | Numbers | |
| Strings surrounded with either single quote or double quote. Note: 'Escaping' special characters is not currently supported. | ||
| Boolean values: true and false. | ||
| Operations | + | Plus |
| — | Minus | |
| / | Division | |
| * | Multiplication | |
| ^ or ** | Power | |
| % | Modulus | |
| Logical operations | = | Equal |
| > | Greater than | |
| >= | Greater than or equal to | |
| < | Less than | |
| <= | Less than or equal to | |
| != or <> | Not equal to |
| Function | Parameter | Results | Comments |
| size( ) | List element | Number of elements in the list. | |
| isEmpty( ) | List element | Returns true if the list is empty. | |
| sum( ) | List element of type 'number' | Returns the sum of the numbers in the list. | |
| avg( ) | List element of type 'number' | Returns the average of the numbers in the list. | |
| One or more numbers separated by commas | Returns the average of the number arguments. | ||
| max( ) | List element | Returns the largest value in the list. | |
| One or more comparable elements. | Returns the largest value of the number arguments. | ||
| min( ) | List element | Returns the smallest value in the list. | |
| One or more comparable elements. | Returns the smallest value of the number arguments. | ||
| abs( ) | Number | Returns the absolute value. | |
| ceiling( ) | Number | Rounds the number to the ceiling. | |
| exp10( ) | Number | Raises 10 to the number power. | |
| acos( ) | Number | Returns the arc cosine of the number in radians. | The result will lose precision, as it uses the system's double float based functions. |
| asin( ) | Number | Returns the arc sine of the number radians. | The result will lose precision, as it uses the system's double float based functions. |
| atan( ) | Number | Returns the arc tangent of the number radians. | The result will lose precision, as it uses the system's double float based functions. |
| cos( ) | Radian | Returns the cosine of the radian angle input. | The result will lose precision, as it uses the system's double float based functions. |
| exp( ) | Number | Raises e to the number power. | The result will lose precision, as it uses the system's double float based functions. |
| log10( ) | Number | Takes the log, base 10, of the number. | The result will lose precision, as it uses the system's double float based functions. |
| log( ) | Number | Takes the natural log (base e) of the number. | The result will lose precision, as it uses the system's double float based functions. |
| sin( ) | Radian | Returns the sine of the radian angle input. | The result will lose precision, as it uses the system's double float based functions. |
| sqrt( ) | Number | Returns the square root of the number. | The result will lose precision, as it uses the system's double float based functions. |
| tan( ) | Radian | Returns the tangent of the radian angle input. | The result will lose precision, as it uses the system's double float based functions. |
| floor( ) | Number | Rounds the number to the floor. | |
| round( ) | Number | Assumes a scale of 0. The default rounding mode of “round half up” is applied. | |
| Number, Scale | The default rounding mode of “round half up” is applied. | ||
| Number, Scale, Mode | The mode must be set to one of the following: • “ROUND_CEILING” • “ROUND_DOWN” • “ROUND_FLOOR” • “ROUND_HALF_DOWN” • “ROUND_HALF_UP” • “ROUND_HALF_EVEN” • “ROUND_UP” • “ROUND_UNNECESSARY” | ||
| negate( ) | Number | Returns the negative value of the number. | Only available in data explorer. |
| Function | Description | Examples |
| any [ ] | This function returns the value true if any of the entries in list satisfies the expression. | The following returns true if any entry in the Balance list is greater than 0. any [ i in list/Balance | i > 0 ] |
| all [ ] | This function returns the value true if all of the entries in the list satisfy the expression. | The following returns true if all phone numbers are populated. all [ i in list/phoneNumber | i != ' ' ] |
| collect [ ] | This function returns a new list of elements from the referenced list where the value of each entry of the new list is the result of the expression applied to each original value. | The following returns a new list with the tax rate applied to each amount. collect [ i in list/amount | i * taxRate ] |
| select [ ] | This function returns a list of all the values of the original list that satisfy the Boolean expression. | The following returns a new list with only the amounts that are negative numbers. select [ i in list/amount | i < 0 ] |
| reject [ ] | This function returns a list of all the values of the original list that do not satisfy the Boolean expression. | The following returns a new list with only the amounts that are not negative numbers. reject [ i in list/amount | i < 0 ] |
