UI Map - Main
Use this page to define basic information about a user interface (UI) Map. Open this page using Admin > System > UI Map
Use the UI Map Query portal to search for an existing UI Map. Once a map is selected, you are brought to the maintenance portal to view and maintain the selected record.
Description of Page
Enter a unique Map name. Owner indicates if the UI map is owned by the base package or by your implementation (Customer Modification).
CAUTION:
Important! If you introduce a new UI map, carefully consider its naming convention. Refer to System Data Naming Convention for more information.
Use UI Map Type to indicate whether the map is a Complete XHTML Document, Complete HTML Document, XHTML Fragment or an HTML Fragment. The default value is Complete XHTML Document.
Enter a Description. Use the Detailed Description to describe how this map is used in detail.
Click on the View Schema to view the UI map's expanded schema definition. Doing this opens the schema viewer window.
Use the Test UI Map hyperlink to render your HTML in a test window.
The Test UI Map hyperlink also exercises the proprietary functionality that binds an XML element with an HTML element so you can get immediate feedback on your HTML syntax.
