Work Lists
The work list buttons can appear in a zone’s column heading,
Clicking the icon results in populating the dashboard
Work List Zone with the entire column. The user may use the Work List zone to easily process entries one at a time without returning back to the source query zone. The work list stays populated until the user overlays the work list by clicking a different column's icon.
When a user clicks on a work list entry in the dashboard, the system behaves as if the user clicked on the hyperlink in the zone. In addition, the system adds a check mark next to the item showing that the user has "worked on" or visited the entry.
The Work List zone is populated only upon user request.
Parent topic
