Parameter | Description |
id | The identification code for the meter. |
macID | A MAC address that must be unique within the system. |
utility | An informational string. |
serviceType | One of the valid ServiceType values (see schema). "Electric" is the only option at this time. |
isCommissioned | Whether or not the meter is in a commissioned state. |
loadActionCode | One of the possible LoadActionCode values used in Connect and Disconnect (see schema). |
outageEventType | One of the possible OutageEventType values used in Device Status Check (see schema). |
executionStatus | One of the possible ExecutionStates (see schema). These values control how the meter will respond to commands. |
groupName | The name linking multiple meters together into a set. |
jobExecutionStatus | One of the possible Job Execution Status values (see schema). This attribute determines how requested jobs perform. |
updateIfExisting | Whether or not to update the meter with the provided values if it already exists in the index. |
Comment | An informational string describing the purpose of the meter. |
Channels | A listing of unit of measures supported by this meter. |
uomCode | A code describing the unit of measure for the channel. |
uomName | A short string containing the name of the unit of measure. |
decimals | The number of digits to the right of the decimal that should be generated when reading the meter. |
description | A longer description of the unit of measure. |
id | The ID for the meter to be removed |
id | The ID for the meter to be removed. |
id | The ID for the meter to be read |
value | A random number representing the scalar reading. |
