Defining Questions
You use the Question portal to display and maintain questions.
You can access the portal by selecting Admin, then Asset Management, then Question. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
Question: This zone provides information about the question.
Service History List: This zone displays a list of service history types that reference the question.
