Upgrades to the Oracle Utilities Application Framework Database
This section describes the database upgrade process for the Oracle Utilities Application Framework database since the last release. It highlights changes made to the administrative tables and how those changes should be applied to the data in order for your current database to work with the Oracle Utilities Application Framework application, and to preserve the business logic implemented in the previous version of the application. The changes that do not require data upgrade are not described in this document. The tasks that need to be performed after running the upgrade scripts are included.
Note: Upgrade scripts do not automatically enable the newly added functionality by default. Please refer to the release notes for more information.
The section provides information on upgrading the Oracle Utilities Application Framework Database including:
• Upgrading from Oracle Utilities Application Framework V4.3.0.2.0 to V4.3.0.4.0
• Upgrading from Oracle Utilities Application Framework V4.4.0.2.0 to V4.4.0.3.0
• Upgrading from Oracle Utilities Application Framework V4.4.0.3.0 to V4.5.0.0.0
• Upgrading from Oracle Utilities Application Framework V4.5.0.0.0 to V4.5.0.1.1
