Relationship Between 2.5.0.1.1 and Prior Versions
V2.5.0.1.1 supports the following upgrade paths:
• If you are installing Oracle Utilities Market Settlements Management for the first time, you must install V2.5.0.1.1, available on the Oracle Software Delivery Cloud.
• If you have Oracle Utilities Market Settlements Management V2.4.0.0 or V2.5.0.0 installed you can upgrade to V2.5.0.1.1 directly.
