Oracle WebLogic Server 14.1.2.x (64-bit)
Oracle WebLogic software can be downloaded from the Oracle website. This application server will run as a 64-bit application.
• Download and install 64-bit Java (as documented above) before installing WebLogic.
• Download and install WebLogic Server 14.1.2.x.
Note: With Oracle Utilities Application Framework V4.5.0.2.0 a WebLogic native installation is required. Refer to the Oracle WebLogic Configuration Guide for Oracle Utilities Application Framework (Doc ID 2413918.1) document on My Oracle Support.
