Fixes and Patches
This release includes fixes and patches released in all patch roll-ups delivered for release 2.5.0.1.1, plus the following:
Bug/Patch Number
Description
38569861
FW 4.5.0.2.0 - Upgrade Hibernate in OUAF from v4 to v5
38091236
To Do Entries can be Worked On even if the user has no 'Change' access for the To Do Entry application service
38207227
Upgrade 4.5.0.2.0 with ojdbc17 jar for 23ai
38258435
In zone maintenance - display, html in the column config is applied. It should show the raw value of config.
38313860
Support navigation across rows in "edit in place" grids using arrow keys
38368219
Pages not loading properly when there are references to purged To Do entries
38368223
Overdue monitoring batchs are not being activated in system
38368227
To Do Summary dashboard / sidebar zone is unnecessarily counting Open To Do entries, causing slowness
38368229
Europe/Dublin time zone not reflected in local time
38368236
Error when viewing data via a CM extension that has been archived by ILM and where the record is a composite key
38368244
Fields not populated by scripts executed during application launch
38405514
Upgrade of Commons-Beanutils Library
38410890
Upgrade of JSON-SMART Library
38412025
Upgrade of DOMPurify Library
38421525
Upgrade of commons-fileupload library
38433154
Upgrade of Nimbus-jose-jwt Library
38434582
Some log tab displays an error after a To Do Purge job completion
38492603
Environment with Java 17 and Weblogic 14 fails when an IWS with an empty Transaction Type mapping is submitted
38518718
Upgrade of Velocity-engine-core and Commons-lang Library
38524160
OCTOBER 2025 CPU ROLLUP BUG
38546006
Blank Screen shown after Payment Arrangement Process Flow cancellation
38558538
IWS Deployment Issues with JDBC version 23.9 libraries
38632964
submitBatchRest.sh for comma parameter value
38651863
Algorithm Parameter validation not working consistently
38658801
Security Issue
38729167
Upgrade of Bouncy Castle Library
38669600
MDM startup failure after upgrade of hibernate from v4 to v5 - MDM 2.5.0.2.0 version
38645410
Timeline zone displays all device events when no current device is installed for the selected service point
38454995
Upgrade scripts affected by Groovy 3.0.7 Upgrade to 3.0.17 [FW 4.5.0.2.0/X1 2.9.0.2.0]
37878277
MV90 SGG Native Upload job hangs/fails when there is a blank device id in one of the records
37956225
The Route Management zone is displaying duplicate SPs
37973512
Cross Installed Meter - Swap Meter throws, Device cannot be installed at the Service Point as a device is already installed for the install Date/Time, exception when multiple install events occurred for single service point
37708243
Unable to Delete Service Point
37734704
Error thrown on initial bills with non-interval scalar start date/time only for 30 minute dvc cfg POST 37195438 Gas Day Enhancement
38073044
Active Usage subscription For Request Orchestrator should be identified by SQL Zone
37828837
UT errors when rate change occurs on the first or last day of the UT period
38198074
Base Zone Scalar Readings are trimming reading value after two decimals
37681500
"Service Point Type is Missing" Error when de-activating Service Point
38078545
On Device retire, the option to select or add a Status Reason is not available
38235921
MDM - Users are able to run scripts, even with read only permissions
38272737
Viewing IMDs is causing page freeze when attempting to load IMD
38095947
Usage Transaction Correction Processor Activity Is Not Created for Scalar Read
38331540
Increase Data Type of column PERIOD_SEQ_NUM from Number(3) to Number(5) affecting Usage Transaction Tables
38340911
Editing a Multi-Item Entry in Service Point Deletes All Other Records
