Upgrading the Staging Database
This section describes how to upgrade the Staging schema on a Conversion environment in V2.4.0.0.0 and higher.
Restore the Staging schema before upgrading/updating an existing environment:
Note: Execute this step if you are upgrading/updating an already-setup-for-Conversion environment.
1. Extract ConvSetup.tar from the ..\MDM\Conversion\ folder.
tar xvf ConvSetup.tar
2. On the Staging schema, execute the following script:
script restore_ctltbls.sql
Note: This script would have been generated during the conversion setup in previous versions starting V2.4.0.0.0 and is also a part of ConvSetup.tar.
