Installation Overview
Refer to the Supported Database Platforms section for the hardware and software versions required to install Oracle Utilities Market Settlements Management database components.
The following types of installation is available:
• Initial Install: Database with no demo data
• Upgrade Install: A database upgrade to version 25.4 from versions 24.3.0.0.0 and 2.5.0.1.1
• Demo Install: Database populated with demo data
The database installation requires a supported version of the Java Development Kit Version 17 and Oracle 19c 32-bit client installed on the Windows 64-bit or 32-bit desktop where the install package is staged and run.
Important! Starting V25.4, please note that Oracle Utilities Meter Data Management supports ADB. For more information, see Oracle Utilities Meter Data Management Support on ADB chapter in the Oracle Utilities Meter Data Management Database Administrator Guide. The documentation is available on the Oracle Utilities Market Settlements Management page on Oracle Help Center.
Note that the Oracle Utilities Meter Data Management database component is a cumulative package comprising of data used by Oracle Utilities Market Settlements Management.
The database installation requires a supported version of the Java Development Kit to be installed on the Windows desktop where the install package is staged and run from. See the Supported Platform section in the Oracle Utilities Market Settlements Management Installation Guide included in this release for the required version of Java. The documentation is available on the Oracle Utilities Market Settlements Management page on Oracle Help Center.
For an Initial Install or Demo Install you will create an empty database on the Unix or Windows server and then populate the database with data. For a database Upgrade Install you will upgrade your current Oracle Utilities Market Settlements Management database.
Review the Storage.xml file prior to an Initial Install or Upgrade Install. Information in this file is used by ORADBI while installing and upgrading the Oracle Utilities Market Settlements Management database objects.
For optimum storage allocation, database administrators should create multiple tablespaces with extents sized to store different types of tables/indexes. They can then edit this file before each upgrade and install process, to spread tables and indexes across these tablespaces. Tables and indexes can be created in parallel by editing degree of parallelism.
Tablespace, storage options, securefile options, Advanced Compression, and parallel information are used only for new objects. Therefore, for initial installs, information for each object should be reviewed. For upgrades, only tablespace information for objects added in the current release needs to be reviewed. Be careful while editing the Storage.xml file. Make sure that tablespace names being used exist in the database. Do not change the basic format of this file.
Note: Prior to the installation of the database schema for the product, make sure that the Database Management System software is installed according to your site standards and the installation guide provided by the database vendor.
