Table_Name |
D1_ACTIVITY_TYPE_DIV |
D1_ACTIVITY_TYPE_FLD_TASK_TYPE |
D1_CONTACT_COMM |
D1_CONTACT_COMM_CHAR |
D1_CONTACT_COMM_K |
D1_CONTACT_COMM_LOG |
D1_CONTACT_COMM_LOG_PARM |
D1_CONTACT_COMM_REL_OBJ |
D1_DVC_ENTITY_GRP |
D1_DVC_EQPMNT |
D1_DVC_TYPE_VALID_DVC_CHAR |
D1_DYN_OPT_QTY |
D1_DYN_OPT_QUESTION |
D1_DYN_OPT_RATE |
D1_DYN_OPT_RULE |
D1_DYN_OPT_SPECIFICATION |
D1_DYN_OPT_TYPE_QTY_TYPE |
D1_DYN_OPT_TYPE_REL |
D1_DYN_OPT_USG_GRP |
D1_ENTITY_GRP |
D1_ENTITY_GRP_CHAR |
D1_ENTITY_GRP_CRIT |
D1_ENTITY_GRP_CRIT_VAL |
D1_ENTITY_GRP_L |
D1_EVT_PARTICIPATION |
D1_EVT_PARTICIPATION_CHAR |
D1_EVT_PARTICIPATION_K |
D1_EVT_PARTICIPATION_LOG |
D1_EVT_PARTICIPATION_LOG_PARM |
D1_FACILITY_SP |
D1_IMD_CTRL_STAGE |
D1_IMD_CTRL_STAGE_K |
D1_IMD_TYPE |
D1_IMD_TYPE_ALG |
D1_IMD_TYPE_L |
D1_MSRMT_AUDIT |
D1_RULE |
D1_RULE_CHAR |
D1_RULE_L |
D1_RULE_PARM |
D1_SPR_PROG |
D1_SP_ENTITY_GRP |
D1_SP_TYPE_DISCONNECT_LOCATION |
D1_SP_TYPE_DIV |
D1_SP_TYPE_FIELD_TASK_TYPE |
D1_US_TYPE_VALID_US_CHAR |
View_Name |
D1_ACT_DVC_SP_VW |
D1_BI_DYN_AGG_VW |
D1_MC_TYPE_PER_EST_EVAL_VW |
D2_MEASR_QTY_AGR_MV |
D2_MEASR_QTY_MV |
D2_QUALITY_CNT_AGR_MV |
D2_QUALITY_CNT_MV |
D2_TIMELINESS_CNT_MV |
D2_TIMELINESS_QTY_MV |
D2_TIMELINES_CNT_AGR_MV |
D2_TIMELINES_QTY_AGR_MV |
Table_Name | Index_Name |
D1_ACTIVITY_TYPE_DIV | D1C636P0 |
D1_ACTIVITY_TYPE_FLD_TASK_TYPE | D1C631P0 |
D1_CONTACT | D1M180S0 |
D1_CONTACT_COMM | D1T653P0 |
D1_CONTACT_COMM | D1T653S1 |
D1_CONTACT_COMM_CHAR | D1T655P0 |
D1_CONTACT_COMM_CHAR | D1T655S1 |
D1_CONTACT_COMM_K | D1T654P0 |
D1_CONTACT_COMM_LOG | D1T656P0 |
D1_CONTACT_COMM_LOG_PARM | D1T657P0 |
D1_CONTACT_COMM_REL_OBJ | D1T658P0 |
D1_DVC_ENTITY_GRP | D1M674P0 |
D1_DVC_ENTITY_GRP | D1M674S0 |
D1_DVC_EQPMNT | D1M629P0 |
D1_DVC_EQPMNT | D1M629S0 |
D1_DVC_TYPE_VALID_DVC_CHAR | D1C634P0 |
D1_DVC_TYPE_VALID_DVC_CHAR | D1C634S1 |
D1_DYN_OPT_EVENT | D1T230S1 |
D1_DYN_OPT_EVENT | D1T230S2 |
D1_DYN_OPT_EVENT | D1T230S3 |
D1_DYN_OPT_QTY | D1M659P0 |
D1_DYN_OPT_QUESTION | D1M646P0 |
D1_DYN_OPT_RATE | D1M645P0 |
D1_DYN_OPT_RULE | D1M647P0 |
D1_DYN_OPT_SPECIFICATION | D1M638P0 |
D1_DYN_OPT_TYPE_QTY_TYPE | D1C660P0 |
D1_DYN_OPT_TYPE_REL | D1M648P0 |
D1_DYN_OPT_USG_GRP | D1M652P0 |
D1_ENTITY_GRP | D1C675P0 |
D1_ENTITY_GRP_CHAR | D1C670P0 |
D1_ENTITY_GRP_CRIT | D1C671P0 |
D1_ENTITY_GRP_CRIT_VAL | D1C672P0 |
D1_ENTITY_GRP_L | D1C669P0 |
D1_EVT_PARTICIPATION | D1T639P0 |
D1_EVT_PARTICIPATION | D1T639S2 |
D1_EVT_PARTICIPATION | D1T639S3 |
D1_EVT_PARTICIPATION | D1T652S1 |
D1_EVT_PARTICIPATION_CHAR | D1T641P0 |
D1_EVT_PARTICIPATION_CHAR | D1T641S1 |
D1_EVT_PARTICIPATION_K | D1T640P0 |
D1_EVT_PARTICIPATION_LOG | D1T642P0 |
D1_EVT_PARTICIPATION_LOG_PARM | D1T643P0 |
D1_FACILITY_SP | D1T633P0 |
D1_IMD_CTRL_STAGE | D1T661P0 |
D1_IMD_CTRL_STAGE | D1T661S0 |
D1_IMD_CTRL_STAGE | D1T661S1 |
D1_IMD_CTRL_STAGE_K | D1T663P0 |
D1_IMD_TYPE | D1C664P0 |
D1_IMD_TYPE_ALG | D1C666P0 |
D1_IMD_TYPE_L | D1C665P0 |
D1_MSRMT_AUDIT | D1T662P0 |
D1_RULE | D1C649P0 |
D1_RULE_CHAR | D1C651P0 |
D1_RULE_L | D1C650P0 |
D1_RULE_PARM | D1C667P0 |
D1_SPR_PROG | D1C668P0 |
D1_SP_ENTITY_GRP | D1M673P0 |
D1_SP_ENTITY_GRP | D1M673S0 |
D1_SP_REL | D1M317S1 |
D1_SP_TYPE_DISCONNECT_LOCATION | D1C637P0 |
D1_SP_TYPE_DIV | D1C635P0 |
D1_SP_TYPE_FIELD_TASK_TYPE | D1M630P0 |
D1_USAGE_EXCP | D1T443S1 |
D1_US_QTY | D1M576P0 |
D1_US_TYPE_VALID_US_CHAR | D1C644P0 |
D1_US_TYPE_VALID_US_CHAR | D1C644S1 |
Table_Name | Column_Name | Data_Type | Data_Length |
CI_ACC_GRP_ROLE | ACCESS_GRP_CD | CHAR | 48 |
CI_ACC_GRP_ROLE | ROLE_ID | CHAR | 40 |
CI_ACC_GRP_ROLE | TD_TYPE_CD | CHAR | 32 |
CI_ACC_GRP_ROLE | VERSION | NUMBER | 22 |
CI_ALG_PARM | ALG_PARM_VAL | VARCHAR2 | 32767 |
CI_BATCH_CTRL | BASE_BATCH_FLG | CHAR | 16 |
CI_BATCH_CTRL | BATCH_TEMPLATE_XFLG | VARCHAR2 | 1016 |
CI_BATCH_CTRL_OPT | BATCH_CD | CHAR | 32 |
CI_BATCH_CTRL_OPT | BATCH_CTRL_OPT_FLG | CHAR | 16 |
CI_BATCH_CTRL_OPT | BATCH_CTRL_OPT_VAL | VARCHAR2 | 1016 |
CI_BATCH_CTRL_OPT | OWNER_FLG | CHAR | 16 |
CI_BATCH_CTRL_OPT | SEQ_NUM | NUMBER | 22 |
CI_BATCH_CTRL_OPT | VERSION | NUMBER | 22 |
CI_BATCH_INST | END_DTTM | DATE | 7 |
CI_BATCH_INST | FILE_DETAILS | CLOB | 4000 |
CI_BATCH_INST | START_DTTM | DATE | 7 |
CI_BATCH_JOB | SUBMIT_METH_FLG | CHAR | 16 |
CI_BATCH_JOB | SUBMIT_USER_ID | CHAR | 32 |
CI_BATCH_RUN | LOG_FILE_NAME | VARCHAR2 | 1016 |
CI_CHAR_TYPE | FLD_NAME | CHAR | 120 |
CI_CNV_DUP_KEY | CX_ID | CHAR | 120 |
CI_CNV_KEY_TMP | CI_ID | CHAR | 120 |
CI_CNV_KEY_TMP | CX_ID | CHAR | 120 |
CI_CNV_KEY_TMP | INIT_ID | VARCHAR2 | 120 |
CI_CURRENCY_CD | EXT_CURRENCY_CD | CHAR | 144 |
CI_MD_FLD_ADDTL | FLD_NAME | CHAR | 120 |
CI_MD_FLD_ADDTL | OWNER_FLG | CHAR | 16 |
CI_MD_FLD_ADDTL | PII_CLASS_FLG | CHAR | 16 |
CI_MD_FLD_ADDTL | VERSION | NUMBER | 22 |
CI_MD_FLD_L | CONTEXT_LABEL1 | VARCHAR2 | 240 |
CI_MD_FLD_L | CONTEXT_LABEL2 | VARCHAR2 | 240 |
CI_MD_FLD_L | CONTEXT_LABEL3 | VARCHAR2 | 240 |
CI_MD_FLD_L | CONTEXT_LABEL_TYPE1 | CHAR | 16 |
CI_MD_FLD_L | CONTEXT_LABEL_TYPE2 | CHAR | 16 |
CI_MD_FLD_L | CONTEXT_LABEL_TYPE3 | CHAR | 16 |
CI_MD_FLD_L | OVRD_CONTEXT_LABEL1 | VARCHAR2 | 240 |
CI_MD_FLD_L | OVRD_CONTEXT_LABEL2 | VARCHAR2 | 240 |
CI_MD_FLD_L | OVRD_CONTEXT_LABEL3 | VARCHAR2 | 240 |
CI_MD_IDX | IDX_CD | VARCHAR2 | 512 |
CI_MD_IDX | OWNER_FLG | CHAR | 16 |
CI_MD_IDX | TBL_NAME | CHAR | 120 |
CI_MD_IDX | UNIQUE_SW | CHAR | 4 |
CI_MD_IDX | VERSION | NUMBER | 22 |
CI_MD_IDX_FLD | FLD_NAME | CHAR | 120 |
CI_MD_IDX_FLD | IDX_CD | VARCHAR2 | 512 |
CI_MD_IDX_FLD | OWNER_FLG | CHAR | 16 |
CI_MD_IDX_FLD | SEQ_NUM | NUMBER | 22 |
CI_MD_IDX_FLD | VERSION | NUMBER | 22 |
CI_MD_TBL | KEY_PREFIX_FLD_NAME | CHAR | 120 |
CI_MD_TBL_ADDTL | OWNER_FLG | CHAR | 16 |
CI_MD_TBL_ADDTL | TBL_GEN_STATUS_FLG | CHAR | 16 |
CI_MD_TBL_ADDTL | TBL_NAME | CHAR | 120 |
CI_MD_TBL_ADDTL | VERSION | NUMBER | 22 |
CI_NT_XID | OWNER_FLG | CHAR | 16 |
CI_NT_XID_L | OWNER_FLG | CHAR | 16 |
CI_PORTAL | PORTAL_ROLE_FLG | CHAR | 16 |
CI_PORTAL_ZONE | ZONE_HEIGHT_FLG | CHAR | 16 |
CI_PORTAL_ZONE | ZONE_LAYOUT | CHAR | 16 |
CI_PORTAL_ZONE | ZONE_MAX_HEIGHT_PCT | NUMBER | 22 |
CI_PORTAL_ZONE | ZONE_ROWS | CHAR | 16 |
CI_PORTAL_ZONE | ZONE_WIDTH_FLG | CHAR | 16 |
CI_TD_ENTRY | RTE_BATCH_CD | CHAR | 32 |
CI_TD_ENTRY | RTE_BATCH_NBR | NUMBER | 22 |
CI_TD_ENTRY | TD_SUB_STATUS_FLG | CHAR | 16 |
CI_TD_ENTRY_OPEN_VW | DKSQ1 | NUMBER | 22 |
CI_TD_ENTRY_OPEN_VW | DKSQ2 | NUMBER | 22 |
CI_TD_ENTRY_OPEN_VW | DKSQ3 | NUMBER | 22 |
CI_TD_ENTRY_OPEN_VW | DKSQ4 | NUMBER | 22 |
CI_TD_ENTRY_OPEN_VW | DKSQ5 | NUMBER | 22 |
CI_TD_ENTRY_OPEN_VW | SKSQ1 | NUMBER | 22 |
CI_TD_ENTRY_OPEN_VW | SKSQ2 | NUMBER | 22 |
CI_TD_ENTRY_OPEN_VW | SKSQ3 | NUMBER | 22 |
CI_TD_ENTRY_OPEN_VW | SKSQ4 | NUMBER | 22 |
CI_TD_ENTRY_OPEN_VW | SKSQ5 | NUMBER | 22 |
CI_TD_ENTRY_OPEN_VW | TD_SUB_STATUS_FLG | CHAR | 16 |
CI_TD_LOG | TD_LOG_STATUS_FLG | CHAR | 16 |
CI_XAI_SENDER | OWNER_FLG | CHAR | 16 |
CI_XAI_SENDER_L | OWNER_FLG | CHAR | 16 |
CI_XAI_SNDR_CTX | OWNER_FLG | CHAR | 16 |
CI_ZONE | ZONE_ROLE_FLG | CHAR | 16 |
CI_ZONE_PRM | ZONE_PARM_VAL | VARCHAR2 | 32767 |
D1_ACTIVITY | RESCHEDULE_REASON | VARCHAR2 | 1016 |
D1_ACTIVITY_ADJ_TYPE | D1_SP_TYPE_CD | VARCHAR2 | 120 |
D1_ACTIVITY_TYPE | SP_DVC_COND_SRC_FLG | CHAR | 16 |
D1_ACTIVITY_TYPE | THROTTLE_OPT_FLG | CHAR | 16 |
D1_ACTIVITY_TYPE_DIV | ACTIVITY_TYPE_CD | VARCHAR2 | 120 |
D1_ACTIVITY_TYPE_DIV | DIVISION_CD | VARCHAR2 | 120 |
D1_ACTIVITY_TYPE_DIV | VERSION | NUMBER | 22 |
D1_ACTIVITY_TYPE_FLD_TASK_TYPE | ACTIVITY_BO_TO_CREATE | CHAR | 120 |
D1_ACTIVITY_TYPE_FLD_TASK_TYPE | ACTIVITY_TYPE_CD | VARCHAR2 | 120 |
D1_ACTIVITY_TYPE_FLD_TASK_TYPE | ALTERNATE_FIELD_TASK_TYPE | VARCHAR2 | 1016 |
D1_ACTIVITY_TYPE_FLD_TASK_TYPE | BO_DATA_AREA | CLOB | 4000 |
D1_ACTIVITY_TYPE_FLD_TASK_TYPE | D1_SP_TYPE_CD | VARCHAR2 | 120 |
D1_ACTIVITY_TYPE_FLD_TASK_TYPE | DEVICE_INSTALLED_AT_SP_SW | CHAR | 4 |
D1_ACTIVITY_TYPE_FLD_TASK_TYPE | DISCONN_LOC_FLG | CHAR | 16 |
D1_ACTIVITY_TYPE_FLD_TASK_TYPE | EXEC_OVRD_ALG_SW | CHAR | 4 |
D1_ACTIVITY_TYPE_FLD_TASK_TYPE | FIELD_TASK_TYPE | VARCHAR2 | 1016 |
D1_ACTIVITY_TYPE_FLD_TASK_TYPE | INSTALL_EVENT_STATUS_OVERRIDE | VARCHAR2 | 1016 |
D1_ACTIVITY_TYPE_FLD_TASK_TYPE | SEQNO | NUMBER | 22 |
D1_ACTIVITY_TYPE_FLD_TASK_TYPE | SP_CATEGORY_FLG | CHAR | 16 |
D1_ACTIVITY_TYPE_FLD_TASK_TYPE | SP_CONNECTED_SW | CHAR | 4 |
D1_ACTIVITY_TYPE_FLD_TASK_TYPE | SP_DVC_COND_FLG | CHAR | 16 |
D1_ACTIVITY_TYPE_FLD_TASK_TYPE | VERSION | NUMBER | 22 |
D1_ACT_DVC_SP_VW | ACCESS_GRP_CD | CHAR | 48 |
D1_ACT_DVC_SP_VW | D1_ACTIVITY_ID | CHAR | 56 |
D1_ACT_DVC_SP_VW | D1_PK_VALUE | VARCHAR2 | 1016 |
D1_ACT_DVC_SP_VW | MAINT_OBJ_CD | CHAR | 48 |
D1_AGG_GROUP_RUN_MC_SET | SCAN_BATCH_CD | CHAR | 32 |
D1_AGG_GROUP_RUN_MC_SET | SCAN_BATCH_NBR | NUMBER | 22 |
D1_AGG_GROUP_RUN_MC_SET | SCAN_BATCH_RERUN_NBR | NUMBER | 22 |
D1_BI_DYN_AGG_VW | AGG_ATTR1 | VARCHAR2 | 16000 |
D1_BI_DYN_AGG_VW | AGG_ATTR10 | VARCHAR2 | 16000 |
D1_BI_DYN_AGG_VW | AGG_ATTR11 | VARCHAR2 | 16000 |
D1_BI_DYN_AGG_VW | AGG_ATTR12 | VARCHAR2 | 16000 |
D1_BI_DYN_AGG_VW | AGG_ATTR13 | VARCHAR2 | 16000 |
D1_BI_DYN_AGG_VW | AGG_ATTR14 | VARCHAR2 | 16000 |
D1_BI_DYN_AGG_VW | AGG_ATTR15 | VARCHAR2 | 16000 |
D1_BI_DYN_AGG_VW | AGG_ATTR16 | VARCHAR2 | 16000 |
D1_BI_DYN_AGG_VW | AGG_ATTR17 | VARCHAR2 | 16000 |
D1_BI_DYN_AGG_VW | AGG_ATTR18 | VARCHAR2 | 16000 |
D1_BI_DYN_AGG_VW | AGG_ATTR19 | VARCHAR2 | 16000 |
D1_BI_DYN_AGG_VW | AGG_ATTR2 | VARCHAR2 | 16000 |
D1_BI_DYN_AGG_VW | AGG_ATTR20 | VARCHAR2 | 16000 |
D1_BI_DYN_AGG_VW | AGG_ATTR3 | VARCHAR2 | 16000 |
D1_BI_DYN_AGG_VW | AGG_ATTR4 | VARCHAR2 | 16000 |
D1_BI_DYN_AGG_VW | AGG_ATTR5 | VARCHAR2 | 16000 |
D1_BI_DYN_AGG_VW | AGG_ATTR6 | VARCHAR2 | 16000 |
D1_BI_DYN_AGG_VW | AGG_ATTR7 | VARCHAR2 | 16000 |
D1_BI_DYN_AGG_VW | AGG_ATTR8 | VARCHAR2 | 16000 |
D1_BI_DYN_AGG_VW | AGG_ATTR9 | VARCHAR2 | 16000 |
D1_BI_DYN_AGG_VW | AGG_MEASR_COMP_ID | CHAR | 48 |
D1_BI_DYN_AGG_VW | AGG_VAL | NUMBER | 22 |
D1_BI_DYN_AGG_VW | AGG_VAL1 | NUMBER | 22 |
D1_BI_DYN_AGG_VW | AGG_VAL10 | NUMBER | 22 |
D1_BI_DYN_AGG_VW | AGG_VAL2 | NUMBER | 22 |
D1_BI_DYN_AGG_VW | AGG_VAL3 | NUMBER | 22 |
D1_BI_DYN_AGG_VW | AGG_VAL4 | NUMBER | 22 |
D1_BI_DYN_AGG_VW | AGG_VAL5 | NUMBER | 22 |
D1_BI_DYN_AGG_VW | AGG_VAL6 | NUMBER | 22 |
D1_BI_DYN_AGG_VW | AGG_VAL7 | NUMBER | 22 |
D1_BI_DYN_AGG_VW | AGG_VAL8 | NUMBER | 22 |
D1_BI_DYN_AGG_VW | AGG_VAL9 | NUMBER | 22 |
D1_BI_DYN_AGG_VW | MEASR_COMP_SET_CD | VARCHAR2 | 120 |
D1_BI_DYN_AGG_VW | MSRMT_DTTM | DATE | 7 |
D1_CONS_EXT_TYPE | INTERVAL_SCALAR_FLG | CHAR | 16 |
D1_CONTACT | ADDRESS1 | VARCHAR2 | 1016 |
D1_CONTACT | ADDRESS1_UPPER | VARCHAR2 | 1016 |
D1_CONTACT | ADDRESS2 | VARCHAR2 | 1016 |
D1_CONTACT | ADDRESS3 | VARCHAR2 | 1016 |
D1_CONTACT | ADDRESS4 | VARCHAR2 | 1016 |
D1_CONTACT | CITY | VARCHAR2 | 360 |
D1_CONTACT | CITY_UPPER | VARCHAR2 | 360 |
D1_CONTACT | COUNTRY | CHAR | 12 |
D1_CONTACT | COUNTY | VARCHAR2 | 360 |
D1_CONTACT | GEO_CODE | CHAR | 44 |
D1_CONTACT | HOUSE_TYPE | CHAR | 8 |
D1_CONTACT | IN_CITY_LIMIT | CHAR | 4 |
D1_CONTACT | NUM1 | CHAR | 24 |
D1_CONTACT | NUM2 | CHAR | 16 |
D1_CONTACT | POSTAL | CHAR | 48 |
D1_CONTACT | STATE | CHAR | 24 |
D1_CONTACT_COMM | BO_DATA_AREA | CLOB | 4000 |
D1_CONTACT_COMM | BO_STATUS_CD | CHAR | 48 |
D1_CONTACT_COMM | BUS_OBJ_CD | CHAR | 120 |
D1_CONTACT_COMM | CONTACT_COMM_CAT | VARCHAR2 | 1016 |
D1_CONTACT_COMM | CONTACT_COMM_CHANNEL | VARCHAR2 | 1016 |
D1_CONTACT_COMM | CONTACT_COMM_CLASS | VARCHAR2 | 1016 |
D1_CONTACT_COMM | CONTACT_COMM_ID | CHAR | 56 |
D1_CONTACT_COMM | CONTACT_COMM_NOTES | VARCHAR2 | 16000 |
D1_CONTACT_COMM | CONTACT_ID | CHAR | 48 |
D1_CONTACT_COMM | CRE_DTTM | DATE | 7 |
D1_CONTACT_COMM | D1_SP_ID | CHAR | 48 |
D1_CONTACT_COMM | ILM_ARCH_SW | CHAR | 4 |
D1_CONTACT_COMM | ILM_DT | DATE | 7 |
D1_CONTACT_COMM | UPD_DTTM | DATE | 7 |
D1_CONTACT_COMM | US_ID | CHAR | 48 |
D1_CONTACT_COMM | VERSION | NUMBER | 22 |
D1_CONTACT_COMM_CHAR | ADHOC_CHAR_VAL | VARCHAR2 | 1016 |
D1_CONTACT_COMM_CHAR | CHAR_TYPE_CD | CHAR | 32 |
D1_CONTACT_COMM_CHAR | CHAR_VAL | CHAR | 64 |
D1_CONTACT_COMM_CHAR | CHAR_VAL_FK1 | VARCHAR2 | 200 |
D1_CONTACT_COMM_CHAR | CHAR_VAL_FK2 | VARCHAR2 | 200 |
D1_CONTACT_COMM_CHAR | CHAR_VAL_FK3 | VARCHAR2 | 200 |
D1_CONTACT_COMM_CHAR | CHAR_VAL_FK4 | VARCHAR2 | 200 |
D1_CONTACT_COMM_CHAR | CHAR_VAL_FK5 | VARCHAR2 | 200 |
D1_CONTACT_COMM_CHAR | CONTACT_COMM_ID | CHAR | 56 |
D1_CONTACT_COMM_CHAR | SEQ_NUM | NUMBER | 22 |
D1_CONTACT_COMM_CHAR | SRCH_CHAR_VAL | VARCHAR2 | 200 |
D1_CONTACT_COMM_CHAR | VERSION | NUMBER | 22 |
D1_CONTACT_COMM_K | CONTACT_COMM_ID | CHAR | 56 |
D1_CONTACT_COMM_K | ENV_ID | NUMBER | 22 |
D1_CONTACT_COMM_LOG | ADHOC_CHAR_VAL | VARCHAR2 | 1016 |
D1_CONTACT_COMM_LOG | BO_STATUS_CD | CHAR | 48 |
D1_CONTACT_COMM_LOG | BO_STATUS_REASON_CD | VARCHAR2 | 120 |
D1_CONTACT_COMM_LOG | CHAR_TYPE_CD | CHAR | 32 |
D1_CONTACT_COMM_LOG | CHAR_VAL | CHAR | 64 |
D1_CONTACT_COMM_LOG | CHAR_VAL_FK1 | VARCHAR2 | 200 |
D1_CONTACT_COMM_LOG | CHAR_VAL_FK2 | VARCHAR2 | 200 |
D1_CONTACT_COMM_LOG | CHAR_VAL_FK3 | VARCHAR2 | 200 |
D1_CONTACT_COMM_LOG | CHAR_VAL_FK4 | VARCHAR2 | 200 |
D1_CONTACT_COMM_LOG | CHAR_VAL_FK5 | VARCHAR2 | 200 |
D1_CONTACT_COMM_LOG | CONTACT_COMM_ID | CHAR | 56 |
D1_CONTACT_COMM_LOG | DESCRLONG | VARCHAR2 | 16000 |
D1_CONTACT_COMM_LOG | LOG_DTTM | DATE | 7 |
D1_CONTACT_COMM_LOG | LOG_ENTRY_TYPE_FLG | CHAR | 16 |
D1_CONTACT_COMM_LOG | MESSAGE_CAT_NBR | NUMBER | 22 |
D1_CONTACT_COMM_LOG | MESSAGE_NBR | NUMBER | 22 |
D1_CONTACT_COMM_LOG | SEQNO | NUMBER | 22 |
D1_CONTACT_COMM_LOG | USER_ID | CHAR | 32 |
D1_CONTACT_COMM_LOG | VERSION | NUMBER | 22 |
D1_CONTACT_COMM_LOG_PARM | CONTACT_COMM_ID | CHAR | 56 |
D1_CONTACT_COMM_LOG_PARM | MSG_PARM_TYP_FLG | CHAR | 16 |
D1_CONTACT_COMM_LOG_PARM | MSG_PARM_VAL | VARCHAR2 | 8000 |
D1_CONTACT_COMM_LOG_PARM | PARM_SEQ | NUMBER | 22 |
D1_CONTACT_COMM_LOG_PARM | SEQNO | NUMBER | 22 |
D1_CONTACT_COMM_LOG_PARM | VERSION | NUMBER | 22 |
D1_CONTACT_COMM_REL_OBJ | CONTACT_COMM_ID | CHAR | 56 |
D1_CONTACT_COMM_REL_OBJ | MAINT_OBJ_CD | CHAR | 48 |
D1_CONTACT_COMM_REL_OBJ | PK_VALUE1 | VARCHAR2 | 1016 |
D1_CONTACT_COMM_REL_OBJ | PK_VALUE2 | VARCHAR2 | 1016 |
D1_CONTACT_COMM_REL_OBJ | PK_VALUE3 | VARCHAR2 | 1016 |
D1_CONTACT_COMM_REL_OBJ | PK_VALUE4 | VARCHAR2 | 1016 |
D1_CONTACT_COMM_REL_OBJ | PK_VALUE5 | VARCHAR2 | 1016 |
D1_CONTACT_COMM_REL_OBJ | SEQNO | NUMBER | 22 |
D1_CONTACT_COMM_REL_OBJ | VERSION | NUMBER | 22 |
D1_CONTACT_EMAIL | EMAIL_VALUE | VARCHAR2 | 1016 |
D1_CONTACT_TYPE | CONTACT_USE_FLG | CHAR | 16 |
D1_DVC | ACCESS_GRP_CD | CHAR | 48 |
D1_DVC | DER_AGG_SPR_CD | VARCHAR2 | 120 |
D1_DVC_ENTITY_GRP | BO_DATA_AREA | CLOB | 4000 |
D1_DVC_ENTITY_GRP | D1_DEVICE_ID | CHAR | 48 |
D1_DVC_ENTITY_GRP | EFF_DTTM | DATE | 7 |
D1_DVC_ENTITY_GRP | ENTITY_GRP_CD | VARCHAR2 | 120 |
D1_DVC_ENTITY_GRP | EXPIRATION_DTTM | DATE | 7 |
D1_DVC_ENTITY_GRP | VERSION | NUMBER | 22 |
D1_DVC_EQPMNT | BO_DATA_AREA | CLOB | 4000 |
D1_DVC_EQPMNT | COMMENTS | VARCHAR2 | 1016 |
D1_DVC_EQPMNT | D1_DEVICE_ID | CHAR | 48 |
D1_DVC_EQPMNT | D1_EQPMNT_ID | CHAR | 48 |
D1_DVC_EQPMNT | D1_INSTALL_DTTM | DATE | 7 |
D1_DVC_EQPMNT | D1_REMOVAL_DTTM | DATE | 7 |
D1_DVC_EQPMNT | EQPMNT_CNT | NUMBER | 22 |
D1_DVC_EQPMNT | MEASR_COMP_ID | CHAR | 48 |
D1_DVC_EQPMNT | VERSION | NUMBER | 22 |
D1_DVC_SP_VW | DIVISION_CD | VARCHAR2 | 120 |
D1_DVC_TYPE | ATTACHED_TO_FLG | CHAR | 16 |
D1_DVC_TYPE_VALID_DVC_CHAR | ADHOC_CHAR_VAL | VARCHAR2 | 1016 |
D1_DVC_TYPE_VALID_DVC_CHAR | CHAR_TYPE_CD | CHAR | 32 |
D1_DVC_TYPE_VALID_DVC_CHAR | CHAR_VAL | CHAR | 64 |
D1_DVC_TYPE_VALID_DVC_CHAR | CHAR_VAL_FK1 | VARCHAR2 | 200 |
D1_DVC_TYPE_VALID_DVC_CHAR | CHAR_VAL_FK2 | VARCHAR2 | 200 |
D1_DVC_TYPE_VALID_DVC_CHAR | CHAR_VAL_FK3 | VARCHAR2 | 200 |
D1_DVC_TYPE_VALID_DVC_CHAR | CHAR_VAL_FK4 | VARCHAR2 | 200 |
D1_DVC_TYPE_VALID_DVC_CHAR | CHAR_VAL_FK5 | VARCHAR2 | 200 |
D1_DVC_TYPE_VALID_DVC_CHAR | DEFAULT_SW | CHAR | 4 |
D1_DVC_TYPE_VALID_DVC_CHAR | DEVICE_TYPE_CD | VARCHAR2 | 120 |
D1_DVC_TYPE_VALID_DVC_CHAR | REQUIRED_SW | CHAR | 4 |
D1_DVC_TYPE_VALID_DVC_CHAR | SORT_SEQ | NUMBER | 22 |
D1_DVC_TYPE_VALID_DVC_CHAR | VERSION | NUMBER | 22 |
D1_DYN_OPT | D1_APPROVAL_PROF_CD | VARCHAR2 | 120 |
D1_DYN_OPT | D1_INITIATIVE_CD | VARCHAR2 | 120 |
D1_DYN_OPT | DIVISION_CD | VARCHAR2 | 120 |
D1_DYN_OPT | END_DT | DATE | 7 |
D1_DYN_OPT | EXT_DYN_OPT_ID_VALUE | VARCHAR2 | 480 |
D1_DYN_OPT | START_DT | DATE | 7 |
D1_DYN_OPT | SUSPEND_FLG | CHAR | 16 |
D1_DYN_OPT_EVENT | DYN_OPT_EVENT_CAT_FLG | CHAR | 16 |
D1_DYN_OPT_EVENT | DYN_OPT_EXT_EVT_ID_VALUE | VARCHAR2 | 480 |
D1_DYN_OPT_EVENT | DYN_OPT_EXT_ID_VALUE | VARCHAR2 | 480 |
D1_DYN_OPT_QTY | DYN_OPT_ID | CHAR | 48 |
D1_DYN_OPT_QTY | DYN_OPT_QTY | NUMBER | 22 |
D1_DYN_OPT_QTY | DYN_OPT_QTY_TYPE | VARCHAR2 | 1016 |
D1_DYN_OPT_QTY | END_DTTM | DATE | 7 |
D1_DYN_OPT_QTY | START_DTTM | DATE | 7 |
D1_DYN_OPT_QTY | VERSION | NUMBER | 22 |
D1_DYN_OPT_QUESTION | D1_ANSWER_CD | VARCHAR2 | 120 |
D1_DYN_OPT_QUESTION | D1_QUESTION_CD | VARCHAR2 | 120 |
D1_DYN_OPT_QUESTION | DYN_OPT_ID | CHAR | 48 |
D1_DYN_OPT_QUESTION | QUESTION_CATEGORY | VARCHAR2 | 1016 |
D1_DYN_OPT_QUESTION | RESPONSE_REQ_FLG | CHAR | 16 |
D1_DYN_OPT_QUESTION | SEQNO | NUMBER | 22 |
D1_DYN_OPT_QUESTION | VERSION | NUMBER | 22 |
D1_DYN_OPT_RATE | D1_RS_CD | VARCHAR2 | 1016 |
D1_DYN_OPT_RATE | DYN_OPT_ID | CHAR | 48 |
D1_DYN_OPT_RATE | SEQNO | NUMBER | 22 |
D1_DYN_OPT_RATE | VERSION | NUMBER | 22 |
D1_DYN_OPT_RULE | DYN_OPT_EVENT_CAT_FLG | CHAR | 16 |
D1_DYN_OPT_RULE | DYN_OPT_ID | CHAR | 48 |
D1_DYN_OPT_RULE | DYN_OPT_RULE_CD | VARCHAR2 | 120 |
D1_DYN_OPT_RULE | SEQNO | NUMBER | 22 |
D1_DYN_OPT_RULE | VERSION | NUMBER | 22 |
D1_DYN_OPT_SPECIFICATION | D1_SPECIFICATION_CD | VARCHAR2 | 120 |
D1_DYN_OPT_SPECIFICATION | DYN_OPT_ID | CHAR | 48 |
D1_DYN_OPT_SPECIFICATION | SEQNO | NUMBER | 22 |
D1_DYN_OPT_SPECIFICATION | VERSION | NUMBER | 22 |
D1_DYN_OPT_TYPE | D1_APPROVAL_PROF_CD | VARCHAR2 | 120 |
D1_DYN_OPT_TYPE | DEVICE_REQD_FLG | CHAR | 16 |
D1_DYN_OPT_TYPE | DYN_OPT_CATEGORY | VARCHAR2 | 1016 |
D1_DYN_OPT_TYPE | DYN_OPT_EVENT_BO_CD | CHAR | 120 |
D1_DYN_OPT_TYPE | EVENT_PARTICIPATION_BO_CD | CHAR | 120 |
D1_DYN_OPT_TYPE | LOCATION_REQD_SOURCE_FLG | CHAR | 16 |
D1_DYN_OPT_TYPE_QTY_TYPE | DYN_OPT_TYPE_CD | VARCHAR2 | 120 |
D1_DYN_OPT_TYPE_QTY_TYPE | DYN_OPT_TYPE_QTY_TYPE | VARCHAR2 | 1016 |
D1_DYN_OPT_TYPE_QTY_TYPE | VERSION | NUMBER | 22 |
D1_DYN_OPT_TYPE_REL | DYN_OPT_TYPE_CD | VARCHAR2 | 120 |
D1_DYN_OPT_TYPE_REL | DYN_OPT_TYPE_REL_TYPE_CD | VARCHAR2 | 120 |
D1_DYN_OPT_TYPE_REL | SEQNO | NUMBER | 22 |
D1_DYN_OPT_TYPE_REL | VERSION | NUMBER | 22 |
D1_DYN_OPT_USG_GRP | CALC_GRP_CATEGORY_FLG | CHAR | 16 |
D1_DYN_OPT_USG_GRP | DYN_OPT_ID | CHAR | 48 |
D1_DYN_OPT_USG_GRP | EFF_DTTM | DATE | 7 |
D1_DYN_OPT_USG_GRP | EXPIRATION_DTTM | DATE | 7 |
D1_DYN_OPT_USG_GRP | USG_GRP_CD | VARCHAR2 | 120 |
D1_DYN_OPT_USG_GRP | VERSION | NUMBER | 22 |
D1_ENTITY_GRP | BO_DATA_AREA | CLOB | 4000 |
D1_ENTITY_GRP | BUS_OBJ_CD | CHAR | 120 |
D1_ENTITY_GRP | ENTITY_GRP_ASSGN_OPT_FLG | CHAR | 16 |
D1_ENTITY_GRP | ENTITY_GRP_CATEGORY | VARCHAR2 | 1016 |
D1_ENTITY_GRP | ENTITY_GRP_CD | VARCHAR2 | 120 |
D1_ENTITY_GRP | ENTITY_GRP_DEACT_OPT_FLG | CHAR | 16 |
D1_ENTITY_GRP | ENTITY_GRP_STAT_FLG | CHAR | 16 |
D1_ENTITY_GRP | VERSION | NUMBER | 22 |
D1_ENTITY_GRP_CHAR | ADHOC_CHAR_VAL | VARCHAR2 | 1016 |
D1_ENTITY_GRP_CHAR | CHAR_TYPE_CD | CHAR | 32 |
D1_ENTITY_GRP_CHAR | CHAR_VAL | CHAR | 64 |
D1_ENTITY_GRP_CHAR | CHAR_VAL_FK1 | VARCHAR2 | 200 |
D1_ENTITY_GRP_CHAR | CHAR_VAL_FK2 | VARCHAR2 | 200 |
D1_ENTITY_GRP_CHAR | CHAR_VAL_FK3 | VARCHAR2 | 200 |
D1_ENTITY_GRP_CHAR | CHAR_VAL_FK4 | VARCHAR2 | 200 |
D1_ENTITY_GRP_CHAR | CHAR_VAL_FK5 | VARCHAR2 | 200 |
D1_ENTITY_GRP_CHAR | ENTITY_GRP_CD | VARCHAR2 | 120 |
D1_ENTITY_GRP_CHAR | SEQ_NUM | NUMBER | 22 |
D1_ENTITY_GRP_CHAR | SRCH_CHAR_VAL | VARCHAR2 | 200 |
D1_ENTITY_GRP_CHAR | VERSION | NUMBER | 22 |
D1_ENTITY_GRP_CRIT | CRITERIA_SEQ_NUM | NUMBER | 22 |
D1_ENTITY_GRP_CRIT | ENTITY_GRP_CD | VARCHAR2 | 120 |
D1_ENTITY_GRP_CRIT | GRP_CRITERIA_SRC | VARCHAR2 | 1016 |
D1_ENTITY_GRP_CRIT | VERSION | NUMBER | 22 |
D1_ENTITY_GRP_CRIT_VAL | BO_DATA_AREA | CLOB | 4000 |
D1_ENTITY_GRP_CRIT_VAL | CRITERIA_SEQ_NUM | NUMBER | 22 |
D1_ENTITY_GRP_CRIT_VAL | CRITERIA_VALUE | CHAR | 200 |
D1_ENTITY_GRP_CRIT_VAL | CRITERIA_VAL_SEQ_NUM | NUMBER | 22 |
D1_ENTITY_GRP_CRIT_VAL | ENTITY_GRP_CD | VARCHAR2 | 120 |
D1_ENTITY_GRP_CRIT_VAL | GRP_CRITERIA_SRC | VARCHAR2 | 1016 |
D1_ENTITY_GRP_CRIT_VAL | VERSION | NUMBER | 22 |
D1_ENTITY_GRP_L | DESCR100 | VARCHAR2 | 400 |
D1_ENTITY_GRP_L | DESCRLONG | VARCHAR2 | 16000 |
D1_ENTITY_GRP_L | ENTITY_GRP_CD | VARCHAR2 | 120 |
D1_ENTITY_GRP_L | LANGUAGE_CD | CHAR | 12 |
D1_ENTITY_GRP_L | VERSION | NUMBER | 22 |
D1_EVT_PARTICIPATION | BO_STATUS_CD | CHAR | 48 |
D1_EVT_PARTICIPATION | BO_STATUS_REASON_CD | VARCHAR2 | 120 |
D1_EVT_PARTICIPATION | BO_XML_DATA_AREA | XMLTYPE | 2000 |
D1_EVT_PARTICIPATION | BUS_OBJ_CD | CHAR | 120 |
D1_EVT_PARTICIPATION | CRE_DTTM | DATE | 7 |
D1_EVT_PARTICIPATION | D1_DEVICE_ID | CHAR | 48 |
D1_EVT_PARTICIPATION | DYN_OPT_EVENT_ID | CHAR | 56 |
D1_EVT_PARTICIPATION | DYN_OPT_ID | CHAR | 48 |
D1_EVT_PARTICIPATION | EVENT_PARTICIPATION_ID | CHAR | 56 |
D1_EVT_PARTICIPATION | ILM_ARCH_SW | CHAR | 4 |
D1_EVT_PARTICIPATION | ILM_DT | DATE | 7 |
D1_EVT_PARTICIPATION | OUTCOME_FLG | CHAR | 16 |
D1_EVT_PARTICIPATION | PARTICIPATION_END_DTTM | DATE | 7 |
D1_EVT_PARTICIPATION | PARTICIPATION_START_DTTM | DATE | 7 |
D1_EVT_PARTICIPATION | PREEMPTIVE_OPT_OUT_FLG | CHAR | 16 |
D1_EVT_PARTICIPATION | RESERVATION_END_DTTM | DATE | 7 |
D1_EVT_PARTICIPATION | RESERVATION_FLG | CHAR | 16 |
D1_EVT_PARTICIPATION | RESERVATION_START_DTTM | DATE | 7 |
D1_EVT_PARTICIPATION | STATUS_UPD_DTTM | DATE | 7 |
D1_EVT_PARTICIPATION | US_ID | CHAR | 48 |
D1_EVT_PARTICIPATION | VERSION | NUMBER | 22 |
D1_EVT_PARTICIPATION_CHAR | ADHOC_CHAR_VAL | VARCHAR2 | 1016 |
D1_EVT_PARTICIPATION_CHAR | CHAR_TYPE_CD | CHAR | 32 |
D1_EVT_PARTICIPATION_CHAR | CHAR_VAL | CHAR | 64 |
D1_EVT_PARTICIPATION_CHAR | CHAR_VAL_FK1 | VARCHAR2 | 200 |
D1_EVT_PARTICIPATION_CHAR | CHAR_VAL_FK2 | VARCHAR2 | 200 |
D1_EVT_PARTICIPATION_CHAR | CHAR_VAL_FK3 | VARCHAR2 | 200 |
D1_EVT_PARTICIPATION_CHAR | CHAR_VAL_FK4 | VARCHAR2 | 200 |
D1_EVT_PARTICIPATION_CHAR | CHAR_VAL_FK5 | VARCHAR2 | 200 |
D1_EVT_PARTICIPATION_CHAR | EVENT_PARTICIPATION_ID | VARCHAR2 | 56 |
D1_EVT_PARTICIPATION_CHAR | SEQ_NUM | NUMBER | 22 |
D1_EVT_PARTICIPATION_CHAR | SRCH_CHAR_VAL | VARCHAR2 | 200 |
D1_EVT_PARTICIPATION_CHAR | VERSION | NUMBER | 22 |
D1_EVT_PARTICIPATION_K | ENV_ID | NUMBER | 22 |
D1_EVT_PARTICIPATION_K | EVENT_PARTICIPATION_ID | CHAR | 56 |
D1_EVT_PARTICIPATION_LOG | ADHOC_CHAR_VAL | VARCHAR2 | 1016 |
D1_EVT_PARTICIPATION_LOG | BO_STATUS_CD | CHAR | 48 |
D1_EVT_PARTICIPATION_LOG | BO_STATUS_REASON_CD | VARCHAR2 | 120 |
D1_EVT_PARTICIPATION_LOG | CHAR_TYPE_CD | CHAR | 32 |
D1_EVT_PARTICIPATION_LOG | CHAR_VAL | CHAR | 64 |
D1_EVT_PARTICIPATION_LOG | CHAR_VAL_FK1 | VARCHAR2 | 200 |
D1_EVT_PARTICIPATION_LOG | CHAR_VAL_FK2 | VARCHAR2 | 200 |
D1_EVT_PARTICIPATION_LOG | CHAR_VAL_FK3 | VARCHAR2 | 200 |
D1_EVT_PARTICIPATION_LOG | CHAR_VAL_FK4 | VARCHAR2 | 200 |
D1_EVT_PARTICIPATION_LOG | CHAR_VAL_FK5 | VARCHAR2 | 200 |
D1_EVT_PARTICIPATION_LOG | DESCRLONG | VARCHAR2 | 16000 |
D1_EVT_PARTICIPATION_LOG | EVENT_PARTICIPATION_ID | CHAR | 56 |
D1_EVT_PARTICIPATION_LOG | LOG_DTTM | DATE | 7 |
D1_EVT_PARTICIPATION_LOG | LOG_ENTRY_TYPE_FLG | CHAR | 16 |
D1_EVT_PARTICIPATION_LOG | MESSAGE_CAT_NBR | NUMBER | 22 |
D1_EVT_PARTICIPATION_LOG | MESSAGE_NBR | NUMBER | 22 |
D1_EVT_PARTICIPATION_LOG | SEQNO | NUMBER | 22 |
D1_EVT_PARTICIPATION_LOG | USER_ID | CHAR | 32 |
D1_EVT_PARTICIPATION_LOG | VERSION | NUMBER | 22 |
D1_EVT_PARTICIPATION_LOG_PARM | EVENT_PARTICIPATION_ID | CHAR | 56 |
D1_EVT_PARTICIPATION_LOG_PARM | MSG_PARM_TYP_FLG | CHAR | 16 |
D1_EVT_PARTICIPATION_LOG_PARM | MSG_PARM_VAL | VARCHAR2 | 8000 |
D1_EVT_PARTICIPATION_LOG_PARM | PARM_SEQ | NUMBER | 22 |
D1_EVT_PARTICIPATION_LOG_PARM | SEQNO | NUMBER | 22 |
D1_EVT_PARTICIPATION_LOG_PARM | VERSION | NUMBER | 22 |
D1_FACILITY_SP | D1_SP_ID | CHAR | 48 |
D1_FACILITY_SP | FACILITY_ID | CHAR | 56 |
D1_FACILITY_SP | VERSION | NUMBER | 22 |
D1_IMD_CTRL_STAGE | ALG_CD | CHAR | 48 |
D1_IMD_CTRL_STAGE | D1_FROM_DTTM | DATE | 7 |
D1_IMD_CTRL_STAGE | D1_TO_DTTM | DATE | 7 |
D1_IMD_CTRL_STAGE | IMD_CTRL_DC_ID | CHAR | 48 |
D1_IMD_CTRL_STAGE | IMD_CTRL_MC_ID | CHAR | 48 |
D1_IMD_CTRL_STAGE | IMD_CTRL_STAGE_ID | CHAR | 56 |
D1_IMD_CTRL_STAGE | IMD_STAGE_PAYLOAD_XML | CLOB | 4000 |
D1_IMD_CTRL_STAGE | IMD_STAGE_STATUS_FLG | CHAR | 16 |
D1_IMD_CTRL_STAGE | IMD_TYPE_CD | VARCHAR2 | 120 |
D1_IMD_CTRL_STAGE_K | ENV_ID | NUMBER | 22 |
D1_IMD_CTRL_STAGE_K | IMD_CTRL_STAGE_ID | CHAR | 56 |
D1_IMD_TYPE | BO_DATA_AREA | CLOB | 4000 |
D1_IMD_TYPE | BUS_OBJ_CD | CHAR | 120 |
D1_IMD_TYPE | IMD_BUS_OBJ_CD | CHAR | 120 |
D1_IMD_TYPE | IMD_SEEDER_FLG | CHAR | 16 |
D1_IMD_TYPE | IMD_TYPE_CD | VARCHAR2 | 120 |
D1_IMD_TYPE | IMD_TYPE_STATUS_FLG | CHAR | 16 |
D1_IMD_TYPE | OWNER_FLG | CHAR | 16 |
D1_IMD_TYPE | VERSION | NUMBER | 22 |
D1_IMD_TYPE_ALG | ALG_CD | CHAR | 48 |
D1_IMD_TYPE_ALG | ERROR_BO_STATUS_CD | CHAR | 48 |
D1_IMD_TYPE_ALG | IMD_TYPE_ALG_STATUS_FLG | CHAR | 16 |
D1_IMD_TYPE_ALG | IMD_TYPE_CD | VARCHAR2 | 120 |
D1_IMD_TYPE_ALG | IMD_TYPE_SEVT_FLG | CHAR | 16 |
D1_IMD_TYPE_ALG | OWNER_FLG | CHAR | 16 |
D1_IMD_TYPE_ALG | SEQ_NUM | NUMBER | 22 |
D1_IMD_TYPE_ALG | VERSION | NUMBER | 22 |
D1_IMD_TYPE_L | DESCR100 | VARCHAR2 | 400 |
D1_IMD_TYPE_L | DESCRLONG | VARCHAR2 | 16000 |
D1_IMD_TYPE_L | IMD_TYPE_CD | VARCHAR2 | 120 |
D1_IMD_TYPE_L | LANGUAGE_CD | CHAR | 12 |
D1_IMD_TYPE_L | OWNER_FLG | CHAR | 16 |
D1_IMD_TYPE_L | VERSION | NUMBER | 22 |
D1_INBOUND_COMM_VW | D1_SP_ID | CHAR | 48 |
D1_INBOUND_COMM_VW | DIVISION_CD | VARCHAR2 | 120 |
D1_INBOUND_COMM_VW | POSTAL | CHAR | 48 |
D1_MC_TYPE_PER_EST_EVAL_VW | CUT_OFF_TIME | VARCHAR2 | 32767 |
D1_MC_TYPE_PER_EST_EVAL_VW | EVALUATION_DTTM | DATE | 7 |
D1_MC_TYPE_PER_EST_EVAL_VW | HRS_WAIT_BEFORE_EST | NUMBER | 22 |
D1_MC_TYPE_PER_EST_EVAL_VW | INTERVAL_SCALAR_FLG | CHAR | 16 |
D1_MC_TYPE_PER_EST_EVAL_VW | MC_CLASS_FLG | CHAR | 16 |
D1_MC_TYPE_PER_EST_EVAL_VW | MEASR_COMP_TYPE_CD | VARCHAR2 | 120 |
D1_MC_TYPE_PER_EST_EVAL_VW | TIME_ZONE_CD | CHAR | 40 |
D1_MDSI | VERSION | NUMBER | 22 |
D1_MDSS | VERSION | NUMBER | 22 |
D1_MEASR_COMP | ACCESS_GRP_CD | CHAR | 48 |
D1_MEASR_COMP_SET | DISTRIBUTE_LOAD_FLG | CHAR | 16 |
D1_MEASR_COMP_SET | LOAD_DISTRIBUTION_FORMULA | VARCHAR2 | 1016 |
D1_MEASR_COMP_SET | LOAD_DIST_MANAGED_BY_FLG | CHAR | 16 |
D1_MEASR_COMP_SET | NBR_OF_DIGITS_TO_USE | NUMBER | 22 |
D1_MEASR_COMP_TYPE | ANCHR_TIME | DATE | 7 |
D1_MEASR_COMP_TYPE | IMD_HANDLING_FLG | CHAR | 16 |
D1_MSRMT | PREVEE_MSRMT_COND_FLG | CHAR | 24 |
D1_MSRMT | PREVEE_MSRMT_VAL | NUMBER | 22 |
D1_MSRMT | PREVEE_READING_COND_FLG | CHAR | 24 |
D1_MSRMT | PREVEE_READING_VAL | NUMBER | 22 |
D1_MSRMT | USER_ID | CHAR | 32 |
D1_MSRMT_AUDIT | AFTER_COMBINED_MULTIPLIER | NUMBER | 22 |
D1_MSRMT_AUDIT | AFTER_MSRMT_COND_FLG | CHAR | 24 |
D1_MSRMT_AUDIT | AFTER_MSRMT_USE_FLG | CHAR | 16 |
D1_MSRMT_AUDIT | AFTER_MSRMT_VAL | NUMBER | 22 |
D1_MSRMT_AUDIT | AFTER_PREVEE_MSRMT_COND_FLG | CHAR | 24 |
D1_MSRMT_AUDIT | AFTER_PREVEE_MSRMT_VAL | NUMBER | 22 |
D1_MSRMT_AUDIT | AFTER_PREVEE_READING_COND_FLG | CHAR | 24 |
D1_MSRMT_AUDIT | AFTER_PREVEE_READING_VAL | NUMBER | 22 |
D1_MSRMT_AUDIT | AFTER_PREV_MSRMT_DTTM | DATE | 7 |
D1_MSRMT_AUDIT | AFTER_READING_COND_FLG | CHAR | 24 |
D1_MSRMT_AUDIT | AFTER_READING_VAL | NUMBER | 22 |
D1_MSRMT_AUDIT | BEFORE_COMBINED_MULTIPLIER | NUMBER | 22 |
D1_MSRMT_AUDIT | BEFORE_MSRMT_COND_FLG | CHAR | 24 |
D1_MSRMT_AUDIT | BEFORE_MSRMT_USE_FLG | CHAR | 16 |
D1_MSRMT_AUDIT | BEFORE_MSRMT_VAL | NUMBER | 22 |
D1_MSRMT_AUDIT | BEFORE_PREVEE_MSRMT_COND_FLG | CHAR | 24 |
D1_MSRMT_AUDIT | BEFORE_PREVEE_MSRMT_VAL | NUMBER | 22 |
D1_MSRMT_AUDIT | BEFORE_PREVEE_READING_COND_FLG | CHAR | 24 |
D1_MSRMT_AUDIT | BEFORE_PREVEE_READING_VAL | NUMBER | 22 |
D1_MSRMT_AUDIT | BEFORE_PREV_MSRMT_DTTM | DATE | 7 |
D1_MSRMT_AUDIT | BEFORE_READING_COND_FLG | CHAR | 24 |
D1_MSRMT_AUDIT | BEFORE_READING_VAL | NUMBER | 22 |
D1_MSRMT_AUDIT | LOG_DTTM | DATE | 7 |
D1_MSRMT_AUDIT | MEASR_COMP_ID | CHAR | 48 |
D1_MSRMT_AUDIT | MSRMT_AUDIT_ENTRY_TYPE_FLG | CHAR | 16 |
D1_MSRMT_AUDIT | MSRMT_DTTM | DATE | 7 |
D1_MSRMT_AUDIT | SEQNO | NUMBER | 22 |
D1_MSRMT_AUDIT | USER_ID | CHAR | 32 |
D1_NW_LOC | NETWORK_NODE_1 | CHAR | 56 |
D1_NW_LOC | NETWORK_NODE_2 | CHAR | 56 |
D1_ON_DOE_VW | ADHOC_CHAR_VAL | VARCHAR2 | 1016 |
D1_ON_DO_VW | ADHOC_CHAR_VAL | VARCHAR2 | 1016 |
D1_ON_DVC_CFG_VW | ADHOC_CHAR_VAL | VARCHAR2 | 1016 |
D1_ON_IE_VW | ADHOC_CHAR_VAL | VARCHAR2 | 1016 |
D1_OUTBOUND_COMM_VW | D1_SP_ID | CHAR | 48 |
D1_OUTBOUND_COMM_VW | DIVISION_CD | VARCHAR2 | 120 |
D1_OUTBOUND_COMM_VW | POSTAL | CHAR | 48 |
D1_RULE | BO_DATA_AREA | CLOB | 4000 |
D1_RULE | BO_STATUS_CD | CHAR | 48 |
D1_RULE | BUS_OBJ_CD | VARCHAR2 | 120 |
D1_RULE | EFF_DT | DATE | 7 |
D1_RULE | EXPIRATION_DT | DATE | 7 |
D1_RULE | RULE_CD | VARCHAR2 | 120 |
D1_RULE | RULE_TYPE_FLG | CHAR | 16 |
D1_RULE | VERSION | NUMBER | 22 |
D1_RULE_CHAR | ADHOC_CHAR_VAL | VARCHAR2 | 1016 |
D1_RULE_CHAR | CHAR_TYPE_CD | CHAR | 32 |
D1_RULE_CHAR | CHAR_VAL | CHAR | 64 |
D1_RULE_CHAR | CHAR_VAL_FK1 | VARCHAR2 | 200 |
D1_RULE_CHAR | CHAR_VAL_FK2 | VARCHAR2 | 200 |
D1_RULE_CHAR | CHAR_VAL_FK3 | VARCHAR2 | 200 |
D1_RULE_CHAR | CHAR_VAL_FK4 | VARCHAR2 | 200 |
D1_RULE_CHAR | CHAR_VAL_FK5 | VARCHAR2 | 200 |
D1_RULE_CHAR | RULE_CD | VARCHAR2 | 120 |
D1_RULE_CHAR | SEQ_NUM | NUMBER | 22 |
D1_RULE_CHAR | SRCH_CHAR_VAL | VARCHAR2 | 200 |
D1_RULE_CHAR | VERSION | NUMBER | 22 |
D1_RULE_L | DESCR100 | VARCHAR2 | 400 |
D1_RULE_L | DESCRLONG | VARCHAR2 | 16000 |
D1_RULE_L | LANGUAGE_CD | CHAR | 12 |
D1_RULE_L | RULE_CD | VARCHAR2 | 120 |
D1_RULE_L | VERSION | NUMBER | 22 |
D1_RULE_PARM | CALC_FREQUENCY | VARCHAR2 | 1016 |
D1_RULE_PARM | D1_SEASONAL_FLG | CHAR | 16 |
D1_RULE_PARM | ELIG_ALG_CD | CHAR | 48 |
D1_RULE_PARM | LINE_EXT_ID | VARCHAR2 | 1016 |
D1_RULE_PARM | MIN_DAYS | NUMBER | 22 |
D1_RULE_PARM | PRORATE_OPTION_FLG | CHAR | 16 |
D1_RULE_PARM | RULE_CD | VARCHAR2 | 120 |
D1_RULE_PARM | RULE_TYPE_CATEGORY | VARCHAR2 | 1016 |
D1_RULE_PARM | SEASON_END | CHAR | 16 |
D1_RULE_PARM | SEASON_START | CHAR | 16 |
D1_RULE_PARM | SEQNO | NUMBER | 22 |
D1_RULE_PARM | SETT_FREQ_FLG | CHAR | 16 |
D1_RULE_PARM | USG_GRP_CD | VARCHAR2 | 120 |
D1_RULE_PARM | VERSION | NUMBER | 22 |
D1_SP | D1_ABOLISH_DT | DATE | 7 |
D1_SP | D1_INSTALL_DT | DATE | 7 |
D1_SP | D1_SERVICE_AREA_CD | VARCHAR2 | 120 |
D1_SPR | ACTIVE_INACTIVE_FLG | CHAR | 16 |
D1_SPR | CONTACT_ID | CHAR | 48 |
D1_SPR | END_DT | DATE | 7 |
D1_SPR | START_DT | DATE | 7 |
D1_SPR_PROG | D1_SPR_CD | VARCHAR2 | 120 |
D1_SPR_PROG | DYN_OPT_ID | CHAR | 48 |
D1_SPR_PROG | END_DT | DATE | 7 |
D1_SPR_PROG | SPR_LFDI | VARCHAR2 | 1016 |
D1_SPR_PROG | START_DT | DATE | 7 |
D1_SPR_PROG | UTILITY_APPROVAL_REQD_FLG | CHAR | 16 |
D1_SP_ENTITY_GRP | BO_DATA_AREA | CLOB | 4000 |
D1_SP_ENTITY_GRP | D1_SP_ID | CHAR | 48 |
D1_SP_ENTITY_GRP | EFF_DTTM | DATE | 7 |
D1_SP_ENTITY_GRP | ENTITY_GRP_CD | VARCHAR2 | 120 |
D1_SP_ENTITY_GRP | EXPIRATION_DTTM | DATE | 7 |
D1_SP_ENTITY_GRP | VERSION | NUMBER | 22 |
D1_SP_EQPMNT | ACTIVE_INACTIVE_FLG | CHAR | 16 |
D1_SP_EQPMNT | BO_DATA_AREA | CLOB | 4000 |
D1_SP_EQPMNT | EQPMNT_CNT | NUMBER | 22 |
D1_SP_EQPMNT | SEQNO | NUMBER | 22 |
D1_SP_TYPE | SP_CLASS_FLG | CHAR | 16 |
D1_SP_TYPE_DISCONNECT_LOCATION | BO_DATA_AREA | CLOB | 4000 |
D1_SP_TYPE_DISCONNECT_LOCATION | D1_SP_TYPE_CD | VARCHAR2 | 120 |
D1_SP_TYPE_DISCONNECT_LOCATION | DISCONN_LOC_FLG | CHAR | 16 |
D1_SP_TYPE_DISCONNECT_LOCATION | VERSION | NUMBER | 22 |
D1_SP_TYPE_DIV | D1_SP_TYPE_CD | VARCHAR2 | 120 |
D1_SP_TYPE_DIV | DIVISION_CD | VARCHAR2 | 120 |
D1_SP_TYPE_DIV | VERSION | NUMBER | 22 |
D1_SP_TYPE_FIELD_TASK_TYPE | BO_DATA_AREA | CLOB | 4000 |
D1_SP_TYPE_FIELD_TASK_TYPE | D1_SP_TYPE_CD | VARCHAR2 | 120 |
D1_SP_TYPE_FIELD_TASK_TYPE | FIELD_TASK_TYPE | VARCHAR2 | 1016 |
D1_SP_TYPE_FIELD_TASK_TYPE | VERSION | NUMBER | 22 |
D1_SVC_TYPE | STD_SVC_TYPE_FLG | CHAR | 16 |
D1_US | PGM_ENRL_SRC_FLG | CHAR | 16 |
D1_USAGE | EVT_SETT_REQ_TYPE_FLG | CHAR | 16 |
D1_USAGE | EXTRACT_FLG | CHAR | 16 |
D1_USAGE | RULE_CD | VARCHAR2 | 120 |
D1_USAGE | RULE_TYPE_CATEGORY | VARCHAR2 | 1016 |
D1_USAGE_PERIOD_SQ | D1_AMOUNT | NUMBER | 22 |
D1_USAGE_PERIOD_SQ | D1_CURRENCY_CD | CHAR | 12 |
D1_USAGE_PERIOD_SQ | D1_FORMULA | VARCHAR2 | 200 |
D1_USAGE_PERIOD_SQ | D1_PRICE | NUMBER | 22 |
D1_USAGE_PERIOD_SQ | D1_QUANTITY1 | NUMBER | 22 |
D1_USAGE_PERIOD_SQ | D1_QUANTITY2 | NUMBER | 22 |
D1_USAGE_PERIOD_SQ | D1_QUANTITY3 | NUMBER | 22 |
D1_USAGE_PERIOD_SQ | D1_QUANTITY4 | NUMBER | 22 |
D1_USAGE_PERIOD_SQ | D1_QUANTITY5 | NUMBER | 22 |
D1_USAGE_PERIOD_SQ | D1_VARIABLE_NAME | CHAR | 80 |
D1_USAGE_PERIOD_SQ | DYN_OPT_EVENT_ID | CHAR | 56 |
D1_USAGE_PERIOD_SQ | DYN_OPT_ID | CHAR | 48 |
D1_USAGE_PERIOD_SQ | LINE_DESCR | VARCHAR2 | 1016 |
D1_USAGE_PERIOD_SQ_DATA | D1_AMOUNT | NUMBER | 22 |
D1_USAGE_PERIOD_SQ_DATA | D1_PRICE | NUMBER | 22 |
D1_USG_RULE_L | LINE_DESCR | VARCHAR2 | 1016 |
D1_US_DYN_OPT | SEQNO | NUMBER | 22 |
D1_US_SP | SEQNO | NUMBER | 22 |
D1_US_TYPE | EVT_SETT_BO_CD | CHAR | 120 |
D1_US_TYPE | PROC_TIMETABLE_TYPE_CD | VARCHAR2 | 120 |
D1_US_TYPE_VALID_US_CHAR | ADHOC_CHAR_VAL | VARCHAR2 | 1016 |
D1_US_TYPE_VALID_US_CHAR | CHAR_TYPE_CD | CHAR | 32 |
D1_US_TYPE_VALID_US_CHAR | CHAR_VAL | CHAR | 64 |
D1_US_TYPE_VALID_US_CHAR | CHAR_VAL_FK1 | VARCHAR2 | 200 |
D1_US_TYPE_VALID_US_CHAR | CHAR_VAL_FK2 | VARCHAR2 | 200 |
D1_US_TYPE_VALID_US_CHAR | CHAR_VAL_FK3 | VARCHAR2 | 200 |
D1_US_TYPE_VALID_US_CHAR | CHAR_VAL_FK4 | VARCHAR2 | 200 |
D1_US_TYPE_VALID_US_CHAR | CHAR_VAL_FK5 | VARCHAR2 | 200 |
D1_US_TYPE_VALID_US_CHAR | DEFAULT_SW | CHAR | 4 |
D1_US_TYPE_VALID_US_CHAR | REQUIRED_SW | CHAR | 4 |
D1_US_TYPE_VALID_US_CHAR | SORT_SEQ | NUMBER | 22 |
D1_US_TYPE_VALID_US_CHAR | US_TYPE_CD | VARCHAR2 | 120 |
D1_US_TYPE_VALID_US_CHAR | VERSION | NUMBER | 22 |
D2_MEASR_QTY_AGR_MV | LOCAL_DT | DATE | 7 |
D2_MEASR_QTY_AGR_MV | MEASR_COMP_ID | CHAR | 48 |
D2_MEASR_QTY_AGR_MV | MSRMT_DT | DATE | 7 |
D2_MEASR_QTY_AGR_MV | MSRMT_DTTM | DATE | 7 |
D2_MEASR_QTY_AGR_MV | MSRMT_LOCAL_DTTM | DATE | 7 |
D2_MEASR_QTY_AGR_MV | MSRMT_VAL | NUMBER | 22 |
D2_MEASR_QTY_AGR_MV | MSRMT_VAL1 | NUMBER | 22 |
D2_MEASR_QTY_AGR_MV | MSRMT_VAL10 | NUMBER | 22 |
D2_MEASR_QTY_AGR_MV | MSRMT_VAL2 | NUMBER | 22 |
D2_MEASR_QTY_AGR_MV | MSRMT_VAL3 | NUMBER | 22 |
D2_MEASR_QTY_AGR_MV | MSRMT_VAL4 | NUMBER | 22 |
D2_MEASR_QTY_AGR_MV | MSRMT_VAL5 | NUMBER | 22 |
D2_MEASR_QTY_AGR_MV | MSRMT_VAL6 | NUMBER | 22 |
D2_MEASR_QTY_AGR_MV | MSRMT_VAL7 | NUMBER | 22 |
D2_MEASR_QTY_AGR_MV | MSRMT_VAL8 | NUMBER | 22 |
D2_MEASR_QTY_AGR_MV | MSRMT_VAL9 | NUMBER | 22 |
D2_MEASR_QTY_MV | CITY | VARCHAR2 | 200 |
D2_MEASR_QTY_MV | D1_MODEL_CD | VARCHAR2 | 200 |
D2_MEASR_QTY_MV | D1_SPR_CD | VARCHAR2 | 200 |
D2_MEASR_QTY_MV | D1_SVC_TPE_CD | VARCHAR2 | 200 |
D2_MEASR_QTY_MV | DEVICE_TYPE_CD | VARCHAR2 | 200 |
D2_MEASR_QTY_MV | DEVICE_TYPE_DESCR | VARCHAR2 | 400 |
D2_MEASR_QTY_MV | GEO_CODE | VARCHAR2 | 200 |
D2_MEASR_QTY_MV | HEAD_END_SYSTEM_CD | VARCHAR2 | 200 |
D2_MEASR_QTY_MV | HEAD_END_SYSTEM_DESCR | VARCHAR2 | 400 |
D2_MEASR_QTY_MV | MANUFACTURER_CD | VARCHAR2 | 200 |
D2_MEASR_QTY_MV | MANUFACTURER_DESCR | VARCHAR2 | 400 |
D2_MEASR_QTY_MV | MC_TYPE_DESCR | VARCHAR2 | 400 |
D2_MEASR_QTY_MV | MEASR_COMP_ID | CHAR | 48 |
D2_MEASR_QTY_MV | MEASR_COMP_TYPE_CD | VARCHAR2 | 120 |
D2_MEASR_QTY_MV | MKT_CD | VARCHAR2 | 200 |
D2_MEASR_QTY_MV | MKT_DESCR | VARCHAR2 | 400 |
D2_MEASR_QTY_MV | MKT_REL_TYPE_DESCR | VARCHAR2 | 240 |
D2_MEASR_QTY_MV | MKT_REL_TYPE_FLG | VARCHAR2 | 200 |
D2_MEASR_QTY_MV | MODEL_DESCR | VARCHAR2 | 400 |
D2_MEASR_QTY_MV | POSTAL | VARCHAR2 | 200 |
D2_MEASR_QTY_MV | SPR_DESCR | VARCHAR2 | 400 |
D2_MEASR_QTY_MV | SVC_TYPE_DESCR | VARCHAR2 | 400 |
D2_MEASR_QTY_MV | USG_CALC_GRP_CD | VARCHAR2 | 200 |
D2_MEASR_QTY_MV | USG_CALC_GRP_DESCR | VARCHAR2 | 400 |
D2_QUALITY_CNT_AGR_MV | LOCAL_DT | DATE | 7 |
D2_QUALITY_CNT_AGR_MV | MEASR_COMP_ID | CHAR | 48 |
D2_QUALITY_CNT_AGR_MV | MSRMT_DT | DATE | 7 |
D2_QUALITY_CNT_AGR_MV | MSRMT_DTTM | DATE | 7 |
D2_QUALITY_CNT_AGR_MV | MSRMT_LOCAL_DTTM | DATE | 7 |
D2_QUALITY_CNT_AGR_MV | MSRMT_VAL | NUMBER | 22 |
D2_QUALITY_CNT_AGR_MV | MSRMT_VAL1 | NUMBER | 22 |
D2_QUALITY_CNT_AGR_MV | MSRMT_VAL10 | NUMBER | 22 |
D2_QUALITY_CNT_AGR_MV | MSRMT_VAL2 | NUMBER | 22 |
D2_QUALITY_CNT_AGR_MV | MSRMT_VAL3 | NUMBER | 22 |
D2_QUALITY_CNT_AGR_MV | MSRMT_VAL4 | NUMBER | 22 |
D2_QUALITY_CNT_AGR_MV | MSRMT_VAL5 | NUMBER | 22 |
D2_QUALITY_CNT_AGR_MV | MSRMT_VAL6 | NUMBER | 22 |
D2_QUALITY_CNT_AGR_MV | MSRMT_VAL7 | NUMBER | 22 |
D2_QUALITY_CNT_AGR_MV | MSRMT_VAL8 | NUMBER | 22 |
D2_QUALITY_CNT_AGR_MV | MSRMT_VAL9 | NUMBER | 22 |
D2_QUALITY_CNT_MV | CITY | VARCHAR2 | 200 |
D2_QUALITY_CNT_MV | D1_MODEL_CD | VARCHAR2 | 200 |
D2_QUALITY_CNT_MV | D1_SPR_CD | VARCHAR2 | 200 |
D2_QUALITY_CNT_MV | D1_SVC_TPE_CD | VARCHAR2 | 200 |
D2_QUALITY_CNT_MV | DEVICE_TYPE_CD | VARCHAR2 | 200 |
D2_QUALITY_CNT_MV | DEVICE_TYPE_DESCR | VARCHAR2 | 400 |
D2_QUALITY_CNT_MV | GEO_CODE | VARCHAR2 | 200 |
D2_QUALITY_CNT_MV | HEAD_END_SYSTEM_CD | VARCHAR2 | 200 |
D2_QUALITY_CNT_MV | HEAD_END_SYSTEM_DESCR | VARCHAR2 | 400 |
D2_QUALITY_CNT_MV | MANUFACTURER_CD | VARCHAR2 | 200 |
D2_QUALITY_CNT_MV | MANUFACTURER_DESCR | VARCHAR2 | 400 |
D2_QUALITY_CNT_MV | MC_TYPE_DESCR | VARCHAR2 | 400 |
D2_QUALITY_CNT_MV | MEASR_COMP_ID | CHAR | 48 |
D2_QUALITY_CNT_MV | MEASR_COMP_TYPE_CD | VARCHAR2 | 120 |
D2_QUALITY_CNT_MV | MKT_CD | VARCHAR2 | 200 |
D2_QUALITY_CNT_MV | MKT_DESCR | VARCHAR2 | 400 |
D2_QUALITY_CNT_MV | MKT_REL_TYPE_DESCR | VARCHAR2 | 240 |
D2_QUALITY_CNT_MV | MKT_REL_TYPE_FLG | VARCHAR2 | 200 |
D2_QUALITY_CNT_MV | MODEL_DESCR | VARCHAR2 | 400 |
D2_QUALITY_CNT_MV | POSTAL | VARCHAR2 | 200 |
D2_QUALITY_CNT_MV | SPR_DESCR | VARCHAR2 | 400 |
D2_QUALITY_CNT_MV | SVC_TYPE_DESCR | VARCHAR2 | 400 |
D2_QUALITY_CNT_MV | USG_CALC_GRP_CD | VARCHAR2 | 200 |
D2_QUALITY_CNT_MV | USG_CALC_GRP_DESCR | VARCHAR2 | 400 |
D2_TIMELINESS_CNT_MV | CITY | VARCHAR2 | 200 |
D2_TIMELINESS_CNT_MV | D1_MODEL_CD | VARCHAR2 | 200 |
D2_TIMELINESS_CNT_MV | D1_SPR_CD | VARCHAR2 | 200 |
D2_TIMELINESS_CNT_MV | D1_SVC_TPE_CD | VARCHAR2 | 200 |
D2_TIMELINESS_CNT_MV | DEVICE_TYPE_CD | VARCHAR2 | 200 |
D2_TIMELINESS_CNT_MV | DEVICE_TYPE_DESCR | VARCHAR2 | 400 |
D2_TIMELINESS_CNT_MV | GEO_CODE | VARCHAR2 | 200 |
D2_TIMELINESS_CNT_MV | HEAD_END_SYSTEM_CD | VARCHAR2 | 200 |
D2_TIMELINESS_CNT_MV | HEAD_END_SYSTEM_DESCR | VARCHAR2 | 400 |
D2_TIMELINESS_CNT_MV | MANUFACTURER_CD | VARCHAR2 | 200 |
D2_TIMELINESS_CNT_MV | MANUFACTURER_DESCR | VARCHAR2 | 400 |
D2_TIMELINESS_CNT_MV | MC_TYPE_DESCR | VARCHAR2 | 400 |
D2_TIMELINESS_CNT_MV | MEASR_COMP_ID | CHAR | 48 |
D2_TIMELINESS_CNT_MV | MEASR_COMP_TYPE_CD | VARCHAR2 | 120 |
D2_TIMELINESS_CNT_MV | MKT_CD | VARCHAR2 | 200 |
D2_TIMELINESS_CNT_MV | MKT_DESCR | VARCHAR2 | 400 |
D2_TIMELINESS_CNT_MV | MKT_REL_TYPE_DESCR | VARCHAR2 | 240 |
D2_TIMELINESS_CNT_MV | MKT_REL_TYPE_FLG | VARCHAR2 | 200 |
D2_TIMELINESS_CNT_MV | MODEL_DESCR | VARCHAR2 | 400 |
D2_TIMELINESS_CNT_MV | POSTAL | VARCHAR2 | 200 |
D2_TIMELINESS_CNT_MV | SPR_DESCR | VARCHAR2 | 400 |
D2_TIMELINESS_CNT_MV | SVC_TYPE_DESCR | VARCHAR2 | 400 |
D2_TIMELINESS_CNT_MV | USG_CALC_GRP_CD | VARCHAR2 | 200 |
D2_TIMELINESS_CNT_MV | USG_CALC_GRP_DESCR | VARCHAR2 | 400 |
D2_TIMELINESS_QTY_MV | CITY | VARCHAR2 | 200 |
D2_TIMELINESS_QTY_MV | D1_MODEL_CD | VARCHAR2 | 200 |
D2_TIMELINESS_QTY_MV | D1_SPR_CD | VARCHAR2 | 200 |
D2_TIMELINESS_QTY_MV | D1_SVC_TPE_CD | VARCHAR2 | 200 |
D2_TIMELINESS_QTY_MV | DEVICE_TYPE_CD | VARCHAR2 | 200 |
D2_TIMELINESS_QTY_MV | DEVICE_TYPE_DESCR | VARCHAR2 | 400 |
D2_TIMELINESS_QTY_MV | GEO_CODE | VARCHAR2 | 200 |
D2_TIMELINESS_QTY_MV | HEAD_END_SYSTEM_CD | VARCHAR2 | 200 |
D2_TIMELINESS_QTY_MV | HEAD_END_SYSTEM_DESCR | VARCHAR2 | 400 |
D2_TIMELINESS_QTY_MV | MANUFACTURER_CD | VARCHAR2 | 200 |
D2_TIMELINESS_QTY_MV | MANUFACTURER_DESCR | VARCHAR2 | 400 |
D2_TIMELINESS_QTY_MV | MC_TYPE_DESCR | VARCHAR2 | 400 |
D2_TIMELINESS_QTY_MV | MEASR_COMP_ID | CHAR | 48 |
D2_TIMELINESS_QTY_MV | MEASR_COMP_TYPE_CD | VARCHAR2 | 120 |
D2_TIMELINESS_QTY_MV | MKT_CD | VARCHAR2 | 200 |
D2_TIMELINESS_QTY_MV | MKT_DESCR | VARCHAR2 | 400 |
D2_TIMELINESS_QTY_MV | MKT_REL_TYPE_DESCR | VARCHAR2 | 240 |
D2_TIMELINESS_QTY_MV | MKT_REL_TYPE_FLG | VARCHAR2 | 200 |
D2_TIMELINESS_QTY_MV | MODEL_DESCR | VARCHAR2 | 400 |
D2_TIMELINESS_QTY_MV | POSTAL | VARCHAR2 | 200 |
D2_TIMELINESS_QTY_MV | SPR_DESCR | VARCHAR2 | 400 |
D2_TIMELINESS_QTY_MV | SVC_TYPE_DESCR | VARCHAR2 | 400 |
D2_TIMELINESS_QTY_MV | USG_CALC_GRP_CD | VARCHAR2 | 200 |
D2_TIMELINESS_QTY_MV | USG_CALC_GRP_DESCR | VARCHAR2 | 400 |
D2_TIMELINES_CNT_AGR_MV | LOCAL_DT | DATE | 7 |
D2_TIMELINES_CNT_AGR_MV | MEASR_COMP_ID | CHAR | 48 |
D2_TIMELINES_CNT_AGR_MV | MSRMT_DT | DATE | 7 |
D2_TIMELINES_CNT_AGR_MV | MSRMT_DTTM | DATE | 7 |
D2_TIMELINES_CNT_AGR_MV | MSRMT_LOCAL_DTTM | DATE | 7 |
D2_TIMELINES_CNT_AGR_MV | MSRMT_VAL | NUMBER | 22 |
D2_TIMELINES_CNT_AGR_MV | MSRMT_VAL1 | NUMBER | 22 |
D2_TIMELINES_CNT_AGR_MV | MSRMT_VAL10 | NUMBER | 22 |
D2_TIMELINES_CNT_AGR_MV | MSRMT_VAL2 | NUMBER | 22 |
D2_TIMELINES_CNT_AGR_MV | MSRMT_VAL3 | NUMBER | 22 |
D2_TIMELINES_CNT_AGR_MV | MSRMT_VAL4 | NUMBER | 22 |
D2_TIMELINES_CNT_AGR_MV | MSRMT_VAL5 | NUMBER | 22 |
D2_TIMELINES_CNT_AGR_MV | MSRMT_VAL6 | NUMBER | 22 |
D2_TIMELINES_CNT_AGR_MV | MSRMT_VAL7 | NUMBER | 22 |
D2_TIMELINES_CNT_AGR_MV | MSRMT_VAL8 | NUMBER | 22 |
D2_TIMELINES_CNT_AGR_MV | MSRMT_VAL9 | NUMBER | 22 |
D2_TIMELINES_QTY_AGR_MV | LOCAL_DT | DATE | 7 |
D2_TIMELINES_QTY_AGR_MV | MEASR_COMP_ID | CHAR | 48 |
D2_TIMELINES_QTY_AGR_MV | MSRMT_DT | DATE | 7 |
D2_TIMELINES_QTY_AGR_MV | MSRMT_DTTM | DATE | 7 |
D2_TIMELINES_QTY_AGR_MV | MSRMT_LOCAL_DTTM | DATE | 7 |
D2_TIMELINES_QTY_AGR_MV | MSRMT_VAL | NUMBER | 22 |
D2_TIMELINES_QTY_AGR_MV | MSRMT_VAL1 | NUMBER | 22 |
D2_TIMELINES_QTY_AGR_MV | MSRMT_VAL10 | NUMBER | 22 |
D2_TIMELINES_QTY_AGR_MV | MSRMT_VAL2 | NUMBER | 22 |
D2_TIMELINES_QTY_AGR_MV | MSRMT_VAL3 | NUMBER | 22 |
D2_TIMELINES_QTY_AGR_MV | MSRMT_VAL4 | NUMBER | 22 |
D2_TIMELINES_QTY_AGR_MV | MSRMT_VAL5 | NUMBER | 22 |
D2_TIMELINES_QTY_AGR_MV | MSRMT_VAL6 | NUMBER | 22 |
D2_TIMELINES_QTY_AGR_MV | MSRMT_VAL7 | NUMBER | 22 |
D2_TIMELINES_QTY_AGR_MV | MSRMT_VAL8 | NUMBER | 22 |
D2_TIMELINES_QTY_AGR_MV | MSRMT_VAL9 | NUMBER | 22 |
F1_ACTION_METHOD | ACTION_METHOD_CD | VARCHAR2 | 120 |
F1_ACTION_METHOD | ACTION_METHOD_ROLE_XFLG | VARCHAR2 | 120 |
F1_ACTION_METHOD | BO_XML_DATA_AREA | XMLTYPE | 2000 |
F1_ACTION_METHOD | BUS_OBJ_CD | CHAR | 120 |
F1_ACTION_METHOD | VERSION | NUMBER | 22 |
F1_ACTION_METHOD_CHAR | ACTION_METHOD_CD | VARCHAR2 | 120 |
F1_ACTION_METHOD_CHAR | ADHOC_CHAR_VAL | VARCHAR2 | 1016 |
F1_ACTION_METHOD_CHAR | CHAR_TYPE_CD | CHAR | 32 |
F1_ACTION_METHOD_CHAR | CHAR_VAL | CHAR | 64 |
F1_ACTION_METHOD_CHAR | CHAR_VAL_FK1 | VARCHAR2 | 200 |
F1_ACTION_METHOD_CHAR | CHAR_VAL_FK2 | VARCHAR2 | 200 |
F1_ACTION_METHOD_CHAR | CHAR_VAL_FK3 | VARCHAR2 | 200 |
F1_ACTION_METHOD_CHAR | CHAR_VAL_FK4 | VARCHAR2 | 200 |
F1_ACTION_METHOD_CHAR | CHAR_VAL_FK5 | VARCHAR2 | 200 |
F1_ACTION_METHOD_CHAR | SEQ_NUM | NUMBER | 22 |
F1_ACTION_METHOD_CHAR | SRCH_CHAR_VAL | VARCHAR2 | 200 |
F1_ACTION_METHOD_CHAR | VERSION | NUMBER | 22 |
F1_ACTION_METHOD_L | ACTION_METHOD_CD | VARCHAR2 | 120 |
F1_ACTION_METHOD_L | DESCR100 | VARCHAR2 | 400 |
F1_ACTION_METHOD_L | DESCRLONG | VARCHAR2 | 16000 |
F1_ACTION_METHOD_L | LANGUAGE_CD | CHAR | 12 |
F1_ACTION_METHOD_L | VERSION | NUMBER | 22 |
F1_ARC_TBL_PARTITION_HIST | ACTUAL_DROP_DTTM | DATE | 7 |
F1_ARC_TBL_PARTITION_HIST | APPROVAL_DROP_DTTM | DATE | 7 |
F1_ARC_TBL_PARTITION_HIST | APPROVAL_USER_ID | CHAR | 32 |
F1_ARC_TBL_PARTITION_HIST | ARCHIVE_DTTM | DATE | 7 |
F1_ARC_TBL_PARTITION_HIST | ARCHIVE_FILE_NAME | VARCHAR2 | 512 |
F1_ARC_TBL_PARTITION_HIST | ARCHIVE_METHOD_FLG | CHAR | 16 |
F1_ARC_TBL_PARTITION_HIST | CRE_DTTM | DATE | 7 |
F1_ARC_TBL_PARTITION_HIST | DROP_APPROVAL_FLG | CHAR | 16 |
F1_ARC_TBL_PARTITION_HIST | DROP_PART_STAT_FLG | CHAR | 16 |
F1_ARC_TBL_PARTITION_HIST | ESTIMATED_SIZE_GB | NUMBER | 22 |
F1_ARC_TBL_PARTITION_HIST | PARTITION_MON | VARCHAR2 | 12 |
F1_ARC_TBL_PARTITION_HIST | PARTITION_YEAR | NUMBER | 22 |
F1_ARC_TBL_PARTITION_HIST | PART_OR_SUBPART_NAME | VARCHAR2 | 512 |
F1_ARC_TBL_PARTITION_HIST | REPEAT_DTTM | DATE | 7 |
F1_ARC_TBL_PARTITION_HIST | REPEAT_FLG | CHAR | 16 |
F1_ARC_TBL_PARTITION_HIST | REPEAT_USER_ID | CHAR | 32 |
F1_ARC_TBL_PARTITION_HIST | RETENTION_OR_SUBRET_DAYS | NUMBER | 22 |
F1_ARC_TBL_PARTITION_HIST | SCHED_DROP_DTTM | DATE | 7 |
F1_ARC_TBL_PARTITION_HIST | TBL_NAME | CHAR | 120 |
F1_ARC_TBL_PARTITION_HIST | TBL_OWNER | VARCHAR2 | 512 |
F1_ATTACHMENT | ATTCH_CONT_LOC_FLG | CHAR | 16 |
F1_ATTACHMENT | ATTCH_FILE_REF | VARCHAR2 | 8000 |
F1_ATTACHMENT_DATA | ATTACHMENT_ID | CHAR | 56 |
F1_ATTACHMENT_DATA | ATTCH_DATA_USAGE_FLG | CHAR | 16 |
F1_ATTACHMENT_DATA | ATTCH_FILE_DETAILS | CLOB | 4000 |
F1_ATTACHMENT_DATA | SEQNO | NUMBER | 22 |
F1_BATCH_CONF_VW | AVG_ELAPSED | NUMBER | 22 |
F1_BATCH_CONF_VW | BATCH_CD | CHAR | 32 |
F1_BATCH_CONF_VW | BATCH_PERF_COUNT | NUMBER | 22 |
F1_BATCH_CONF_VW | BEST_ELAPSED | NUMBER | 22 |
F1_BATCH_CONF_VW | CONFIDENCE | NUMBER | 22 |
F1_BATCH_CONF_VW | MED_ELAPSED | NUMBER | 22 |
F1_BATCH_CONF_VW | SAMPLE_SIZE | NUMBER | 22 |
F1_BATCH_CONF_VW | STD_DEVIATION | NUMBER | 22 |
F1_BATCH_CONF_VW | WORST_ELAPSED | NUMBER | 22 |
F1_BATCH_RUN_ANALYTICS_SNAP | BATCH_BUS_DT | DATE | 7 |
F1_BATCH_RUN_ANALYTICS_SNAP | BATCH_CD | CHAR | 32 |
F1_BATCH_RUN_ANALYTICS_SNAP | BATCH_JOB_ID | CHAR | 56 |
F1_BATCH_RUN_ANALYTICS_SNAP | BATCH_JOB_STAT_FLG | CHAR | 8 |
F1_BATCH_RUN_ANALYTICS_SNAP | BATCH_NBR | NUMBER | 22 |
F1_BATCH_RUN_ANALYTICS_SNAP | BATCH_RERUN_NBR | NUMBER | 22 |
F1_BATCH_RUN_ANALYTICS_SNAP | CRE_DTTM | DATE | 7 |
F1_BATCH_RUN_ANALYTICS_SNAP | DO_NOT_RESTART_SW | CHAR | 4 |
F1_BATCH_RUN_ANALYTICS_SNAP | ELAPSED_SECS | NUMBER | 22 |
F1_BATCH_RUN_ANALYTICS_SNAP | END_DTTM | DATE | 7 |
F1_BATCH_RUN_ANALYTICS_SNAP | PROCESS_DT | DATE | 7 |
F1_BATCH_RUN_ANALYTICS_SNAP | REC_ERR_CNT | NUMBER | 22 |
F1_BATCH_RUN_ANALYTICS_SNAP | REC_PROC_CNT | NUMBER | 22 |
F1_BATCH_RUN_ANALYTICS_SNAP | RUN_STATUS | CHAR | 8 |
F1_BATCH_RUN_ANALYTICS_SNAP | START_DTTM | DATE | 7 |
F1_BATCH_RUN_ANALYTICS_SNAP | SUBMIT_METH_FLG | CHAR | 16 |
F1_BATCH_RUN_ANALYTICS_SNAP | SUBMIT_USER_ID | CHAR | 32 |
F1_BATCH_RUN_ANALYTICS_SNAP | THREADPOOL | VARCHAR2 | 1016 |
F1_BATCH_RUN_ANALYTICS_SNAP | USER_ID | CHAR | 32 |
F1_BATCH_RUN_ANALYTICS_SNAP | VERSION | NUMBER | 22 |
F1_BATCH_RUN_HIST_VW | BATCH_BUS_DT | DATE | 7 |
F1_BATCH_RUN_HIST_VW | BATCH_CD | CHAR | 32 |
F1_BATCH_RUN_HIST_VW | BATCH_JOB_ID | CHAR | 56 |
F1_BATCH_RUN_HIST_VW | BATCH_NBR | NUMBER | 22 |
F1_BATCH_RUN_HIST_VW | BATCH_RERUN_NBR | NUMBER | 22 |
F1_BATCH_RUN_HIST_VW | BATCH_RUN_COUNT | NUMBER | 22 |
F1_BATCH_RUN_HIST_VW | DO_NOT_RESTART_SW | CHAR | 4 |
F1_BATCH_RUN_HIST_VW | ELAPSED_TIME | NUMBER | 22 |
F1_BATCH_RUN_HIST_VW | END_DTTM | DATE | 7 |
F1_BATCH_RUN_HIST_VW | PROCESS_DT | DATE | 7 |
F1_BATCH_RUN_HIST_VW | RUN_STATUS | CHAR | 8 |
F1_BATCH_RUN_HIST_VW | START_DTTM | DATE | 7 |
F1_BATCH_RUN_HIST_VW | SUBMIT_METH_FLG | CHAR | 16 |
F1_BATCH_RUN_HIST_VW | SUBMIT_USER_ID | CHAR | 32 |
F1_BATCH_RUN_HIST_VW | THREADPOOL | VARCHAR2 | 1016 |
F1_BATCH_RUN_HIST_VW | TOTAL_ERROR | NUMBER | 22 |
F1_BATCH_RUN_HIST_VW | TOTAL_PROCESSED | NUMBER | 22 |
F1_BATCH_RUN_HIST_VW | USER_ID | CHAR | 32 |
F1_BATCH_THD_ANALYTICS_SNAP | BATCH_BUS_DT | DATE | 7 |
F1_BATCH_THD_ANALYTICS_SNAP | BATCH_CD | CHAR | 32 |
F1_BATCH_THD_ANALYTICS_SNAP | BATCH_JOB_ID | CHAR | 56 |
F1_BATCH_THD_ANALYTICS_SNAP | BATCH_NBR | NUMBER | 22 |
F1_BATCH_THD_ANALYTICS_SNAP | BATCH_RERUN_NBR | NUMBER | 22 |
F1_BATCH_THD_ANALYTICS_SNAP | BATCH_THREAD_NBR | NUMBER | 22 |
F1_BATCH_THD_ANALYTICS_SNAP | CRE_DTTM | DATE | 7 |
F1_BATCH_THD_ANALYTICS_SNAP | END_DT | DATE | 7 |
F1_BATCH_THD_ANALYTICS_SNAP | END_DTTM | DATE | 7 |
F1_BATCH_THD_ANALYTICS_SNAP | REC_ERR_CNT | NUMBER | 22 |
F1_BATCH_THD_ANALYTICS_SNAP | REC_PROC_CNT | NUMBER | 22 |
F1_BATCH_THD_ANALYTICS_SNAP | RUN_STATUS | CHAR | 8 |
F1_BATCH_THD_ANALYTICS_SNAP | SCHEDULER_ID | NUMBER | 22 |
F1_BATCH_THD_ANALYTICS_SNAP | START_DT | DATE | 7 |
F1_BATCH_THD_ANALYTICS_SNAP | START_DTTM | DATE | 7 |
F1_BATCH_THD_ANALYTICS_SNAP | SUBMIT_METH_FLG | CHAR | 16 |
F1_BATCH_THD_ANALYTICS_SNAP | SUBMIT_USER_ID | CHAR | 32 |
F1_BATCH_THD_ANALYTICS_SNAP | THD_RETRY_CNT | NUMBER | 22 |
F1_BATCH_THD_ANALYTICS_SNAP | THREADPOOL | VARCHAR2 | 1016 |
F1_BATCH_THD_ANALYTICS_SNAP | THREAD_STATUS | CHAR | 8 |
F1_BATCH_THD_ANALYTICS_SNAP | VERSION | NUMBER | 22 |
F1_BATCH_THD_CAP_VW | BATCH_BUS_DT | DATE | 7 |
F1_BATCH_THD_CAP_VW | BATCH_CD | CHAR | 32 |
F1_BATCH_THD_CAP_VW | BATCH_JOB_ID | CHAR | 56 |
F1_BATCH_THD_CAP_VW | BATCH_NBR | NUMBER | 22 |
F1_BATCH_THD_CAP_VW | BATCH_RERUN_NBR | NUMBER | 22 |
F1_BATCH_THD_CAP_VW | BATCH_THREAD_CAP_COUNT | NUMBER | 22 |
F1_BATCH_THD_CAP_VW | BATCH_THREAD_NBR | NUMBER | 22 |
F1_BATCH_THD_CAP_VW | END_DT | DATE | 7 |
F1_BATCH_THD_CAP_VW | F1_MINUTE_IN_DAY | NUMBER | 22 |
F1_BATCH_THD_CAP_VW | F1_TIME_KEY | CHAR | 16 |
F1_BATCH_THD_CAP_VW | JOB_END_MINS | NUMBER | 22 |
F1_BATCH_THD_CAP_VW | JOB_START_MINS | NUMBER | 22 |
F1_BATCH_THD_CAP_VW | RUN_PROCESSING_DT | DATE | 7 |
F1_BATCH_THD_CAP_VW | START_DT | DATE | 7 |
F1_BATCH_THD_CAP_VW | SUBMIT_METH_FLG | CHAR | 16 |
F1_BATCH_THD_CAP_VW | SUBMIT_USER_ID | CHAR | 32 |
F1_BATCH_THD_CAP_VW | THREADPOOL | VARCHAR2 | 1016 |
F1_BATCH_THD_CAP_VW | THREAD_END_DTTM | DATE | 7 |
F1_BATCH_THD_CAP_VW | THREAD_START_DTTM | DATE | 7 |
F1_BATCH_THD_HIST_VW | BATCH_BUS_DT | DATE | 7 |
F1_BATCH_THD_HIST_VW | BATCH_CD | CHAR | 32 |
F1_BATCH_THD_HIST_VW | BATCH_JOB_ID | CHAR | 56 |
F1_BATCH_THD_HIST_VW | BATCH_NBR | NUMBER | 22 |
F1_BATCH_THD_HIST_VW | BATCH_RERUN_NBR | NUMBER | 22 |
F1_BATCH_THD_HIST_VW | BATCH_RUN_THD_COUNT | NUMBER | 22 |
F1_BATCH_THD_HIST_VW | BATCH_THREAD_NBR | NUMBER | 22 |
F1_BATCH_THD_HIST_VW | ELAPSED_TIME | NUMBER | 22 |
F1_BATCH_THD_HIST_VW | PROCESS_DT | DATE | 7 |
F1_BATCH_THD_HIST_VW | RECS_PER_MINUTE | NUMBER | 22 |
F1_BATCH_THD_HIST_VW | RETRY_COUNT | NUMBER | 22 |
F1_BATCH_THD_HIST_VW | RUN_STATUS | CHAR | 8 |
F1_BATCH_THD_HIST_VW | THREADPOOL | VARCHAR2 | 1016 |
F1_BATCH_THD_HIST_VW | THREAD_END_DTTM | DATE | 7 |
F1_BATCH_THD_HIST_VW | THREAD_START_DTTM | DATE | 7 |
F1_BATCH_THD_HIST_VW | THREAD_STATUS | CHAR | 8 |
F1_BATCH_THD_HIST_VW | TOTAL_ERROR | NUMBER | 22 |
F1_BATCH_THD_HIST_VW | TOTAL_PROCESSED | NUMBER | 22 |
F1_BATCH_VOL_VW | BATCH_CD | CHAR | 32 |
F1_BATCH_VOL_VW | BATCH_NBR | NUMBER | 22 |
F1_BATCH_VOL_VW | BATCH_RERUN_NBR | NUMBER | 22 |
F1_BATCH_VOL_VW | BATCH_THD_VOL_COUNT | NUMBER | 22 |
F1_BATCH_VOL_VW | MAX_PROCESSED | NUMBER | 22 |
F1_BATCH_VOL_VW | RECS_PER_MINUTE | NUMBER | 22 |
F1_BATCH_VOL_VW | TOTAL_PROCESSED | NUMBER | 22 |
F1_BUS_OBJ_STATUS_L | DESCR_OVRD | VARCHAR2 | 240 |
F1_BUS_OBJ_STATUS_RSN_L | DESCR_OVRD | VARCHAR2 | 240 |
F1_BUS_OBJ_STATUS_RSN_VW | BO_STATUS_REASON_CD | VARCHAR2 | 120 |
F1_BUS_OBJ_STATUS_RSN_VW | DESCR | VARCHAR2 | 240 |
F1_BUS_OBJ_STATUS_RSN_VW | DESCRLONG | VARCHAR2 | 16000 |
F1_BUS_OBJ_STATUS_RSN_VW | LANGUAGE_CD | CHAR | 12 |
F1_BUS_OBJ_STATUS_RSN_VW | OWNER_FLG | CHAR | 16 |
F1_BUS_OBJ_STATUS_RSN_VW | VERSION | NUMBER | 22 |
F1_BUS_OBJ_STATUS_VW | BO_STATUS_CD | CHAR | 48 |
F1_BUS_OBJ_STATUS_VW | BUS_OBJ_CD | CHAR | 120 |
F1_BUS_OBJ_STATUS_VW | DESCR | VARCHAR2 | 240 |
F1_BUS_OBJ_STATUS_VW | DESCRLONG | VARCHAR2 | 16000 |
F1_BUS_OBJ_STATUS_VW | LANGUAGE_CD | CHAR | 12 |
F1_BUS_OBJ_STATUS_VW | OWNER_FLG | CHAR | 16 |
F1_BUS_OBJ_STATUS_VW | VERSION | NUMBER | 22 |
F1_BUS_OBJ_TR_RULE_L | BO_NEXT_STATUS_OVRD_LBL | VARCHAR2 | 240 |
F1_CAL_FISC_PERIOD_D | F1_FISC_PERIOD_END_DT | DATE | 7 |
F1_CAL_FISC_PERIOD_D | F1_FISC_PERIOD_FLG | CHAR | 16 |
F1_CAL_FISC_PERIOD_D | F1_FISC_PERIOD_IN_QUARTER | NUMBER | 22 |
F1_CAL_FISC_PERIOD_D | F1_FISC_PERIOD_IN_YEAR | NUMBER | 22 |
F1_CAL_FISC_PERIOD_D | F1_FISC_PERIOD_KEY | NUMBER | 22 |
F1_CAL_FISC_PERIOD_D | F1_FISC_PERIOD_START_DT | DATE | 7 |
F1_CAL_FISC_PERIOD_D | F1_FISC_QUARTER_END_DT | DATE | 7 |
F1_CAL_FISC_PERIOD_D | F1_FISC_QUARTER_FLG | CHAR | 16 |
F1_CAL_FISC_PERIOD_D | F1_FISC_QUARTER_IN_YEAR | NUMBER | 22 |
F1_CAL_FISC_PERIOD_D | F1_FISC_QUARTER_KEY | NUMBER | 22 |
F1_CAL_FISC_PERIOD_D | F1_FISC_QUARTER_START_DT | DATE | 7 |
F1_CAL_FISC_PERIOD_D | F1_FISC_YEAR | NUMBER | 22 |
F1_CAL_FISC_PERIOD_D | F1_FISC_YEAR_END_DT | DATE | 7 |
F1_CAL_FISC_PERIOD_D | F1_FISC_YEAR_START_DT | DATE | 7 |
F1_CAL_FISC_QUARTER_D | F1_FISC_QUARTER_END_DT | DATE | 7 |
F1_CAL_FISC_QUARTER_D | F1_FISC_QUARTER_FLG | CHAR | 16 |
F1_CAL_FISC_QUARTER_D | F1_FISC_QUARTER_IN_YEAR | NUMBER | 22 |
F1_CAL_FISC_QUARTER_D | F1_FISC_QUARTER_KEY | NUMBER | 22 |
F1_CAL_FISC_QUARTER_D | F1_FISC_QUARTER_START_DT | DATE | 7 |
F1_CAL_FISC_QUARTER_D | F1_FISC_YEAR | NUMBER | 22 |
F1_CAL_FISC_QUARTER_D | F1_FISC_YEAR_END_DT | DATE | 7 |
F1_CAL_FISC_QUARTER_D | F1_FISC_YEAR_START_DT | DATE | 7 |
F1_CAL_FISC_YEAR_D | F1_FISC_YEAR | NUMBER | 22 |
F1_CAL_FISC_YEAR_D | F1_FISC_YEAR_END_DT | DATE | 7 |
F1_CAL_FISC_YEAR_D | F1_FISC_YEAR_START_DT | DATE | 7 |
F1_CAL_MONTH_D | F1MONTH_ABBR | CHAR | 16 |
F1_CAL_MONTH_D | F1_CAL_QUARTER_END_DT | DATE | 7 |
F1_CAL_MONTH_D | F1_CAL_QUARTER_FLG | CHAR | 16 |
F1_CAL_MONTH_D | F1_CAL_QUARTER_IN_YEAR | NUMBER | 22 |
F1_CAL_MONTH_D | F1_CAL_QUARTER_KEY | NUMBER | 22 |
F1_CAL_MONTH_D | F1_CAL_QUARTER_START_DT | DATE | 7 |
F1_CAL_MONTH_D | F1_CAL_YEAR | NUMBER | 22 |
F1_CAL_MONTH_D | F1_CAL_YEAR_END_DT | DATE | 7 |
F1_CAL_MONTH_D | F1_CAL_YEAR_NAME | CHAR | 16 |
F1_CAL_MONTH_D | F1_CAL_YEAR_START_DT | DATE | 7 |
F1_CAL_MONTH_D | F1_MONTH_END_DT | DATE | 7 |
F1_CAL_MONTH_D | F1_MONTH_IN_QUARTER | NUMBER | 22 |
F1_CAL_MONTH_D | F1_MONTH_IN_YEAR | NUMBER | 22 |
F1_CAL_MONTH_D | F1_MONTH_KEY | NUMBER | 22 |
F1_CAL_MONTH_D | F1_MONTH_START_DT | DATE | 7 |
F1_CAL_QUARTER_D | F1_CAL_QUARTER_END_DT | DATE | 7 |
F1_CAL_QUARTER_D | F1_CAL_QUARTER_FLG | CHAR | 16 |
F1_CAL_QUARTER_D | F1_CAL_QUARTER_IN_YEAR | NUMBER | 22 |
F1_CAL_QUARTER_D | F1_CAL_QUARTER_KEY | NUMBER | 22 |
F1_CAL_QUARTER_D | F1_CAL_QUARTER_START_DT | DATE | 7 |
F1_CAL_QUARTER_D | F1_CAL_YEAR | NUMBER | 22 |
F1_CAL_QUARTER_D | F1_CAL_YEAR_END_DT | DATE | 7 |
F1_CAL_QUARTER_D | F1_CAL_YEAR_NAME | CHAR | 16 |
F1_CAL_QUARTER_D | F1_CAL_YEAR_START_DT | DATE | 7 |
F1_CAL_WEEK_D | F1_WEEK_END_DT | DATE | 7 |
F1_CAL_WEEK_D | F1_WEEK_IN_YEAR | NUMBER | 22 |
F1_CAL_WEEK_D | F1_WEEK_KEY | NUMBER | 22 |
F1_CAL_WEEK_D | F1_WEEK_NAME | CHAR | 28 |
F1_CAL_WEEK_D | F1_WEEK_START_DT | DATE | 7 |
F1_CAL_YEAR_D | F1_CAL_YEAR | NUMBER | 22 |
F1_CAL_YEAR_D | F1_CAL_YEAR_END_DT | DATE | 7 |
F1_CAL_YEAR_D | F1_CAL_YEAR_NAME | CHAR | 16 |
F1_CAL_YEAR_D | F1_CAL_YEAR_START_DT | DATE | 7 |
F1_COLOR_OPT | BACKGROUND_COLOR_XFLG | VARCHAR2 | 120 |
F1_COLOR_OPT | BO_XML_DATA_AREA | XMLTYPE | 2000 |
F1_COLOR_OPT | BUS_OBJ_CD | CHAR | 120 |
F1_COLOR_OPT | COLOR_OPT_CD | VARCHAR2 | 120 |
F1_COLOR_OPT | COLOR_OPT_CLASS_FLG | CHAR | 16 |
F1_COLOR_OPT | FOREGROUND_COLOR_XFLG | VARCHAR2 | 120 |
F1_COLOR_OPT | OWNER_FLG | CHAR | 16 |
F1_COLOR_OPT | VERSION | NUMBER | 22 |
F1_COLOR_OPT_ITEM | COLOR_OPT_CD | VARCHAR2 | 120 |
F1_COLOR_OPT_ITEM | ITEM_BACKGROUND_COLOR_XFLG | VARCHAR2 | 120 |
F1_COLOR_OPT_ITEM | ITEM_FOREGROUND_COLOR_XFLG | VARCHAR2 | 120 |
F1_COLOR_OPT_ITEM | OWNER_FLG | CHAR | 16 |
F1_COLOR_OPT_ITEM | SEQNO | NUMBER | 22 |
F1_COLOR_OPT_ITEM | VERSION | NUMBER | 22 |
F1_COLOR_OPT_L | COLOR_OPT_CD | VARCHAR2 | 120 |
F1_COLOR_OPT_L | DESCR100 | VARCHAR2 | 400 |
F1_COLOR_OPT_L | LANGUAGE_CD | CHAR | 12 |
F1_COLOR_OPT_L | OWNER_FLG | CHAR | 16 |
F1_COLOR_OPT_L | VERSION | NUMBER | 22 |
F1_CRYPTO_KEY | PUBLIC_KEY | VARCHAR2 | 32767 |
F1_CRYPTO_KEY_RING | KEY_RING_CAT_FLG | CHAR | 16 |
F1_CRYPTO_KEY_RING | OWNER_FLG | CHAR | 16 |
F1_CRYPTO_KEY_RING_L | OWNER_FLG | CHAR | 16 |
F1_DATA_EXPORT_CTRL | BUS_OBJ_CD | CHAR | 120 |
F1_DATA_EXPORT_CTRL | CRE_DTTM | DATE | 7 |
F1_DATA_EXPORT_CTRL | F1_DATA_EXPORT_CD | VARCHAR2 | 120 |
F1_DATA_EXPORT_CTRL | F1_DATA_EXPORT_CLS_FLG | CHAR | 16 |
F1_DATA_EXPORT_CTRL | F1_EXPORT_THRU_DTTM | DATE | 7 |
F1_DATA_EXPORT_CTRL | F1_INIT_EXPORT_FLG | CHAR | 16 |
F1_DATA_EXPORT_CTRL | F1_ONGEXP_STATUS_FLG | CHAR | 16 |
F1_DATA_EXPORT_CTRL | MAINT_OBJ_CD | CHAR | 48 |
F1_DATA_EXPORT_CTRL | VERSION | NUMBER | 22 |
F1_DATA_EXPORT_CTRL_LOG | ADHOC_CHAR_VAL | VARCHAR2 | 1016 |
F1_DATA_EXPORT_CTRL_LOG | CHAR_TYPE_CD | CHAR | 32 |
F1_DATA_EXPORT_CTRL_LOG | CHAR_VAL | CHAR | 64 |
F1_DATA_EXPORT_CTRL_LOG | CHAR_VAL_FK1 | VARCHAR2 | 200 |
F1_DATA_EXPORT_CTRL_LOG | CHAR_VAL_FK2 | VARCHAR2 | 200 |
F1_DATA_EXPORT_CTRL_LOG | CHAR_VAL_FK3 | VARCHAR2 | 200 |
F1_DATA_EXPORT_CTRL_LOG | CHAR_VAL_FK4 | VARCHAR2 | 200 |
F1_DATA_EXPORT_CTRL_LOG | CHAR_VAL_FK5 | VARCHAR2 | 200 |
F1_DATA_EXPORT_CTRL_LOG | DESCRLONG | VARCHAR2 | 16000 |
F1_DATA_EXPORT_CTRL_LOG | F1_DATA_EXPORT_CD | VARCHAR2 | 120 |
F1_DATA_EXPORT_CTRL_LOG | LOG_DTTM | DATE | 7 |
F1_DATA_EXPORT_CTRL_LOG | LOG_ENTRY_TYPE_FLG | CHAR | 16 |
F1_DATA_EXPORT_CTRL_LOG | MESSAGE_CAT_NBR | NUMBER | 22 |
F1_DATA_EXPORT_CTRL_LOG | MESSAGE_NBR | NUMBER | 22 |
F1_DATA_EXPORT_CTRL_LOG | SEQNO | NUMBER | 22 |
F1_DATA_EXPORT_CTRL_LOG | USER_ID | CHAR | 32 |
F1_DATA_EXPORT_CTRL_LOG | VERSION | NUMBER | 22 |
F1_DATA_EXPORT_CTRL_LOG_PARM | F1_DATA_EXPORT_CD | VARCHAR2 | 120 |
F1_DATA_EXPORT_CTRL_LOG_PARM | MSG_PARM_TYP_FLG | CHAR | 16 |
F1_DATA_EXPORT_CTRL_LOG_PARM | MSG_PARM_VAL | VARCHAR2 | 8000 |
F1_DATA_EXPORT_CTRL_LOG_PARM | PARM_SEQ | NUMBER | 22 |
F1_DATA_EXPORT_CTRL_LOG_PARM | SEQNO | NUMBER | 22 |
F1_DATA_EXPORT_CTRL_LOG_PARM | VERSION | NUMBER | 22 |
F1_ETL_MP_CTRL | F1_BI_TYPE_FLD | CHAR | 120 |
F1_ETL_MP_CTRL | F1_BI_TYPE_VALUE | CHAR | 16 |
F1_EXTSYS_OUTMSG_PROF | OWNER_FLG | CHAR | 16 |
F1_FILE_INT_REC | BO_XML_DATA_AREA | XMLTYPE | 2000 |
F1_FILE_INT_REC | BUS_OBJ_CD | CHAR | 120 |
F1_FILE_INT_REC | DATA_AREA_CD | CHAR | 120 |
F1_FILE_INT_REC | FILE_INT_REC_CD | VARCHAR2 | 120 |
F1_FILE_INT_REC | FILE_INT_REC_STATUS_FLG | CHAR | 16 |
F1_FILE_INT_REC | FILE_INT_TYPE_CD | VARCHAR2 | 120 |
F1_FILE_INT_REC | OWNER_FLG | CHAR | 16 |
F1_FILE_INT_REC | PRNT_SEQ | NUMBER | 22 |
F1_FILE_INT_REC | ROOT_ELEM | VARCHAR2 | 400 |
F1_FILE_INT_REC | SEQNO | NUMBER | 22 |
F1_FILE_INT_REC | VERSION | NUMBER | 22 |
F1_FILE_INT_REC_ALG | ALG_CD | CHAR | 48 |
F1_FILE_INT_REC_ALG | FILE_INT_REC_CD | VARCHAR2 | 120 |
F1_FILE_INT_REC_ALG | FILE_INT_REC_SEVT_FLG | CHAR | 16 |
F1_FILE_INT_REC_ALG | FILE_INT_TYPE_CD | VARCHAR2 | 120 |
F1_FILE_INT_REC_ALG | OWNER_FLG | CHAR | 16 |
F1_FILE_INT_REC_ALG | SEQ_NUM | NUMBER | 22 |
F1_FILE_INT_REC_ALG | VERSION | NUMBER | 22 |
F1_FILE_INT_REC_L | DESCR100 | VARCHAR2 | 400 |
F1_FILE_INT_REC_L | DESCR4000 | VARCHAR2 | 16000 |
F1_FILE_INT_REC_L | FILE_INT_REC_CD | VARCHAR2 | 120 |
F1_FILE_INT_REC_L | FILE_INT_TYPE_CD | VARCHAR2 | 120 |
F1_FILE_INT_REC_L | LANGUAGE_CD | CHAR | 12 |
F1_FILE_INT_REC_L | OWNER_FLG | CHAR | 16 |
F1_FILE_INT_REC_L | VERSION | NUMBER | 22 |
F1_FILE_INT_TYPE | BO_XML_DATA_AREA | XMLTYPE | 2000 |
F1_FILE_INT_TYPE | BUS_OBJ_CD | CHAR | 120 |
F1_FILE_INT_TYPE | FILE_INT_CLASS_FLG | CHAR | 16 |
F1_FILE_INT_TYPE | FILE_INT_OBJ_FLG | CHAR | 16 |
F1_FILE_INT_TYPE | FILE_INT_STATUS_FLG | CHAR | 16 |
F1_FILE_INT_TYPE | FILE_INT_TYPE_CD | VARCHAR2 | 120 |
F1_FILE_INT_TYPE | OWNER_FLG | CHAR | 16 |
F1_FILE_INT_TYPE | VERSION | NUMBER | 22 |
F1_FILE_INT_TYPE_L | DESCR100 | VARCHAR2 | 400 |
F1_FILE_INT_TYPE_L | DESCR4000 | VARCHAR2 | 16000 |
F1_FILE_INT_TYPE_L | FILE_INT_TYPE_CD | VARCHAR2 | 120 |
F1_FILE_INT_TYPE_L | LANGUAGE_CD | CHAR | 12 |
F1_FILE_INT_TYPE_L | OWNER_FLG | CHAR | 16 |
F1_FILE_INT_TYPE_L | VERSION | NUMBER | 22 |
F1_INSIGHT_GRP | BO_XML_DATA_AREA | XMLTYPE | 2000 |
F1_INSIGHT_GRP | BUS_OBJ_CD | CHAR | 120 |
F1_INSIGHT_GRP | INSIGHT_CLASS_FLG | CHAR | 16 |
F1_INSIGHT_GRP | INSIGHT_GRP_CD | VARCHAR2 | 120 |
F1_INSIGHT_GRP | VERSION | NUMBER | 22 |
F1_INSIGHT_GRP_CHAR | ADHOC_CHAR_VAL | VARCHAR2 | 1016 |
F1_INSIGHT_GRP_CHAR | CHAR_TYPE_CD | CHAR | 32 |
F1_INSIGHT_GRP_CHAR | CHAR_VAL | CHAR | 64 |
F1_INSIGHT_GRP_CHAR | CHAR_VAL_FK1 | VARCHAR2 | 200 |
F1_INSIGHT_GRP_CHAR | CHAR_VAL_FK2 | VARCHAR2 | 200 |
F1_INSIGHT_GRP_CHAR | CHAR_VAL_FK3 | VARCHAR2 | 200 |
F1_INSIGHT_GRP_CHAR | CHAR_VAL_FK4 | VARCHAR2 | 200 |
F1_INSIGHT_GRP_CHAR | CHAR_VAL_FK5 | VARCHAR2 | 200 |
F1_INSIGHT_GRP_CHAR | INSIGHT_GRP_CD | VARCHAR2 | 120 |
F1_INSIGHT_GRP_CHAR | SEQ_NUM | NUMBER | 22 |
F1_INSIGHT_GRP_CHAR | SRCH_CHAR_VAL | VARCHAR2 | 200 |
F1_INSIGHT_GRP_CHAR | VERSION | NUMBER | 22 |
F1_INSIGHT_GRP_L | DESCR100 | VARCHAR2 | 400 |
F1_INSIGHT_GRP_L | DESCRLONG | VARCHAR2 | 16000 |
F1_INSIGHT_GRP_L | INSIGHT_GRP_CD | VARCHAR2 | 120 |
F1_INSIGHT_GRP_L | LANGUAGE_CD | CHAR | 12 |
F1_INSIGHT_GRP_L | VERSION | NUMBER | 22 |
F1_INSIGHT_GRP_TYPE | INSIGHT_GRP_CD | VARCHAR2 | 120 |
F1_INSIGHT_GRP_TYPE | INSIGHT_TYPE_CD | VARCHAR2 | 120 |
F1_INSIGHT_GRP_TYPE | SEQ_NUM | NUMBER | 22 |
F1_INSIGHT_GRP_TYPE | VERSION | NUMBER | 22 |
F1_INSIGHT_GRP_VISUAL_STR | INSIGHT_GRP_CD | VARCHAR2 | 120 |
F1_INSIGHT_GRP_VISUAL_STR | VERSION | NUMBER | 22 |
F1_INSIGHT_GRP_VISUAL_STR | VISUAL_STRUCTURE_FLG | CHAR | 16 |
F1_INSIGHT_TYPE | BO_XML_DATA_AREA | XMLTYPE | 2000 |
F1_INSIGHT_TYPE | BUS_OBJ_CD | CHAR | 120 |
F1_INSIGHT_TYPE | INSIGHT_ACT_TRACK_FLG | CHAR | 16 |
F1_INSIGHT_TYPE | INSIGHT_TYPE_CD | VARCHAR2 | 120 |
F1_INSIGHT_TYPE | OWNER_FLG | CHAR | 16 |
F1_INSIGHT_TYPE | VERSION | NUMBER | 22 |
F1_INSIGHT_TYPE | VISUAL_STRUCTURE_FLG | CHAR | 16 |
F1_INSIGHT_TYPE_ALG | ALG_CD | CHAR | 48 |
F1_INSIGHT_TYPE_ALG | INSIGHT_SEVT_FLG | CHAR | 16 |
F1_INSIGHT_TYPE_ALG | INSIGHT_TYPE_CD | VARCHAR2 | 120 |
F1_INSIGHT_TYPE_ALG | OWNER_FLG | CHAR | 16 |
F1_INSIGHT_TYPE_ALG | SEQ_NUM | NUMBER | 22 |
F1_INSIGHT_TYPE_ALG | VERSION | NUMBER | 22 |
F1_INSIGHT_TYPE_CHAR | ADHOC_CHAR_VAL | VARCHAR2 | 1016 |
F1_INSIGHT_TYPE_CHAR | CHAR_TYPE_CD | CHAR | 32 |
F1_INSIGHT_TYPE_CHAR | CHAR_VAL | CHAR | 64 |
F1_INSIGHT_TYPE_CHAR | CHAR_VAL_FK1 | VARCHAR2 | 200 |
F1_INSIGHT_TYPE_CHAR | CHAR_VAL_FK2 | VARCHAR2 | 200 |
F1_INSIGHT_TYPE_CHAR | CHAR_VAL_FK3 | VARCHAR2 | 200 |
F1_INSIGHT_TYPE_CHAR | CHAR_VAL_FK4 | VARCHAR2 | 200 |
F1_INSIGHT_TYPE_CHAR | CHAR_VAL_FK5 | VARCHAR2 | 200 |
F1_INSIGHT_TYPE_CHAR | INSIGHT_TYPE_CD | VARCHAR2 | 120 |
F1_INSIGHT_TYPE_CHAR | OWNER_FLG | CHAR | 16 |
F1_INSIGHT_TYPE_CHAR | SEQ_NUM | NUMBER | 22 |
F1_INSIGHT_TYPE_CHAR | SRCH_CHAR_VAL | VARCHAR2 | 200 |
F1_INSIGHT_TYPE_CHAR | VERSION | NUMBER | 22 |
F1_INSIGHT_TYPE_L | DESCR100 | VARCHAR2 | 400 |
F1_INSIGHT_TYPE_L | DESCRLONG | VARCHAR2 | 16000 |
F1_INSIGHT_TYPE_L | INSIGHT_TYPE_CD | VARCHAR2 | 120 |
F1_INSIGHT_TYPE_L | LANGUAGE_CD | CHAR | 12 |
F1_INSIGHT_TYPE_L | OWNER_FLG | CHAR | 16 |
F1_INSIGHT_TYPE_L | VERSION | NUMBER | 22 |
F1_INSIGHT_TYPE_USER_ACT | INSIGHT_ACT_CD | VARCHAR2 | 120 |
F1_INSIGHT_TYPE_USER_ACT | INSIGHT_ACT_CLASS_FLG | CHAR | 16 |
F1_INSIGHT_TYPE_USER_ACT | INSIGHT_ACT_DISP_TYPE | CHAR | 16 |
F1_INSIGHT_TYPE_USER_ACT | INSIGHT_ACT_FLD_FLG | CHAR | 16 |
F1_INSIGHT_TYPE_USER_ACT | INSIGHT_TYPE_CD | VARCHAR2 | 120 |
F1_INSIGHT_TYPE_USER_ACT | OWNER_FLG | CHAR | 16 |
F1_INSIGHT_TYPE_USER_ACT | SCR_CD | CHAR | 48 |
F1_INSIGHT_TYPE_USER_ACT | VERSION | NUMBER | 22 |
F1_INSIGHT_TYPE_USER_ACT_ALG | ALG_CD | CHAR | 48 |
F1_INSIGHT_TYPE_USER_ACT_ALG | INSIGHT_ACT_CD | VARCHAR2 | 120 |
F1_INSIGHT_TYPE_USER_ACT_ALG | INSIGHT_ACT_SEVT_FLG | CHAR | 16 |
F1_INSIGHT_TYPE_USER_ACT_ALG | INSIGHT_TYPE_CD | VARCHAR2 | 120 |
F1_INSIGHT_TYPE_USER_ACT_ALG | OWNER_FLG | CHAR | 16 |
F1_INSIGHT_TYPE_USER_ACT_ALG | SEQ_NUM | NUMBER | 22 |
F1_INSIGHT_TYPE_USER_ACT_ALG | VERSION | NUMBER | 22 |
F1_INSIGHT_TYPE_VISUAL_SETTING | DISP_ICON_CD | CHAR | 48 |
F1_INSIGHT_TYPE_VISUAL_SETTING | HEADER_CAT_FLG | CHAR | 16 |
F1_INSIGHT_TYPE_VISUAL_SETTING | HEADER_COLOR_OPT_CD | VARCHAR2 | 120 |
F1_INSIGHT_TYPE_VISUAL_SETTING | ICON_COLOR_OPT_CD | VARCHAR2 | 120 |
F1_INSIGHT_TYPE_VISUAL_SETTING | INSIGHT_COLOR_OPT_CD | VARCHAR2 | 120 |
F1_INSIGHT_TYPE_VISUAL_SETTING | INSIGHT_TYPE_CD | VARCHAR2 | 120 |
F1_INSIGHT_TYPE_VISUAL_SETTING | OWNER_FLG | CHAR | 16 |
F1_INSIGHT_TYPE_VISUAL_SETTING | SEQ_NUM | NUMBER | 22 |
F1_INSIGHT_TYPE_VISUAL_SETTING | SEVERITY_VAL | NUMBER | 22 |
F1_INSIGHT_TYPE_VISUAL_SETTING | VERSION | NUMBER | 22 |
F1_INSIGHT_TYPE_VISUAL_SETTING | VISUAL_SETTING_TYPE_FLG | CHAR | 16 |
F1_IWS_SVC | IWS_REST_VER_FLG | CHAR | 16 |
F1_IWS_SVC | PUBLISH_FLG | CHAR | 16 |
F1_IWS_SVC_FLDTEXT | EXAMPLE_TEXT | VARCHAR2 | 16000 |
F1_IWS_SVC_FLDTEXT | FLD_NAME | CHAR | 120 |
F1_IWS_SVC_FLDTEXT | IN_SVC_NAME | VARCHAR2 | 1016 |
F1_IWS_SVC_FLDTEXT | IWS_HELP_TEXT | VARCHAR2 | 16000 |
F1_IWS_SVC_FLDTEXT | OWNER_FLG | CHAR | 16 |
F1_IWS_SVC_FLDTEXT | TEXT_NAME | CHAR | 120 |
F1_IWS_SVC_FLDTEXT | VERSION | NUMBER | 22 |
F1_IWS_SVC_OPER | MAINT_OBJ_CD | CHAR | 48 |
F1_IWS_SVC_OPER | SEQ_NUM | NUMBER | 22 |
F1_IWS_SVC_OPER_L | DESCR | VARCHAR2 | 240 |
F1_IWS_SVC_OPER_L | DESCRLONG | VARCHAR2 | 16000 |
F1_IWS_SVC_OPER_L | IN_SVC_NAME | VARCHAR2 | 1016 |
F1_IWS_SVC_OPER_L | LANGUAGE_CD | CHAR | 12 |
F1_IWS_SVC_OPER_L | OPERATION_NAME | VARCHAR2 | 1016 |
F1_IWS_SVC_OPER_L | OWNER_FLG | CHAR | 16 |
F1_IWS_SVC_OPER_L | VERSION | NUMBER | 22 |
F1_IWS_SVC_OPER_OPT | IN_SVC_NAME | VARCHAR2 | 1016 |
F1_IWS_SVC_OPER_OPT | IWS_OPR_OPT_FLG | CHAR | 16 |
F1_IWS_SVC_OPER_OPT | IWS_OPR_OPT_VAL | VARCHAR2 | 32767 |
F1_IWS_SVC_OPER_OPT | OPERATION_NAME | VARCHAR2 | 1016 |
F1_IWS_SVC_OPER_OPT | OWNER_FLG | CHAR | 16 |
F1_IWS_SVC_OPER_OPT | SEQ_NUM | NUMBER | 22 |
F1_IWS_SVC_OPER_OPT | VERSION | NUMBER | 22 |
F1_IWS_SVC_SCHEMA | IN_SVC_NAME | VARCHAR2 | 1016 |
F1_IWS_SVC_SCHEMA | IWS_SCHEMA_DEFN | CLOB | 4000 |
F1_IWS_SVC_SCHEMA | IWS_SCHEMA_NAME | VARCHAR2 | 1016 |
F1_IWS_SVC_SCHEMA | IWS_SCHEMA_TYPE_FLG | CHAR | 16 |
F1_IWS_SVC_SCHEMA | OWNER_FLG | CHAR | 16 |
F1_IWS_SVC_SCHEMA | VERSION | NUMBER | 22 |
F1_LGCY_OBJ | CHANGE_REF_NAME | VARCHAR2 | 120 |
F1_LGCY_OBJ | LGCY_CAT_FLG | CHAR | 16 |
F1_MD_BI_TBL | BUS_OBJ_CD | CHAR | 120 |
F1_MD_BI_TBL | F1_BI_HIER_DEFN | VARCHAR2 | 32767 |
F1_MD_BI_TBL | F1_BI_NAME | VARCHAR2 | 400 |
F1_MD_BI_TBL | F1_BI_TABLE_TYPE_FLG | CHAR | 16 |
F1_MD_BI_TBL | F1_BI_TBL_NAME | CHAR | 120 |
F1_MD_BI_TBL | OWNER_FLG | CHAR | 16 |
F1_MD_BI_TBL | TBL_NAME | CHAR | 120 |
F1_MD_BI_TBL | VERSION | NUMBER | 22 |
F1_MD_BI_TBL_FLD | BI_ELEM_NAME | VARCHAR2 | 240 |
F1_MD_BI_TBL_FLD | F1_AGG_RULE_FLG | CHAR | 16 |
F1_MD_BI_TBL_FLD | F1_BI_FLD_TYPE_FLG | CHAR | 16 |
F1_MD_BI_TBL_FLD | F1_BI_TBL_NAME | CHAR | 120 |
F1_MD_BI_TBL_FLD | F1_BUCKET_BO | VARCHAR2 | 120 |
F1_MD_BI_TBL_FLD | F1_CALC_EXP | VARCHAR2 | 16000 |
F1_MD_BI_TBL_FLD | F1_DEGENERATE_SW | CHAR | 4 |
F1_MD_BI_TBL_FLD | F1_DISP_SEQ_NUM | NUMBER | 22 |
F1_MD_BI_TBL_FLD | F1_HIDE_TIME_SW | CHAR | 4 |
F1_MD_BI_TBL_FLD | F1_INTERNAL_SW | CHAR | 4 |
F1_MD_BI_TBL_FLD | F1_PROC_OPT_FLG | CHAR | 16 |
F1_MD_BI_TBL_FLD | FLD_NAME | CHAR | 120 |
F1_MD_BI_TBL_FLD | LOGICAL_DM_NAME | VARCHAR2 | 240 |
F1_MD_BI_TBL_FLD | OVRD_FLD_NAME | CHAR | 120 |
F1_MD_BI_TBL_FLD | OWNER_FLG | CHAR | 16 |
F1_MD_BI_TBL_FLD | SEQ_NUM | NUMBER | 22 |
F1_MD_BI_TBL_FLD | VERSION | NUMBER | 22 |
F1_MD_BI_TBL_L | DESCR100 | VARCHAR2 | 400 |
F1_MD_BI_TBL_L | DESCRLONG | VARCHAR2 | 16000 |
F1_MD_BI_TBL_L | F1_BI_TBL_NAME | CHAR | 120 |
F1_MD_BI_TBL_L | LANGUAGE_CD | CHAR | 12 |
F1_MD_BI_TBL_L | OWNER_FLG | CHAR | 16 |
F1_MD_BI_TBL_L | VERSION | NUMBER | 22 |
F1_MENU_APP_SVCS_VW | APP_SVC_ID | CHAR | 80 |
F1_MENU_APP_SVCS_VW | LINE_VISIBILITY_SW | CHAR | 4 |
F1_MENU_APP_SVCS_VW | MENU_LINE_ID | CHAR | 40 |
F1_MIGR_DATA_ST | BULK_IMPORT_FLG | CHAR | 16 |
F1_MIGR_DATA_ST | INSERT_ONLY_FLG | CHAR | 16 |
F1_MIGR_DATA_ST | MIGR_FILEVERSION | NUMBER | 22 |
F1_MIGR_DATA_ST | REDACT_OPT_FLG | CHAR | 16 |
F1_MIGR_DATA_ST_TBL | RECORD_COUNT | NUMBER | 22 |
F1_MIGR_OBJ | ENTITIES_CNT | NUMBER | 22 |
F1_MIGR_OBJ_DATA | MIGR_OBJ_ID | CHAR | 56 |
F1_MIGR_OBJ_DATA | SEQ_NUM | NUMBER | 22 |
F1_MIGR_OBJ_DATA | TBL_DATA | CLOB | 4000 |
F1_MIGR_OBJ_DATA | VERSION | NUMBER | 22 |
F1_MIGR_OBJ_SQL | PK_VALUE1 | VARCHAR2 | 1016 |
F1_MIGR_OBJ_SQL | PK_VALUE2 | VARCHAR2 | 1016 |
F1_MIGR_OBJ_SQL | PK_VALUE3 | VARCHAR2 | 1016 |
F1_MIGR_OBJ_SQL | PK_VALUE4 | VARCHAR2 | 1016 |
F1_MIGR_OBJ_SQL | PK_VALUE5 | VARCHAR2 | 1016 |
F1_MIGR_REQ_INSTR | ENTITY_TAG | VARCHAR2 | 120 |
F1_MO_UPD | ENT_KEY_HASH | NUMBER | 22 |
F1_MO_UPD | MAINT_OBJ_CD | CHAR | 48 |
F1_MO_UPD | PK_VALUE1 | VARCHAR2 | 1016 |
F1_MO_UPD | PK_VALUE2 | VARCHAR2 | 1016 |
F1_MO_UPD | PK_VALUE3 | VARCHAR2 | 1016 |
F1_MO_UPD | PK_VALUE4 | VARCHAR2 | 1016 |
F1_MO_UPD | PK_VALUE5 | VARCHAR2 | 1016 |
F1_MO_UPD_BACKLOG | ENT_KEY_HASH | NUMBER | 22 |
F1_MO_UPD_BACKLOG | MAINT_OBJ_CD | CHAR | 48 |
F1_MO_UPD_BACKLOG | PK_VALUE1 | VARCHAR2 | 1016 |
F1_MO_UPD_BACKLOG | PK_VALUE2 | VARCHAR2 | 1016 |
F1_MO_UPD_BACKLOG | PK_VALUE3 | VARCHAR2 | 1016 |
F1_MO_UPD_BACKLOG | PK_VALUE4 | VARCHAR2 | 1016 |
F1_MO_UPD_BACKLOG | PK_VALUE5 | VARCHAR2 | 1016 |
F1_MO_UPD_BACKLOG | REC_ROW_ID | VARCHAR2 | 400 |
F1_MO_UPD_BACKUP | BATCH_CD | CHAR | 32 |
F1_MO_UPD_BACKUP | BATCH_NBR | NUMBER | 22 |
F1_MO_UPD_BACKUP | BATCH_THREAD_NBR | NUMBER | 22 |
F1_MO_UPD_BACKUP | CRE_DTTM | DATE | 7 |
F1_MO_UPD_BACKUP | EXPORTED_KEYS | CLOB | 4000 |
F1_MST_CONFIG | CONFIG_CLS_FLG | CHAR | 16 |
F1_MST_CONFIG | CONFIG_PART_NAME | VARCHAR2 | 1016 |
F1_MST_CONFIG_CHAR | ADHOC_CHAR_VAL | VARCHAR2 | 1016 |
F1_MST_CONFIG_CHAR | BUS_OBJ_CD | CHAR | 120 |
F1_MST_CONFIG_CHAR | CHAR_TYPE_CD | CHAR | 32 |
F1_MST_CONFIG_CHAR | CHAR_VAL | CHAR | 64 |
F1_MST_CONFIG_CHAR | CHAR_VAL_FK1 | VARCHAR2 | 200 |
F1_MST_CONFIG_CHAR | CHAR_VAL_FK2 | VARCHAR2 | 200 |
F1_MST_CONFIG_CHAR | CHAR_VAL_FK3 | VARCHAR2 | 200 |
F1_MST_CONFIG_CHAR | CHAR_VAL_FK4 | VARCHAR2 | 200 |
F1_MST_CONFIG_CHAR | CHAR_VAL_FK5 | VARCHAR2 | 200 |
F1_MST_CONFIG_CHAR | CONFIG_PART_NAME | VARCHAR2 | 1016 |
F1_MST_CONFIG_CHAR | SEQ_NUM | NUMBER | 22 |
F1_MST_CONFIG_CHAR | SRCH_CHAR_VAL | VARCHAR2 | 200 |
F1_MST_CONFIG_CHAR | VERSION | NUMBER | 22 |
F1_PATCH_DETAILS | APPL_VERSION | VARCHAR2 | 240 |
F1_PATCH_DETAILS | BASE_REF_ID | VARCHAR2 | 240 |
F1_PATCH_DETAILS | EXT_PATCH_REF_ID | VARCHAR2 | 240 |
F1_PATCH_DETAILS | PATCH_CATEGORY | VARCHAR2 | 1016 |
F1_PATCH_DETAILS | PATCH_COMP_XFLG | VARCHAR2 | 120 |
F1_PATCH_DETAILS | PATCH_COPY_FLG | CHAR | 16 |
F1_PATCH_DETAILS | PATCH_DESCR | VARCHAR2 | 1016 |
F1_PATCH_DETAILS | PATCH_ID | CHAR | 48 |
F1_PATCH_DETAILS | PATCH_INSTALL_DTTM | DATE | 7 |
F1_PATCH_DETAILS | PATCH_PROD_ID | VARCHAR2 | 120 |
F1_PATCH_DETAILS | PATCH_VERSION | VARCHAR2 | 240 |
F1_PATCH_DETAILS | RELATED_REF_ID | VARCHAR2 | 240 |
F1_PATCH_DETAILS | RELEASE_VER | VARCHAR2 | 400 |
F1_PATCH_DETAILS | VERSION | NUMBER | 22 |
F1_PROC_PANEL | UI_MAP_CD | CHAR | 120 |
F1_PROD_METRIC_SNPSHT | BO_STATUS_CD | CHAR | 48 |
F1_PROD_METRIC_SNPSHT | BO_XML_DATA_AREA | XMLTYPE | 2000 |
F1_PROD_METRIC_SNPSHT | BUS_OBJ_CD | CHAR | 120 |
F1_PROD_METRIC_SNPSHT | CRE_DTTM | DATE | 7 |
F1_PROD_METRIC_SNPSHT | METRIC_SNAPSHOT_ID | CHAR | 48 |
F1_PROD_METRIC_SNPSHT | PROD_METRIC_TYPE_CD | VARCHAR2 | 120 |
F1_PROD_METRIC_SNPSHT | SNAPSHOT_XML_DATA_AREA | XMLTYPE | 2000 |
F1_PROD_METRIC_SNPSHT | STATUS_UPD_DTTM | DATE | 7 |
F1_PROD_METRIC_SNPSHT | VERSION | NUMBER | 22 |
F1_PROD_METRIC_SNPSHT_K | ENV_ID | NUMBER | 22 |
F1_PROD_METRIC_SNPSHT_K | METRIC_SNAPSHOT_ID | CHAR | 48 |
F1_PROD_METRIC_SNPSHT_VAL | EXT_PROD_METRIC | CHAR | 144 |
F1_PROD_METRIC_SNPSHT_VAL | METRIC_SNAPSHOT_ID | CHAR | 48 |
F1_PROD_METRIC_SNPSHT_VAL | METRIC_VALUE | VARCHAR2 | 1016 |
F1_PROD_METRIC_SNPSHT_VAL | VERSION | NUMBER | 22 |
F1_PROD_METRIC_TYPE | BO_STATUS_CD | CHAR | 48 |
F1_PROD_METRIC_TYPE | BO_XML_DATA_AREA | XMLTYPE | 2000 |
F1_PROD_METRIC_TYPE | BUS_OBJ_CD | CHAR | 120 |
F1_PROD_METRIC_TYPE | OWNER_FLG | CHAR | 16 |
F1_PROD_METRIC_TYPE | PROD_METRIC_TYPE_CD | VARCHAR2 | 120 |
F1_PROD_METRIC_TYPE | PROD_OFFERINGS | VARCHAR2 | 400 |
F1_PROD_METRIC_TYPE | SNAPSHOT_BO_CD | CHAR | 120 |
F1_PROD_METRIC_TYPE | VERSION | NUMBER | 22 |
F1_PROD_METRIC_TYPE_L | DESCR100 | VARCHAR2 | 400 |
F1_PROD_METRIC_TYPE_L | DESCRLONG | VARCHAR2 | 16000 |
F1_PROD_METRIC_TYPE_L | LANGUAGE_CD | CHAR | 12 |
F1_PROD_METRIC_TYPE_L | OWNER_FLG | CHAR | 16 |
F1_PROD_METRIC_TYPE_L | PROD_METRIC_TYPE_CD | VARCHAR2 | 120 |
F1_PROD_METRIC_TYPE_L | VERSION | NUMBER | 22 |
F1_REDACTION_RULE | BUS_OBJ_CD | CHAR | 120 |
F1_REDACTION_RULE | FLD_NAME | CHAR | 120 |
F1_REDACTION_RULE | REDACT_FILTER_EXP | VARCHAR2 | 8000 |
F1_REDACTION_RULE | REDACT_FUNC_XFLG | VARCHAR2 | 120 |
F1_REDACTION_RULE | REDACT_REF_FLD | CHAR | 120 |
F1_REDACTION_RULE | REDACT_RULE_CD | VARCHAR2 | 120 |
F1_REDACTION_RULE | REDACT_SRC_TYPE_FLG | CHAR | 16 |
F1_REDACTION_RULE | REDACT_XPATH_EXP | VARCHAR2 | 8000 |
F1_REDACTION_RULE | TBL_NAME | CHAR | 120 |
F1_REDACTION_RULE | VERSION | NUMBER | 22 |
F1_REDACTION_RULE_L | DESCR100 | VARCHAR2 | 400 |
F1_REDACTION_RULE_L | LANGUAGE_CD | CHAR | 12 |
F1_REDACTION_RULE_L | REDACT_RULE_CD | VARCHAR2 | 120 |
F1_REDACTION_RULE_L | VERSION | NUMBER | 22 |
F1_REQ_TYPE | OWNER_FLG | CHAR | 16 |
F1_REQ_TYPE_L | OWNER_FLG | CHAR | 16 |
F1_SIBSCH_TBLS_VW | SYSTEM_TBL_SW | CHAR | 4 |
F1_SIBSCH_TBLS_VW | TBL_NAME | CHAR | 120 |
F1_TAG | BO_DATA_AREA | CLOB | 4000 |
F1_TAG | BUS_OBJ_CD | CHAR | 120 |
F1_TAG | ENTITY_TAG | VARCHAR2 | 120 |
F1_TAG | ENTITY_TAG_CLASS_FLG | CHAR | 16 |
F1_TAG | MAINT_OBJ_CD | CHAR | 48 |
F1_TAG | OWNER_FLG | CHAR | 16 |
F1_TAG | TAG_STATUS_FLG | CHAR | 16 |
F1_TAG | VERSION | NUMBER | 22 |
F1_TAGGED_ENTITY | ENTITY_TAG | VARCHAR2 | 120 |
F1_TAGGED_ENTITY | KEYS | VARCHAR2 | 800 |
F1_TAGGED_ENTITY | MAINT_OBJ_CD | CHAR | 48 |
F1_TAGGED_ENTITY | OWNER_FLG | CHAR | 16 |
F1_TAGGED_ENTITY | PK_VALUE1 | VARCHAR2 | 1016 |
F1_TAGGED_ENTITY | PK_VALUE2 | VARCHAR2 | 1016 |
F1_TAGGED_ENTITY | PK_VALUE3 | VARCHAR2 | 1016 |
F1_TAGGED_ENTITY | PK_VALUE4 | VARCHAR2 | 1016 |
F1_TAGGED_ENTITY | PK_VALUE5 | VARCHAR2 | 1016 |
F1_TAGGED_ENTITY | REFERENCE_NAME | VARCHAR2 | 240 |
F1_TAGGED_ENTITY | VERSION | NUMBER | 22 |
F1_TAG_CHAR | ADHOC_CHAR_VAL | VARCHAR2 | 1016 |
F1_TAG_CHAR | CHAR_TYPE_CD | CHAR | 32 |
F1_TAG_CHAR | CHAR_VAL | CHAR | 64 |
F1_TAG_CHAR | CHAR_VAL_FK1 | VARCHAR2 | 200 |
F1_TAG_CHAR | CHAR_VAL_FK2 | VARCHAR2 | 200 |
F1_TAG_CHAR | CHAR_VAL_FK3 | VARCHAR2 | 200 |
F1_TAG_CHAR | CHAR_VAL_FK4 | VARCHAR2 | 200 |
F1_TAG_CHAR | CHAR_VAL_FK5 | VARCHAR2 | 200 |
F1_TAG_CHAR | ENTITY_TAG | VARCHAR2 | 120 |
F1_TAG_CHAR | OWNER_FLG | CHAR | 16 |
F1_TAG_CHAR | SEQ_NUM | NUMBER | 22 |
F1_TAG_CHAR | SRCH_CHAR_VAL | VARCHAR2 | 200 |
F1_TAG_CHAR | VERSION | NUMBER | 22 |
F1_TAG_L | DESCR100 | VARCHAR2 | 400 |
F1_TAG_L | DESCRLONG | VARCHAR2 | 16000 |
F1_TAG_L | ENTITY_TAG | VARCHAR2 | 120 |
F1_TAG_L | LANGUAGE_CD | CHAR | 12 |
F1_TAG_L | OWNER_FLG | CHAR | 16 |
F1_TAG_L | VERSION | NUMBER | 22 |
F1_TREE | APPLY_HEADER_STYLE_FLG | CHAR | 16 |
F1_TREE | BUS_OBJ_CD | CHAR | 120 |
F1_TREE | OWNER_FLG | CHAR | 16 |
F1_TREE | TREE_CD | CHAR | 120 |
F1_TREE | VERSION | NUMBER | 22 |
F1_TREE_L | DESCR100 | VARCHAR2 | 400 |
F1_TREE_L | LANGUAGE_CD | CHAR | 12 |
F1_TREE_L | OWNER_FLG | CHAR | 16 |
F1_TREE_L | TREE_CD | CHAR | 120 |
F1_TREE_L | VERSION | NUMBER | 22 |
F1_TREE_NODE | BROADCAST_NODE_FLG | CHAR | 16 |
F1_TREE_NODE | CONTEXT_MENU_NAME | CHAR | 120 |
F1_TREE_NODE | CTXT_MENU_USAGE_FLG | CHAR | 16 |
F1_TREE_NODE | DISP_ICON_CD | CHAR | 48 |
F1_TREE_NODE | INITIALLY_EXPAND_FLG | CHAR | 16 |
F1_TREE_NODE | NODE_NAME | CHAR | 120 |
F1_TREE_NODE | NODE_NAVIGATION_FLG | CHAR | 16 |
F1_TREE_NODE | NODE_TEXT_FORMAT | VARCHAR2 | 8000 |
F1_TREE_NODE | NODE_TEXT_LABEL | CHAR | 120 |
F1_TREE_NODE | OWNER_FLG | CHAR | 16 |
F1_TREE_NODE | PARENT_NODE_NAME | CHAR | 120 |
F1_TREE_NODE | SEQNO | NUMBER | 22 |
F1_TREE_NODE | TREE_CD | CHAR | 120 |
F1_TREE_NODE | VERSION | NUMBER | 22 |
F1_TREE_NODE_ALG | ALG_CD | CHAR | 48 |
F1_TREE_NODE_ALG | NODE_NAME | CHAR | 120 |
F1_TREE_NODE_ALG | OWNER_FLG | CHAR | 16 |
F1_TREE_NODE_ALG | SEQ_NUM | NUMBER | 22 |
F1_TREE_NODE_ALG | TREE_CD | CHAR | 120 |
F1_TREE_NODE_ALG | TREE_NODE_SEVT_FLG | CHAR | 16 |
F1_TREE_NODE_ALG | VERSION | NUMBER | 22 |
F1_TREE_NODE_L | DESCR100 | VARCHAR2 | 400 |
F1_TREE_NODE_L | LANGUAGE_CD | CHAR | 12 |
F1_TREE_NODE_L | NODE_NAME | CHAR | 120 |
F1_TREE_NODE_L | OWNER_FLG | CHAR | 16 |
F1_TREE_NODE_L | TREE_CD | CHAR | 120 |
F1_TREE_NODE_L | VERSION | NUMBER | 22 |
SC_APP_SERVICE_L | DESCRLONG | VARCHAR2 | 16000 |
SC_USER | DASHBOARD_LOC_FLG | CHAR | 16 |
SC_USER | DASHBOARD_STATE_FLG | CHAR | 16 |
SEC_INVENTORY | ENCRYPTED_BYTES | RAW | 2000 |
SEC_INVENTORY | ENCRYPTION_ALG | VARCHAR2 | 120 |
SEC_INVENTORY | ENC_KEY_NAME | VARCHAR2 | 800 |
SEC_INVENTORY | SALT | RAW | 2000 |
SEC_INVENTORY | SECRET_NAME | VARCHAR2 | 800 |
SEC_INVENTORY | VERIFICATION_HASH | RAW | 2000 |
SEC_INVENTORY | VERIFICATION_HASH_ALG | VARCHAR2 | 120 |
Table_Name | Column_Name | From | To |
CI_ALG_PARM | ALG_PARM_VAL | VARCHAR2 | 8000 |
CI_CNV_DUP_KEY | CX_ID | CHAR | 56 |
CI_CNV_KEY_TMP | CI_ID | CHAR | 56 |
CI_CNV_KEY_TMP | CX_ID | CHAR | 56 |
CI_CNV_KEY_TMP | INIT_ID | VARCHAR2 | 56 |
CI_ZONE_PRM | ZONE_PARM_VAL | VARCHAR2 | 16000 |
D1_ACTIVITY_ADJ_TYPE | BUS_OBJ_CD | CHAR | 120 |
D1_CONTACT_EMAIL | EMAIL_VALUE | VARCHAR2 | 280 |
D1_INBOUND_COMM_VW | D1_SP_ID | VARCHAR2 | 48 |
D1_INBOUND_COMM_VW | POSTAL | VARCHAR2 | 48 |
D1_OUTBOUND_COMM_VW | D1_SP_ID | VARCHAR2 | 48 |
D1_OUTBOUND_COMM_VW | POSTAL | VARCHAR2 | 48 |
F1_CRYPTO_KEY | PUBLIC_KEY | VARCHAR2 | 8000 |
F1_CRYPTO_KEY_RING_LINK | EXT_KEY_RING_CD | CHAR | 120 |
F1_CRYPTO_KEY_RING_LINK | INT_KEY_RING_CD | CHAR | 120 |
F1_CRYPTO_KEY_RING_LINK | VERSION | NUMBER | 22 |
F1_PROC_PANEL | UI_MAP_CD | VARCHAR2 | 120 |
