Application Framework Installation and Configuration Worksheets
During the installation and configuration of the application you will need to provide a variety of system values. These worksheets will assist you in providing that information. They should be completed before installing the application framework. No Customer Install Value fields should be left blank.
Note: Some web application server information will not be available until the software installation steps have been completed as described in the Installing Pre-requisite Software section in the Planning the Installation for prerequisite third-party software installation instructions.
Refer to the Server Administration Guide for additional details (default, valid values, usage, etc.), as applicable.
Menu Block 1: Environment ID, Roles, Third Party Software Configuration
The Environment ID, Roles, Third Party Software Configuration options include:
Menu Option
Name Used in Documentation
Environment ID
ENVIRONMENT_ID
Server Roles
SERVER_ROLES
Oracle Client Home Directory
ORACLE_CLIENT_HOME
Web Java Home Directory
JAVA_HOME
Hibernate JAR Directory
HIBERNATE_JAR_DIR
**ONS JAR Directory
ONS_JAR_DIR
Web Application Server Home Directory
WEB_SERVER_HOME
***Additional JAR Directory
WLTHINT3CLIENT_JAR_DIR
* Denotes optional menu items that may be required for the product installation and variables.
** To activate the RAC FCF, the application needs the external ons.jar file, from the ORACLE_HOME path:
$ORACLE_HOME/opmn/lib/ons.jar
During the installation the relevant option should be populated with the folder location of the ons.jar.
*** Refer to the Additional Prerequisite Software Information for more information.
Menu Block 2: Keystore Options
The keystore is a set of files used for encryption, decryption and hash generation. The files reside in the following location:
• <SPLEBASE>/ks/.ouaf_keystore
• <SPLEBASE>/ks/.ouaf_storepass
To run the application correctly, data encryption, decryption and hash generation of data in the database and on the application server must be performed using the same keystore; otherwise, the application will fail.
Starting Oracle Utilities Application Framework v4.4.0.0.0 the keystore and truststore options have been removed from the Menu and defaulted into the following template user exit, which is loaded by all properties files: templates/FW_spl.properties.keystore.truststore.include.
The user can still customize those options using the “Centralized Properties Customization”.
Upgrades from Oracle Utilities Application Framework versions below 4.4.0.0.0 will still use the keystore and truststore options recorded in the existing etc/ENVIRON.INI file (Menu options file).
Note: Populate the “Import Keystore Directory” option to import an existing keystore.
Keystore options include:
Menu Option
Customer
Install
Value
KS_IMPORT_KEYSTORE_FOLDER
Menu Block 50: Environment Installation Options
Environment installation options include:
Menu Option
Customer
Install
Value
Environment Mount Point
SPLDIR
Log File Mount Point
SPLDIROUT
Environment Name
SPLENVIRON
Installation Application Viewer Module
WEB_
ISAPPVIEWER
Install Demo Generation Cert Script
CERT_INSTALL_
SCRIPT
Install Sample CM Source Code
CM_INSTALL_
SAMPLE
Menu Block 1: Environment Description
The environment description menu option includes:
Menu Option
DESC
Menu Block 2: [WebLogic] Business Application Server Configuration
WebLogic Business Application Server configuration options include:
Menu Option
Business Server Host
BSN_WLHOST
Business Server Application Name
BSN_APP
Menu Block 3: [WebLogic] Web Application Server Configuration
WebLogic Web Application Server configuration options include:
Menu Option
Web Server Host
WEB_WLHOST
Weblogic SSL Port Number
WEB_WLSSLPORT
Weblogic Console Port Number
WLS_ADMIN_PORT
Web Context Root
WEB_CONTEXT_
ROOT
WebLogic JNDI User ID
WEB_WLSYSUSER
WebLogic JNDI Password
WEB_WLSYSPASS
WebLogic Server Name
WEB_WLS_
SVRNAME
Web Server Application Name
WEB_APP
Deploy Application Viewer Module
WEB_DEPLOY_
APPVIEWER
Enable The Unsecured Health Check Service
WEB_ENABLE_
HEALTHCHECK
MDB RunAs User ID
WEB_IWS_MDB_
RUNAS_USER
Super User Ids
WEB_IWS_SUPER_
USERS
Menu Block 4 - Database Configuration
The parameters below and in the worksheet are for the database configuration. Note that if changes are made to any of the database menu option items below, thus potentially connecting to a different schema, a warning will be displayed in the screen next to the actual option that has been changed.
Menu Option
Customer
Install
Value
Application Server Database User ID
DBUSER
Application Server Database Password
DBPASS
XAI Database User ID
XAI_DBUSER
XAI Database Password
XAI_DBPASS
Batch Database User ID
BATCH_DBUSER
Batch Database Password
BATCH_DBPASS
Web JDBC DataSource Name
JDBC_NAME
Database Name
DBNAME
Database Server
DBSERVER
Database Port
DBPORT
ONS Server Configuration
ONSCONFIG
Database Override Connection String
DB_OVERRIDE_
CONNECTION
Character Based Database
CHAR_BASED_DB
Oracle Client Character Set NLS_LANG
NLS_LANG
Menu Block 5 - General Configuration Options
The general configuration options include:
Menu Option
Customer
Install
Value
Batch RMI Port
BATCH_RMI_PORT
RMI Port number for JMX Business
BSN_JMX_RMI_PORT_
PERFORMANCE
RMI Port number for JMX Web
WEB_JMX_RMI_PORT_PERFORMANCE
JMX Enablement System User ID
BSN_JMX_SYSUSER
JMX Enablement System Password
BSN_JMX_SYSPASS
Coherence Cluster Name
COHERENCE_
CLUSTER_NAME
Coherence Cluster Address
COHERENCE_
CLUSTER_ADDRESS
Coherence Cluster Port
COHERENCE_
CLUSTER_PORT
Coherence Cluster Mode
COHERENCE_
CLUSTER_MODE
Menu Block 6 - OUAF TrustStore Options
The OUAF truststore configuration is required for IWS.
Menu Option
Customer
Install Value
Import TrustStore Directory
TS_IMPORT_KEYSTORE_FOLDER
Menu Block 8 - OSB Configuration
The OSB configuration includes:
Menu Option
Customer
Install Value
OSB Home
OSB Host Server
slc11cds.us.oracle.com
OSB Port Number
OSB SSL Port Number
OSB Managed Server Port Number
OSB Managed Server SSL Port Number
JDBC URL for Database
OSB Service Table Schema Name
OSB Service Table Schema Password
OSB WebLogic User Name
OSB WebLogic User Password
Mount Point for OSB Files
/spl/sploutput/osb
Menu Block 9 - SOA Configuration
The SOA configuration includes:
Menu Option
Customer
Install Value
SOA Home
SOA Host Server
SOA Port Number
SOA SSL Port Number
SOA Internal URL
SOA External URL
JDBC URL for SOA Database
SOA Service Table Schema Name
SOA Service Table Schema Password
SOA WebLogic User Name
SOA WebLogic User Password
Specify the Path for XAI/IWS Service
XAIApp/xaiservert
Menu Block 10 - SOA Configuration Plan (MDM)
The SOA configuration plan (MDF) includes:
Menu Option
Customer
Install Value
MDM Bulk Request Callback URL
MDM Headend HTTP Connection Timeout
50000
MDM Headend HTTP Read Timeout
500000
MDM SOA Request Queue JNDI Name
queue/BulkRequestQueue
MDM SOA Notify Queue JNDI Name
queue/BulkNotifyQueue
MDM SOA Command Queue JNDI Name
queue/BulkCommandQueue
SGG-NMS TestHarness Partition Name
SGG-NMS_Test
Menu Block 11 - Configuration for DataRaker Integration
The DataRaker Integration configuration includes:
Menu Option
Customer
Install Value
JNDI Name of Destination Queue to publish SGG payloads for DataRaker Integration Tool
DataRakerQueue
Number of records (SGG Payloads) to accumulate
100
Max file size for the accumulated (SGG Payloads) file in Kilobytes
524288
Specify a time which, when exceeded, causes a new outgoing file to be created in seconds
600
Polling frequency of Staging directory for new files in seconds
60
Mount point/directory for the accumulated SGG payload file
/spl/sploutput/staging
Mount Point/directory for the converted XML file to place for DataRaker
/spl/sploutput/int
Menu Block 16 - SOA Configuration Plan (LG)
The SOA configuration plan (LG) includes:
Menu Option
Customer
Install Value
LG SOA Partition Name
LG
LG SOA TestHarness Partition Name
LG_Test
AMI Event Subscriber Output Path
/spl/sploutput/osb/lg-cim-event
MR_Server endpoint URI
CD_Server endpoint URI
CIM_Server endpoint URI
MeteringServer endpoint URI
Security policy attached to outbound web service calls to a CIM interface
sgg/d3_cfs_cim_header_client_policy
Security policy attached to inbound web service calls from a CIM interface
sgg/d3_cim_token_service_policy
The name of the OWSM policy to use when SOA calls a head end system
oracle/http_basic_auth_over_ssl_client_policy
The name of the OWSM policy to use when SOA is called by a head end system
oracle/http_basic_auth_over_ssl_service_policy
Menu Block 17 - SOA Configuration Plan (NES)
The SOA configuration plan (NES) includes:
Menu Option
Customer
Install Value
NES endpoint URI
SOA partition to which the application is installed
Echelon
Path to the NES EventManager web service on the head end system
CoreServices/EventManager.asmx
Path to the NES GatewayManager web service
CoreServices/GatewayManager.asmx
Path to the NES DeviceManager web service on the head end system
CoreServices/DeviceManager.asmx
Path to the NES SettingManager web service on the head end system
CoreServices/SettingManager.asmx
Path to the NES UserManager web service on the head end system
CoreServices/UserManager.asmx
Name of the OWSM policy to use when SOA calls a head end system
Name of the OWSM policy to use when SOA is called by a head end system
Menu Block 18 - SOA Configuration Plan (Sensus)
The SOA configuration plan (Sensus) includes:
Menu Option
Customer
Install Value
Sensus SOA TestHarness Partition Name
Sensus_Test
Sensus SOA Partition Name
Sensus
MR Server Endpoint URI
CD Server Endpoint URI
OD Server Endpoint URI
Headend Http Read Timeout
500000
Headend Http Connection Timeout
50000
Menu Block 19 - SOA Configuration Plan (SSN)
Menu Option
Customer
Install Value
SSN SOA Partition Name
SSN
SOA Weblogic User Name
SSN SOA Queue JNDI Name
queue/SSNODRQ
SSN Headend DataAggregation Endpoint URI
The URL for the SSN 4.7 DataAggregation service (DataAggregation.asmx)
http://127.0.0.1/CoreServices/DataAggregation.asmx
The URL for the SSN 4.10 DataAggregation service
https://ssn.ssnsgs.net:3000/amm/webservice/v2_1/DataAggregat...
The url for the SSN 4.14 DataAggregation service
https://ssn.ssnsgs.net:3000/amm/webservice/v2_5_1/DataAggregationPort
The url for the SSN 5.1 DataAggregation service
https://ssn.ssnsgs.net:3000/amm/webservice/v2_7/DataAggregationPort
SSN Headend DeviceManager Endpoint URI
The URL for the SSN 4.7 DeviceManager service (DeviceManager.asmx)
http://127.0.0.1/CoreServices/DeviceManager.asmx
The URL for the SSN 4.10 DeviceManager service
https://ssn.ssnsgs.net:3000/amm/webservice/v2_1/DeviceManage...
The url for the SSN 4.14 DeviceManager service
https://ssn.ssnsgs.net:3000/amm/webservice/v2_5_1/DeviceManagerPort
The url for the SSN 5.1 DeviceManager service
https://ssn.ssnsgs.net:3000/amm/webservice/v2_7/DeviceManagerPort
SSN Headend DeviceResults Endpoint URI
The URL for the SSN 4.7 DeviceResults service (DeviceResults.asmx)
http://127.0.0.1/CoreServices/DeviceResults.asmx
The URL for the SSN 4.10 DeviceResults service
https://ssn.ssnsgs.net:3000/amm/webservice/v2_1/DeviceResult...
The url for the SSN 4.14 DeviceResults service
https://ssn.ssnsgs.net:3000/amm/webservice/v2_5_1/DeviceResults
The url for the SSN 5.1 DeviceResults service
https://ssn.ssnsgs.net:3000/amm/webservice/v2_7/DeviceResults
SSN Headend JobManager Endpoint URI
The URL for the SSN 4.7 JobManager service (JobManager.asmx)
http://127.0.0.1/CoreServices/JobManager.asmx
The URL for the SSN 4.10 JobManager service:
https://ssn.ssnsgs.net:3000/amm/webservice/v2_1/JobManagerPo...
The url for the SSN 4.14 JobManager service
https://ssn.ssnsgs.net:3000/amm/webservice/v2_5_1/JobManagerPort
The url for the SSN 5.1 JobManager service
https://ssn.ssnsgs.net:3000/amm/webservice/v2_7/JobManagerPort
Menu Block 20 - SSN JMS Source Destination Bridge Configuration
The SSN JMS Source Destination Bridge configuration includes:
Menu Option
Customer
Install Value
SSN Bridge Destination Name
SSNTestHarnessBridgeDestination
SSN Bridge Destination Additional Classpath
SSN Bridge Destination Connection URL
SSN Bridge Destination Initial Context Factory
weblogic.jndi.WLInitialContextFactory
SSN Bridge Connection Factory JNDI Name
jms/SSNTestHarnessConnectionFactory
SSN Bridge Destination Queue JNDI Name
queue/SSNTestSSNODRQ
SSN Destination Bridge Username
Menu Block 21 - DG Reference Implementation SOA Configuration
The DG Reference Implementation SOA configuration includes:
Menu Option
Customer
Install Value
DG SOA Partition Name
DG
500000
50000
DG SOA TestHarness Partition Name
DG_Test
Menu Block 22 - SOA Configuration Plan (Itron Openway)
The SOA Configuration Plan (Itron Openway) configuration includes:
Menu Option
Customer
Install Value
Itron SOA Partition Name
Itron
500000
50000
DataSubscriberService Output Path
ExceptionSubscriberService Output Path
Itron Headend DataService Endpoint URI
Itron Headend DiagnosticService Endpoint URI
Itron Headend UtilService Endpoint URI
Itron Headend ControlService Endpoint URI
Itron Headend ProvisioningService Endpoint URI
Itron Headend ProvisioningService370 Endpoint URI
Itron Headend ControlService370 Endpoint URI:
Itron SOA TestHarness Partition Name
Itron_Test
Advanced Menu Options
The advanced menu options are not available during installation. These options can be accessed after installation using the following commands:
Linux/UNIX:
$SPLEBASE/bin/configureEnv.sh -a
Windows:
%SPLEBASE%\bin\configureEnv.cmd -a
Menu Block 50 - WebLogic Advanced Environment Miscellaneous Configuration
WebLogic advanced environment miscellaneous configurations include:
Menu Option
Customer
Value
Install
OUAF DBMS Scheduler User
OUAF_DBMS_SCHEDULER_USER
Enter the location of the Application Server Profile Home
WAS_PROFILE_NAME_HOME
WebLogic ThreadPoolWorker Enabled
WLS_THEADPOOLWORKERENABLED
Online JVM Batch Server Enabled
BATCHENABLED
Online JVM Batch Number of Threads
BATCHTHREADS
Online JVM Batch Scheduler Daemon Enabled
BATCHDAEMON
Enable Batch Edit Functionality
BATCHEDIT_
ENABLED
Batch Online Log Directory
BATCH_ONLINE_LOG_DIR
JDBC Read Timeout
JDBC_TIMEOUT
Enable JMS Global Flush for Batch
ENABLE_JMS_GLOBAL_FLUSH
Add UsernameToken.xml
ADD_USERNAMETOKEN_XML
IWS deployment target
WLS_CLUSTER_NAME
Web Admin Server Host
WEB_ADMIN_SERVER
Split File Size in MB
TEMPSTORAGE_SPLITFILESIZE
GIS Service Running on the same Web Server
GIS
GIS Service URL
GIS_URL
GIS WebLogic System User ID
GIS_WLSYSUSER
GIS WebLogic System Password
GIS_WLSYSPASS
Online Display Software Home
ONLINE_DISPLAY_HOME
Max Queries To Hold In Cache Across All Threads
XQUERIES_TO_
CACHE
Seconds Timeout Flush Cache Completely
XQUERY_CACHE_
FLUSH_TIMEOUT
Menu Block 51 - WebLogic Advanced Environment Memory Configuration
WebLogic advanced environment memory configurations include:
Menu Option
Customer
Install
Value
Global JVM Arguments
GLOBAL_JVMARGS
Ant Min Heap Size
ANT_OPT_MIN
Ant Max Heap Size
ANT_OPT_MAX
Ant Additional Options
ANT_ADDITIONAL_OPT
Thread Pool Worker Java Min Heap Size
BATCH_MEMORY_OPT_MIN
Thread Pool Worker Java Max Heap Size
BATCH_MEMORY_OPT_MAX
Thread Pool Worker Additional Options
BATCH_MEMORY_
ADDITIONAL_OPT
Menu Block 52 - Advanced Web Application Configuration
Advanced web application configurations include:
Menu Option
Name Used in
Documentation
Customer
Install
Value
Deploy XAI Application Module
WEB_DEPLOY_XAIAPP
Web Application Cache Settings
WEB_L2_CACHE_MODE
Web Server Port Number
WEB_WLPORT
CSRF Protection For REST Services
CSRF_PROTECTION
OWSM Protection For REST Services
OWSM_PROTECTION_FOR_
REST_SERVICES
Domain Home Location
WLS_DOMAIN_HOME
Batch Cluster URL
WEB_BATCH_CLUSTER_URL
Strip HTML Comments
STRIP_HTML_COMMENTS
Authentication Login Page Type
WEB_WLAUTHMETHOD
Web Form Login Page
WEB_FORM_LOGIN_PAGE
Web Form Login Error Page
WEB_FORM_LOGIN_ERROR_
PAGE
Application Viewer Form Login Page
WEB_APPVIEWER_FORM_
LOGIN_PAGE
Application Viewer Form Login Error Page
WEB_APPVIEWER_FORM_
LOGIN_ERROR_PAGE
Help Form Login Page
WEB_HELP_FORM_LOGIN_
PAGE
Help Form Login Error Page
ERROR_PAGE
Web Security Role
WEB_SECURITY_NAME
Web Principal Name
WEB_PRINCIPAL_NAME
Application Viewer Security Role
WEB_APPVIEWER_ROLE_
NAME
Application Viewer Principal Name
WEB_APPVIEWER_PRINCIPAL_NAME
This is a development environment
WEB_ISDEVELOPMENT
Preload All Pages on Startup
WEB_PRELOADALL
Maximum Age of a Cache Entry for Text
WEB_MAXAGE
Maximum Age of a Cache Entry for Images
WEB_MAXAGEI
JSP Recompile Interval (s)
WEB_
WLPAGECHECKSECONDS
Enable Strict Transport Security
Strict Transport Security Max Age
HSTS_MAX_AGE
Strict Transport Security Include Subdomains
HSTS_SUBDOMAINS
Strict Transport Security Preload
HSTS_PRELOAD
User Interface Style
USER_INTERFACE_STYLE
Oracle Guided Learning Id
ORACLE_GUIDED_LEARNING_ID
Menu Block 54 - WebLogic Diagnostics
WebLogic diagnostic options include:
Menu Option
Customer
Install
Value
Diagnostic Context Enabled
WLS_DIAGNOSTIC_CONTEXT_ENABLED
Menu Block 55 - URI, File and URL Related Options
URI, File and URL Related Options include:
Menu Option
Customer
Install
Value
Enable CORS For Embedded UI
ENABLE_CORS
Source Origin for CORS Host
CORS_HOST
Source Origin for CORS Port
CORS_PORT
Source Origin for CORS Scheme
CORS_SCHEME
Restriction URIs Enable
CLOUD_RESTRICTION_URIS_
ENABLE
Custom SQL Security
CUSTOM_SQL_SECURITY
White List Full Path
CLOUD_WHITE_LIST_PATH
Custom White List Full Path
CLOUD_CUSTOM_WHITE_LIST_PATH
Substitution Variable List File Location
CLOUD_SUBSTITUTION_VARIABLE_LIST_FILE_LOCATION
Directory For Variable F1_CMA_FILES
CLOUD_LOCATION_
F1_MIGR_ASSISTANT_FILES
URI For Variable F1_OAUTH2_URI
CLOUD_LOCATION_F1_
OAUTH2_URI
URI for Variable F1_BASE_REST_URL
CLOUD_LOCATION_F1_BASE_REST_URL
URI for Variable F1_OPEN_API_BASE_URL
CLOUD_LOCATION_F1_OPEN_API_BASE_URL
URI For Variable F1_BASE_WEB_URI
CLOUD_LOCATION_F1_BASE_WEB_URI
URI For Variable F1_BASE_IWS_URI
CLOUD_LOCATION_F1_BASE_IWS_URI
Consolidated Logfile Full Path
CONSOLIDATED_LOG_FILE_PATH
Temporary File Location
TMP_FILE_LOCATION
Menu Block 56 - Mobile Security Configuration
Mobile Security configurations include:
Menu Option
Customer
Install
Value
Enable Mobile Application
MOBILE_ENABLED
Deploy Only Mobile Web Application
MOBILE_APP_ONLY
Mobile Application Directory
MOBILE_APPDIR
Allow Self Signed SSL Certificates
ALLOW_SELFSIGNED_SSL
Force Http Connection
FORCE_HTTP
Web Mobile Form Login Page
WEB_MOBILE_FORM_LOGIN_PAGE
Web Mobile Form Login Error Page
WEB_MOBILE_FORM_LOGIN_ERROR_PAGE
