Menu Option | Name Used In Documentation | Customer Install Value |
OSB Home | OSB_HOME | |
OSB Host Server | OSB_HOST | |
OSB Port Number: | OSB_PORT_NUMBER | |
OSB SSL Port Number | OSB_SSL_PORT | |
OSB Managed Server Port Number | OSB_MS_PORT_NUMBER | |
OSB Managed Server SSL Port Number | OSB_MS_SSL_PORT_NUMBER | |
JDBC URL for database | DBURL_OSB | |
OSB Service Table Schema Name | RCUSTBSCHEMA_OSB | |
OSB Service Table Schema Password | RCUSTBSCHEMAPWD_OSB | |
OSB WebLogic User Name | WEBLOGIC_USERNAME_OSB | |
OSB WebLogic User Password | WEBLOGIC_PASSWORD_OSB | |
Mount Point for OSB files | OSB_LOG_DIR |
Menu Option | Name Used in this Documentation | Customer Install Value |
SOA Home | SOA_HOME | |
SOA Host Server | SOA_HOST | |
SOA Port Number: | SOA_PORT_NUMBER | |
SOA SSL Port Number | SOA_SSL_PORT_NUMBER | |
SOA Internal URL | SOA_INTERNAL_URL | |
SOA External URL | SOA_EXTERNAL_URL | |
JDBC URL for database | DBURL_SOA | |
SOA Service table schema Name | RCUSTBSCHEMA_SOA | |
SOA Service table schema Password | RCUSTBSCHEMAPWD_SOA | |
SOA WebLogic User Name | WEBLOGIC_USERNAME_SOA | |
SOA WebLogic User Password | WEBLOGIC_PASSWORD_SOA | |
Specify the path for XAI/IWS Service | WEB_SERVICE_PATH |
MDF Bulk Request Callback URL | D1_BULK_REQUEST_ CALLBACK_URL | |
MDF Headend http connection timeout | D1_HEADEND_HTTP_CONN_ TIMEOUT | |
MDF Headend http read timeout | D1_HEADEND_HTTP_READ_ TIMEOUT | |
MDF SOA Request Queue JNDI Name | SOA_REQUEST_QUEUE_D1 | |
MDF SOA Notify Queue JNDI Name | SOA_NOTIFY_QUEUE_D1 | |
MDF SOA Command Queue JNDI Name | SOA_COMMAND_QUEUE_D1 | |
SGG-NMS TestHarness Partition Name | SOA_PARTITION_D1 |
Destination Queue to publish SGG payloads for DataRaker Integration Tool | SGG_DR_INT_QUEUE | |
Number of records (SGG Payloads) to accumulate | SOA_DR_PUBLISH_SIZE | |
Max file size for the accumulated (SGG Payloads) file in Kilobytes | SOA_DR_FILE_SIZE | |
Specify a time which, when exceeded, causes a new outgoing file to be created in seconds | SOA_DR_ELAPSED_TIME | |
Polling frequency of Staging directory for new files in seconds | SOA_DR_POLLING_FREQ | |
Mount point/directory for the accumulated SGG payload file | SOA_DR_STAGING_DIR | |
Mount Point/directory for the converted XML file to place for DataRaker | SOA_DR_INTEGRATION_DIR |
Enable OSB SSL Port | OSB_SSL | |
OSB Trust Keystore Type | OSB_TRUST_KS | |
OSB Trust Keystore File Type | OSB_TRUST_KS_TYPE | |
OSB Trust Keystore File | OSB_TRUST_KS_FILE |
SOA Initial Heap Size | SOA_MEMORY_OPT_MIN | |
SOA Maximum Heap Size | SOA_MEMORY_OPT_MAX | |
SOA Minimum Perm Size | SOA_MEMORY_OPT_MINPERMSIZE | |
SOA Maximum Perm Size | SOA_MEMORY_OPT_ MAXPERM SIZE | |
SOA Application Additional Options | SOA_JVM_ADDITIONAL_OPT | |
The name of the OWSM policy to use when SOA calls another SOA service | SOA_SOA_CLIENT_POLICY | |
The name of the OWSM policy to use when SOA is called by another SOA service | SOA_SOA_SERVICE_POLICY | |
The name of the OWSM policy to use when SOA calls an OUAF service | SOA_SOA_SERVICE_POLICY |
OSB Initial Heap Size | OSB_MEMORY_OPT_MIN | |
OSB Maximum Heap Size | OSB_MEMORY_OPT_MAX | |
OSB Minimum Perm Size | OSB_MEMORY_OPT_MINPERMSIZE | |
OSB Maximum Perm Size | OSB_MEMORY_OPT_MAXPERMSIZE | |
OSB Application Additional Options | OSB_JVM_ADDITIONAL_OPT |
Enable Data Migration | DATA_MIGRATION | |
Data Migration Database User | DATA_MIGRATION_DB_USER | |
Data Migration Database Password | DATA_MIGRATION_DB_PASS |
Enable SOA SSL Port | SOA_SSL | |
SOA Trust Keystore Type | SOA_TRUST_KS | |
SOA Trust Keystore File Type | SOA_TRUST_KS_ TYPE | |
SOA Trust Keystore File | SOA_TRUST_KS_ FILE |
SSN TestHarness SOA Host Server | SOA_HOST_TEST_D7 | |
SSN TestHarness SOA Port Number | SOA_PORT_NUMBER_D7 | |
SSN SOA TestHarness Partition Name | SOA_PARTITION_TEST_D7 | |
SSN SOA TestHarness Queue JNDI Name | SOA_QUEUE_TEST_D7 |
