Relationship Between 2.5.0.0.0 and Prior Versions
Version 2.5.0.0.0 supports the following upgrade paths:
• If you are installing Oracle Utilities Meter Data Management for the first time, you must install V2.5.0.0.0 available on Oracle Software Delivery Cloud.
• If you have Oracle Utilities Meter Data Management V2.1.0.2.0 or earlier installed, you must upgrade to:
V2.1.0.3.0 > V2.2.0.3.0 > V2.3.0.2.0 > V2.5.0.0.0
• If you have Oracle Utilities Meter Data Management V2.1.0.3.0 installed, upgrade to:
V2.2.0.3.0 directly > V2.3.0.2.0 > V2.5.0.0.0
• If you have Oracle Utilities Meter Data Management V2.2.0.1.0 or V2.2.0.2.0 installed, you must upgrade to:
• If you have Oracle Utilities Meter Data Management V2.2.0.3.0 or later installed, you must upgrade to V2.3.0.2.0, and then to V2.5.0.0.0.
