Secure Communications (SSL)
By default, Oracle Utilities Meter Data Management uses HTTPS to communicate to the browser and across the tiers. The transport protocol can be encrypted using SSL/TLS to secure transmission of data across networks.
Note: Oracle strongly recommends that customers use SSL to secure transmission for production environments.
To implement SSL the following process must be completed:
2. Set the SSL Port Number using the WEB_WLSSLPORT configuration parameter as outlined in the product Server Administration Guide.
3. Once the setup has been tested and verified refer to the console documentation on disabling insecure protocols.
