Processing Role | Description |
Bulk Response | This role will identify the appropriate message to send with the results of a bulk command execution. For example, this would be used if a large list of devices had been supplied to execute device status check in order to verify outage status. |
Response - Success | This role will identify the appropriate message to send for a successful smart meter command |
Send Device Event | This role sets up the subscription for device events that Oracle Utilities Network Management System has interest in. |
Suppression Notification | This role identifies the appropriate message to send when a notification has been set or removed. |
Activity Type | Description |
Bulk Request Header | Configuration for the bulk request header activity type which is used in making smart meter command requests for a list of meters. |
Bulk Response | Configuration for the bulk response activity type which organizes the response for bulk requests. |
Device Event Notification Suppression | Identifies the device event categories and types that are subject to suppression. |
