Configuring Dynamic Option Types
This portal is used to display and maintain a Dynamic Option Type.
You can access the portal by selecting Admin, then Usage, then Dynamic Option Type.
• Dynamic Option Type List: displays all of the Dynamic Option Types so you can choose the one you want to display in more detail
• Dynamic Option Type: shows the specific configuration for the selected Dynamic Option Type
Parent topic
