Introduction
As delivered, the Adapter Development Kit supports payload processing of usage and event data exported from an AMI head end system in the “native” initial measurement and device event data formats (the format of the initial measurement and device event seeder business objects).
The Adapter Development Kit can also be configured to support payload processing of data from AMI head end systems in custom and non-standard formats. This involves creation of Groovy Library Scripts to:
• Parse the payload into a “plain XML” format, and
• Transform the plain XML format into the “native” ” initial measurement and device event data formats
These scripts are executed as User Exit Interceptors configured on the SGG Payload Processing Configuration extendable lookup. See
Creating SGG Payload Processing Configuration Extendable Lookup Values.
Parent topic
