Lifecycle State | Algorithms |
Validate | Similar to the sctivity, the Validate state houses algorithms that will execute prior to sending the message. • Validate Communication Type: This algorithm ensures the communicationType field is populated on the message. |
Validation Error | If the Validate state encounters an error, the business object transitions to this state. The algorithms are similar to those in the activity business object. |
Awaiting Response | The Awaiting Response state sends an outbound message and awaits the response. • Populate Send Detail: Each outbound communication has a specific algorithm to populate all the schema elements that are required to create the outbound message. • Create Outbound Message: This algorithm creates a specific outbound message based on the Processing Role. The response is stored in the responseDetails element. • Timeout: This algorithm detects whether a communication has been waiting for an asynchronous response too long. |
Retry | The lifecycle state responsible for transitioning the outbound communication back to Awaiting Response. |
Response Error | The business object enters the Response Error state when an error has occurred in sending the request. It contains algorithms for creating To Do entries and for retrying similar to the activity’s Communication Error state. |
Completed | This is the final state representing a successful outbound communication. Finishing tasks such as setting flags for use by subsequent communications and notifying the parent activity of completion are performed. |
Discarded | Includes an algorithm that transfers the parent activity to Failed. |
