Command | Processing Role | Business Object | Outbound Message Business Object |
Device Commissioning | Device Registration | Itron - Add Meter Definition (D8-AddMeterDefinitionsDR) | Outbound Message for Itron Commission D8-ItronCommissionOutboundMsg |
Device Decommissioning | Device Deregistration | Itron - Deregister Meter (D8-DeregisterMeterDR) | Outbound Message for Itron Decommission D8-ItronDecommissionOutbndMsg |
Remote Connect | Remote Connect | Itron - Reconnect Meter (Remote Connect) D8-ReconnectMeterDR) | Outbound Message for Itron connect command D8-ItronRemoteConnectOutbndMsg |
Get Remote Connect Result | Itron - Reconnect Meter Result (D8-ReconnectMeterResult) | Outbound Message for Itron connect result command (D8-ItronRemoteCntRsltOutMsg) | |
Remote Disconnect | Remote Disconnect | Itron - Disconnect Meter (D8-DisconnectMeterDR) | Outbound Message for Itron disconnect command D8-ItronRemoteDisconnectOutMsg |
Get Remote Disconnect Result | Itron - Disconnect Meter Result (D8-DisconnectMeterResult) | Outbound Message for Itron disconnect result command (D8-ItronRemoteDcntRsltOutMsg) | |
On-Demand Read (Scalar) | On-Demand Read (Scalar) | Itron - Contingency Read (Scalar) (D8-ReadScalarDR) | Outbound Message for Itron Contingency Read command D8-ItronOnDemandReadOutbndMsg |
Get On-Demand Read Result | Itron - On Demand Read Result (D8-ReadOnDemandReadResultDR) | O/B Msg for Itron Contingency Read Result (D8-ItronOnDemandReadRsltOBMsg) | |
On-Demand Read (Interval) | On-Demand Read (Interval) | Itron - Contingency Read (Interval) (D8-ReadIntervalDR) | Outbound Message for Itron Contingency Read command (D8-ItronOnDemandReadOutbndMsg) |
Scheduled Read (Scalar) | Send Schedule Read Request | Itron - Interrogate by Group (Scalar) (D8-InterrogateByGroupDR) | Outbound Message for Itron Schedule Read command (D8-ItronInterrogateByGrpOBMsg) |
Get Schedule Read Result | Itron - Interrogate by Group Results (D8- InterrogateByGroupResultDR) | Outbound Message for Itron Schedule Read Result command (D8-ItronInterrogateByGrpRsltOB) | |
Scheduled Read (Interval) | Send Schedule Read Request | Itron - Interrogate by Group (Interval) (D8-InterrogateByGroupDR) | Outbound Message for Itron Schedule Read command (D8-ItronInterrogateByGrpOBMsg) |
Device Status Check | Device Status Check | Itron - Ping by Endpoints (Status Check) (D8-PingByEndpointsDR) | Outbound Message for Itron Device status check (D8-ItronDvcStatusChkOutbndMsg) |
Get Device Status Check Result | Itron - Ping By Endpoints Result (D8- PingByEndpointsResultDR) | O/B Msg for Itron DeviceStatusCheck Result (D8-ItronDvcStatusChkRstlOBMsg) | |
Multi-Device Status Check | Multi-Device Status Check | Itron - Ping By Endpoints Multi-Device (D8-PingByEndpointsMultiDvcDR) | Outbound Message for Itron Multi device status check (D8-ItronDvcStChkMtDvcOutbndMsg) |
Get Multi-Device Status Check Result | Itron – Ping By Endpoints Multi Dvc Result (D8- PingByEndpointsMDResultDR) | O/B Message for Itron MultiDeviceStatusCheck Result (D8-ItronDvcStChkMtDvcRsltOBMsg) | |
Load Check | Load Check | Itron - Detect Load Side Voltage (D8-DetectLoadSideVoltgeByMtrDR) | Outbound Message for Itron Detect Load Side Voltage (D8-ItronDetectLoadSideVolOBMsg) |
Get Load Check Results | Itron – Detect Load Side Voltage Result (D8- DetLoadSideVoltageMtrRsltDR) | Outbound Message for LoadCheckResult Cmd (D8-ItronDetLSVoltMtrRsltOutMsg) |
Device Commissioning | Device Registration | L+G Add Meter to Inventory(MultiSpeak) (D3-AddMeterToInventryMultiSpDR) | LG - Add Meter To Inventory OB Message D3-AddMeterToInventoryOBMsg |
Device Decommissioning | Device Removal | L+G Meter Remove Notification (MultiSpeak) (D3-MtrRmvNotifMultiSpeakDR) | LG - Meter Remove Notification OB Message (D3-MeterRemoveNotifOBMsg) |
Meter Retire | Device Deregistration | L+G Meter Retire Notification (D3-MeterRetireNotificationDR) | LG - Meter Retire Notification OB Message (D3-MeterRetireNotifOBMsg) |
Meter Exchange | Device Installation | L+G Meter Exchange Notification (D3-MeterExNotificatnMultiSpDR) | LG -Meter Exchange Notification OB Message (D3-MeterExchNotificatnOBMsg) |
Remote Connect | Remote Connect | L+G Initiate Connect Disconnect DR (D3-InitiateConnectDisconnectDR) | L+G Initiate Connect Disconnect OB Message (D3-InitConnectDisconnectOBMsg) |
Remote Disconnect | Remote Disconnect | L+G Initiate Connect Disconnect DR (D3-InitiateConnectDisconnectDR) | L+G Initiate Connect Disconnect OB Message (D3-InitConnectDisconnectOBMsg) |
Demand Reset | Demand Reset | L+G Schedule Demand Reset (Multispeak) (D3-ScheduleDemandResetDR) | LG - Schedule Demand Reset OB Message (D3-ScheduleDemandResetOBMsg) |
On-Demand Read (MultiSpeak) | On-Demand Read (Scalar) | L+G MultiSpeak Initiate Meter Read By Meter Num Direct Route (D3-InitiateMRByMtrNbrDR) | L+G MultiSpeak InitiateMeterReadByMeterNumber OB Message (D3-InitMtrReadByMtrNumOBMsg) |
On-Demand Read (Interval) [CIM] | On-Demand Read (Interval) | CIM Meter On Demand Read Direct Route (Interval) (D3-CIMGetLPDataDR) | CIM AMIRequest GetMeterReads OB Message (D3-CIMAMIRequestGetMtrRdOBMsg) |
On-Demand Read (Scalar) [CIM] | On-Demand Read (Scalar) | CIM Meter On Demand Read Direct Route (Scalar) (D3-CIMMeterOnDemandReadDR) | CIM AMIRequest GetMeterReads OB Message (D3-CIMAMIRequestGetMtrRdOBMsg) |
Device Status Check | Device Status Check | CIM Ping Direct Route (D3-CIMPingDR) | CIM AMIRequest GetMeterReads OB Message (D3-CIMAMIRequestGetMtrRdOBMsg) |
Device Commissioning | Device Registration | Sensus -Meter Add Notification Direct Route (D6-MeterAddNotificationDR) | Sensus - Meter Add Notification OB Message D6-MeterAddNotificationOBMsg |
Device Decommissioning | Device Removal | Sensus -Meter Remove Notification Direct Route (D6-MeterRemoveNotificationDR) | Sensus -Meter Remove Notification OB Msg (D6-MeterRemoveNotificatnOBMsg) |
Remote Connect | Remote Connect | Sensus - Initiate Conn Discon - DR (D6-InitiateConnectDisconnectDR) | Sensus Initiate Connect Discon OB Message (D6-InitConnectDisconnectOBMsg) |
Remote Disconnect | Remote Disconnect | Sensus - Initiate Conn Discon - DR (D6-InitiateConnectDisconnectDR) | Sensus Initiate Connect Discon OB Message (D6-InitConnectDisconnectOBMsg) |
On-Demand Read (MultiSpeak) | On-Demand Read (Scalar) | Sensus - Initiate Meter Read By Meter ID (D6-InitiateMeterByMeterIdDR) | Sensus MultiSpeak InitiateMeterReadByMeterNumber OB Message (D6-InitMtrRdMtrIdOBMsg) |
Device Status Check | Device Status Check | Sensus Initiate Outage Detection DR (D6-InitiateOutageDetectionDR) | Sensus InitiateOutageDetection OB Message (D6-InitOutageDetectionOBMsg) |
Device Commissioning | Device Registration | SSN - Replace Location (D7-ReplaceLocationDR) | SSN - Replace Location (Comm) OB Message (D7-ReplaceLocationOBMsg) |
Device Decommissioning | Device Removal | SSN - Replace Device At Location (Decomm) (D7-ReplDeviceAtLocForDecommDR) | SSN - Replace Device At Loc O/B Message: (D7-ReplaceDeviceAtLocOBMsg) |
Remote Connect | Remote Connect | SSN - Connect or Disconnect (D7-ConnectDisconnectDR) | SSN - Connect Disconnect OB Message (D7-ConnectDisconnectOBMsg) |
Get Remote Connect Result | SSN - Connect Disconnect Results (D7-ConnectDisconnectResultDR) | SSN - GetConnectDisconnectResult OB Message (D7-GetCntDiscntResultOBMsg) | |
Remote Disconnect | Remote Disconnect | SSN - Connect or Disconnect (D7-ConnectDisconnectDR) | SSN - Connect Disconnect OB Message (D7-ConnectDisconnectOBMsg) |
Get Remote Disconnect Result | SSN - Connect Disconnect Results (D7-ConnectDisconnectResultDR) | SSN - GetConnectDisconnectResult OB Message (D7-GetCntDiscntResultOBMsg) | |
On-Demand Read (Scalar) | On-Demand Read (Scalar) | SSN - Add Meter Read Job (Scalar) (D7-AddMeterReadJobScalarDR ) | SSN - Add Meter Read Job Scalar OB Msg Type D7-AddMeterReadJobScalarOBMsg |
Get On-Demand Read Result (Scalar) | SSN - Meter Read Results (Scalar) (D7-MeterReadResultsScalar ) | SSN - GetMeterReadResults(Scalar) By JobId (D7-GetSMtrRdRsltJobIdOBMsgTyp ) | |
On-Demand Read (Interval) | On-Demand Read (Interval) | SSN - Add Meter Read Job (Interval) (D7-AddMeterReadJobIntervalDR ) | SSN - AddMeterReadJob Interval OB Msg Type (D7-AddMtrReadJobIntervalOBMsg ) |
Get On-Demand Read Result (Interval) | SSN - Meter Read Results (Interval) (D7-MeterReadResultsInterval ) | SSN - GetMeterReadResults(Interval) By JobId (D7-GetIMtrRdRsltJobIdOBMsgTyp ) | |
Device Status Check | Device Status Check | SSN - Add Ping Job (D7-AddPingJobDR) | SSN - Add Ping Job OB Message (D7-AddPingJobOBMsg) |
Get Device Status Check Result | SSN - Ping Results (D7-PingResultsDR) | SSN - Get Ping Results O/B Message (D7-GetPingResultsOBMsg) |
