Outbound Message Business Object | Message XSL | Response XSL |
Outbound Message for Itron Commission (D8-ItronCommissionOutboundMsg) | D8-CommissionRequest.xsl | D8-CommissionResponse.xsl |
Outbound Message for Itron Decommission (D8-ItronDecommissionOutbndMsg) | D8-DecommissionRequest.xsl | D8-DecommissionResponse.xsl |
Outbound Message for Itron connect command (D8-ItronRemoteConnectOutbndMsg) | D8-ReconnectRequest.xsl | D8-ReconnectResponse.xsl |
Outbound Message for Itron connect result command (D8-ItronRemoteCntRsltOutMsg) | D8-GetReconnectRsRequest.xsl | D8-GetReconnectRsResponse.xsl |
Outbound Message for Itron disconnect command (D8-ItronRemoteDisconnectOutMsg) | D8-DisconnectRequest.xsl | D8-DisconnectResponse.xsl |
Outbound Message for Itron disconnect result command (D8-ItronRemoteDcntRsltOutMsg) | D8-GetDisconnectRsRequest.xsl | D8-GetDisconnectRsResponse.xsl |
Outbound Message for Itron Contingency Read command (D8-ItronOnDemandReadOutbndMsg) | D8-ContRdByEndptsRequest.xsl | D8-ContRdByEndptsResponse.xsl |
O/B Msg for Itron Contingency Read Result (D8-ItronOnDemandReadRsltOBMsg) | D8-GetContRdByEndptsRsReq.xsl | D8-GetContRdByEndptsRsResp.xsl |
Outbound Message for Itron Schedule Read command (D8-ItronInterrogateByGrpOBMsg) | D8-InterrogateByGroupReq.xsl | D8-InterrogateByGroupResp.xsl |
Outbound Message for Itron Schedule Read Result command (D8-ItronInterrogateByGrpRsltOB) | D8-GetIntByGroupRsRequest.xsl | D8-GetIntByGroupRsResponse.xsl |
Outbound Message for Itron Device status check (D8-ItronDvcStatusChkOutbndMsg) | D8-PingByEndpointsRequest.xsl | D8-PingByEndpointsResponse.xsl |
O/B Msg for Itron DeviceStatusCheck Result (D8-ItronDvcStatusChkRstlOBMsg) | D8-GetPingByEndptsRsReq.xsl | D8-GetPingByEndptsRsResp.xsl |
Outbound Message for Itron Multi device status check (D8-ItronDvcStChkMtDvcOutbndMsg) | D8-PingByEndpointsRequest.xsl | D8-PingByEndpointsResponse.xsl |
O/B Message for Itron MultiDeviceStatusCheck Result (D8-ItronDvcStChkMtDvcRsltOBMsg) | D8-GetPingByEndptsRsReq.xsl | D8-GetPingByEndptsRsResp.xsl |
Outbound Message for Itron Detect Load Side Voltage (D8-ItronDetectLoadSideVolOBMsg) | D8-DetLSVByMeterRequest.xsl | D8-DetLSVByMeterResponse.xsl |
Outbound Message for LoadCheckResult Cmd (D8-ItronDetLSVoltMtrRsltOutMsg) | D8-GetDetLSVByMeterRsReq.xsl | D8-GetDetLSVByMeterRsResp.xsl |
Outbound Message for Itron Read Disconnect State D8-ItronReadDisconStateOutMsg | D8-RdDiscStByMtrsRequest.xsl | D8-RdDiscStByMtrsResponse.xsl |
Outbound Message for ReadDisconStateMeter Cmd D8-ItronRdDiscStByMtRsltOutMsg | D8-GetRdDiscStByMtrsRsReq.xsl | D8-GetRdDiscStByMtrsRsResp.xsl |
LG - Add Meter To Inventory OB Message D3-AddMeterToInventoryOBMsg | D3-AddMtrToInvRequest.xsl | D3-AddMtrToInvResponse.xsl |
LG - Meter Remove Notification OB Message D3-MeterRemoveNotifOBMsg | D3-MtrRemoveNotfRequest.xsl | D3-MtrRemoveNotfResponse.xsl |
LG - Meter Retire Notification OB Message D3-MeterRetireNotifOBMsg | D3-MtrRetireNotfRequest.xsl | D3-MtrRetireNotfResponse.xsl |
LG -Meter Exchange Notification OB Message D3-MeterExchNotificatnOBMsg | D3-MtrExcNotifRequest.xsl | D3-MtrExcNotifResponse.xsl |
L+G Initiate Connect Disconnect OB Message D3-InitConnectDisconnectOBMsg | D3-InitiateConnDisconReq.xsl | D3-InitiateConnDisconResp.xsl |
LG - Schedule Demand Reset OB Message D3-ScheduleDemandResetOBMsg | D3-ScheduleDemandRstReq.xsl | D3-ScheduleDemandRstResp.xsl |
L+G MultiSpeak InitiateMeterReadByMeterNumber OB Message D3-InitMtrReadByMtrNumOBMsg | D3-InitMtrRdMtrNumRequest.xsl | D3-InitMtrRdMtrNumResponse.xsl |
CIM AMIRequest GetMeterReads OB Message D3-CIMAMIRequestGetMtrRdOBMsg | D3-CIMGetMtrReadsRequest.xsl | D3-CIMGetMtrReadsResponse.xsl |
Sensus - Meter Add Notification OB Message D6-MeterAddNotificationOBMsg | D6-MtrAddRemoveNotifReq.xsl | D6-MeterAddNotifResponse.xsl |
Sensus -Meter Remove Notification OB Msg (D6-MeterRemoveNotificatnOBMsg) | D6-MtrAddRemoveNotifReq.xsl | D6-MeterAddNotifResponse.xsl |
Sensus Initiate Connect Discon OB Message (D6-InitConnectDisconnectOBMsg) | D6-InitiateConnDisconReq.xsl | D6-InitiateConnDisconResp.xsl |
Sensus MultiSpeak InitiateMeterReadByMeterNumber OB Message (D6-InitMtrRdMtrIdOBMsg) | D6-InitMtrRdMtrIdRequest.xsl | D6-InitMtrRdMtrIdResponse.xsl |
Sensus InitiateOutageDetection OB Message (D6-InitOutageDetectionOBMsg) | D6-InitOutDetectRequest.xsl | D6-InitOutDetectResponse.xsl |
SSN - Find Device Outbound Message D7-FindDeviceOutboundMsg | D7-FindDeviceRequest.xsl | D7-FindDeviceResponse.xsl |
SSN - Get Job Status Outbound Message D7-GetJobStatusOutboundMsgType | D7-GetJobStatusRequest.xsl | D7-GetJobStatusResponse.xsl |
SSN - Replace Location (D7-ReplaceLocationDR) | D7-ReplaceLocationRequest.xsl | D7-ReplaceLocationResponse.xsl |
SSN - Replace Device At Location (Decomm) (D7-ReplDeviceAtLocForDecommDR) | D7-RepDvcAtLocRequest.xsl | D7-RepDvcAtLocResponse.xsl |
SSN - Connect or Disconnect (D7-ConnectDisconnectDR) | D7-AddRemProvJobRequest.xsl | D7-AddRemProvJobResponse.xsl |
SSN - Connect Disconnect Results (D7-ConnectDisconnectResultDR) | D7-GetRemProvRsByJobIDReq.xsl | D7-GetRemProvRsByJobIDResp.xsl |
SSN - Add Meter Read Job Scalar OB Msg D7-AddMeterReadJobScalarOBMsg | D7-AddMtrRdJobScRequest.xsl | D7-AddMtrRdJobScResponse.xsl |
SSN - GetMeterReadResults(Scalar) By JobId D7-GetSclrMtrRdRstByJobIdOBMsg | D7-GetMtrRdRsByJobIDReq.xsl | D7-GetMtrRdRsByJobIDResp.xsl |
SSN - AddMeterReadJob Interval OB Msg D7-GetIntMtrRdRsltByJobIdOBMsg | D7-AddMtrRdJobIntRequest.xsl | D7-AddMtrRdJobIntResponse.xsl |
SSN - GetMeterReadResults(Interval) By JobId D7-GetIMtrRdRsltJobIdOBMsgTyp | D7-GetMtrRdRsByJobIDReq.xsl | D7-GetMtrRdRsByJobIDResp.xsl |
SSN - Add Ping Job (D7-AddPingJobDR) | D7-AddPingJobRequest.xsl | D7-AddPingJobResponse.xsl |
SSN - Ping Results (D7-PingResultsDR) | D7-GetMtrRdRsByJobIDReq.xsl | D7-GetMtrRdRsByJobIDResp.xsl |
