Understanding Device Event Types
Device Events
Device event types define properties common to specific types of events.
Device event types represent different types of events that can take place relative to a device. Examples of device events include power outages, power restoration, tampering alerts, and other events.
Device event types can be defined by the following attributes:
• Standard Event Name: the "standard" name of the event type. Device vendors may have their own specific names for device events. Only a single active device event type may be mapped to a given standard name at any time.
• Device Event Category: a category (defined as an Extendable Lookup) used to group device event types.
• Reporting Category: a category used to group device event types for reporting purposes.
• Activity Type: the activity type for activities created for device events of this type.
Device Event Mapping
The first step to device event type configuration is defining the list of standard event names that will be processed by the system. This is done by populating the Standard Event Name extendable lookup (D1-StdEventNameLookup). More information about this extendable lookup can be found in
About Device Events.
With the fully defined list of Standard Event Names each head-end specific event name (which is also called an external event name) that the system will receive from a given head-end should be mapped to a standard event name. This mapping is configured using a device event mapping extendable lookup. Each head-end system should have its own extendable lookup to define event name mapping in order to prevent possible conflicts between mappings. Each of these business objects should be defined as a child of the parent business object Device Event Mapping (D1-DeviceEventMappingLookup).
For example, head-end systems A and B might both use the same event name, such as the code "1", but this event might need to be mapped to "outage" for head-end system A but "tamper" for head-end system B.
The device event mapping extendable lookup business object is configurable. Each Oracle Utilities Smart Grid Gateway adapter includes a device event mapping lookup business object for the supported head-end system.
Lastly, each device event type is associated to a standard name. This means that as each device event that is received will go through the following mapping steps:
1. The head end specific event name is mapped to a standard event name using the head end specific device event mapping extendable lookup
2. The standard event name is mapped to a device event type
3. The device event type is used to select the appropriate device event business object
Device Event - Additional Processing
Certain device event business objects can be used to update master data as a result of device events received into the system. For example, when a utility's field worker arms a meter, the resulting device event can trigger an update to the device's arming status in the Oracle Utilities application. This processing is initiated by the Execute - Additional Processing system event
algorithm during the Additional Processing status of the business object's lifecycle.
The following base package business objects are configured to execute additional processing:
If a standard device event requires additional processing, the algorithms that execute the processing should be specified in the Additional Processing Algorithms list on the Standard Event Name extendable lookup for the event. The base package includes the additional processing algorithm Arm Meter (D1-ARM-METER).
Only a subset of base package device event business objects are configured to execute additional processing
Description | Business Object Name |
Device Event Communication Response | D1-DeviceEventComResp |
Standard Device Event | D1-StandardDeviceEvent |
If additional processing is required for any business objects not listed above it can easily be added by configuring the algorithm Executer - Additional Processing System Event (D1-EXTADDPRC) in the Additional Processing status.
Reader Remarks
Reader remark types define properties common to specific types of reader remarks.
Reader remarks are a type of device event used to capture and/or record specific events or circumstances encountered when a meter reader is manually reading scalar meters. Reader remark types represent the different types of remarks that meter readers can record. Examples of reader remark types include evidence of tampering, broken seals, damaged meter, dog on premises, and other notices.
When creating a new device type there are the following options:
Name | Details | Business Object |
Reader Remark Type | Provides the configuration for a reader remark type | D1-ReaderRemarkType |
Field Activity Remarks
Field activity remark types define properties common to specific types of field activity remarks.
Field activity remarks are a type of device event used to capture and/or record specific events or circumstances encountered when a field worker is performing field work at a service point. Field activity remarks represent can represent situations that are found as well as actions that were taken in the field.
Device Field Remark Type | Provides the configuration for a field activity remark type | D1-DeviceFieldRemarkType |
Parent topic
