Maintaining Usage Subscription Market Participants
You use the Usage Subscription Market Participant portal is used to display and maintain usage subscription market participants.
You can access the portal from the Main > Usage > Usage Subscription Market Participant. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
Usage Subscription Market Participant: This zone displays the basic attributes of the usage subscription market participant
Sub Usage Subscriptions: lists sub usage subscriptions for the usage subscription market participant’s usage subscription
