Working with Route Management
This Route Management portal is used to change the sequence of Service Points within a measurement cycle and route and to transfer Service Points from one measurement cycle and route to another.
You can access the portal from the Main > Device Installation > Route Management. You are brought to a query portal with options for searching. Once you enter your search criteria, a list of related Service Points is presented.
The following actions are available once a Measurement Cycle and Route are selected:
• Renumber Sequence: renumbers the sequence of selected Service Points for the route. Use the Renumber Sequence page to renumber the sequence of Service Points in a measurement cycle route.
• Transfer Measurement Cycle Route: Use this button to transfer the selected Service Points to another route. Use the Transfer Measurement Cycle Route page to transfer the selected Service Points to another measurement cycle route. You can also renumber the sequence of Service Points in their new route as part of the transfer.
Parent topic
