Outbound Message Types
Outbound message types define specific types of messages sent to an external system, such as messages containing device command requests.
The following outbound message types must be configured in your system. If these are not present in your configuration, add them. Refer to the Oracle Utilities Application Framework documentation for more information about creating outbound message types.
Outbound Message Type | Description |
D3-ADDMTRINV | Add Meter to Inventory |
D3-COMMS | Commission Device |
D3-CONNECT | Connect Device |
D3-DECOMMS | Decommission |
D3-DEMRESET | Demand Reset |
D3-DERDEV | Deregister Device |
D3-DISCONNEC | Disconnect Device |
D3-DVCSTSCHK | Device Status Check |
D3-INITMRN | Initiate Meter Read by Meter Number |
D3-INITMTR | Initiate Meter Read by Meter Number |
D3-MTRADDNOT | Meter Add Notification Outbound Message Type |
D3-MTREX | Meter Exchange Notification OB MSG |
D3-MTRRMV | Meter Remove Notification |
Note: The following apply to all of the above outbound message types:
• Business Object: D1-OutboundMessage (Outbound Message)
• Priority: Priority 50
Parent topic
