Message Senders
Message senders define the details of how messages are sent to an external system, such as messages containing device command requests.
The following message senders must be configured in your system. If these are not present in your configuration, add them. Refer to the Oracle Utilities Application Framework documentation for more information about creating message senders.
 Message Sender
 Description
D4-ADDMETREQ
 Add Meter Request
D4-CONLOAD
 Connect Load
D4-DECOMMIS
 Device Decommissioning
D4-DISCONLD
 Disconnect Load
D4-HNLBATEVT
 NES Handle Batch Event
D4-HNLBATUSG
 NES Handle Batch Usage
D4-RDLOADST
Read Load status
D4-READBILLD
NES On-Demand Read (Scalar)(2)
D4-READLP
Read Load Profile
D4-RETMETID
 Retrieve Meter Identifier
D4-RETRIEVE
 Retrieve Meter Information
D4-ReadBill
Read Billing Data
D4-SETATMCFG
 Set ATM Configuration
Note: The following apply to all of the above message senders:
Main Tab:
Invocation Type: Real-time
Message Class: RTHTTPSNDR (Sender routes message via HTTP real-time)
MSG Encoding: UTF-8 message encoding
Context Tab:
HTTP Header: SOAPAction: http://xmlns.oracle.com/ouaf/echelon/<OPERATION>
HTTP Login User: <USER_​ID>
HTTP Login Password: <PASSWORD>
HTTP Method: POST
HTTP URL 1: http://<EM_​SERVER>:<EM_​SERVER_​PORT>/soa-infra/services/D4/<SERVICE>/<SERVICE>
where:
<OPERATION>: the operation performed by the message sender (see Operation column in the table above)
<USER_​ID>: the user ID used to log into WebLogic Enterprise Manager
<PASSWORD>: the password used to log into WebLogic Enterprise Manager
<EM_​SERVER>: the machine name or IP address of server where the WebLogic Enterprise Manager is installed
<EM_​SERVER_​PORT>: the port where the WebLogic Enterprise Manager is installed
<SERVICE>: the service invoked by the message sender (see Service column in the table above)
