Message Senders
Message senders define the details of how messages are sent to an external system, such as messages containing device command requests. An message sender should be configured for each command.
The following message senders must be configured in your system. If these are not present in your configuration, add them. Refer to the Oracle Utilities Application Framework documentation for more information about creating message senders.
Message Sender
Description
D7-DECOMM
SSN Replace Device at Location for Decommission
D7-COMM
SSN Replace Location - Commission
D7-ADDJOB
SSN Add Meter Read Job
D7-ADDPING
SSN Add Ping Job
D7-CONNECT
SSN Connect Device
D7-GTSTATUS
SSN Get Status
Note: The following apply to all of the above message senders:
Main Tab:
Invocation Type: Real-time
Message Class: RTHTTPSNDR (Sender routes message via HTTP real-time)
MSG Encoding: UTF-8 message encoding
Context Tab:
HTTP Header: SOAPAction:http://xmlns.oracle.com/ouaf/ssn/<OPERATION>
HTTP Login User: <USER_​ID>
HTTP Login Password: <PASSWORD>
HTTP Method: POST
HTTP URL 1: http://<EM_​SERVER>:<EM_​SERVER_​PORT>/soa-infra/services/SSN/<SERVICE>
where:
<OPERATION>: the operation performed by the message sender (see Operation column in the table above)
<USER_​ID>: the user ID used to log into WebLogic Enterprise Manager
<PASSWORD>: the password used to log into WebLogic Enterprise Manager
<EM_​SERVER_​IP>: the machine name or IP address of server where the WebLogic Enterprise Manager is installed
<EM_​SERVER_​PORT>: the port where the WebLogic Enterprise Manager is installed
<SERVICE>: the service invoked by the message sender (see Service column in the table above)
