Defining Application Services
Please refer to
Application Security for a description of how application services are used when you grant user groups access rights transactions. Refer to
Action Level Security for more information about the significance of an application service's access modes.
You can access the portal using > > You are brought to a query portal with options for searching for a specific application service. Once a record has been selected you are brought to the maintenance portal to view and maintain the selected record.
The Application Service zone provides the information about the application service and its access modes.
The
Secured Objects zone displays the object (or objects) that are secured by this application service. Refer to
Application Security for details about the types of objects that may be secured.
The Application Security tab includes zones to view and manage which user groups have access to the application service and which ones do not have access.
The User Groups Linked zone lists the user groups that currently have a link to the application service. Note that expired links are also included.
• Click the
Description link to navigate to the
User Group - Users page for the adjacent user group. This allows you to add or remove users linked to the user group.
• Click Deny Access to remove the selected Application Service's link to this user group.
The User Groups not Linked lists the user groups that do not have a link to the application service. The following actions are available:
• Click the
• Click
Grant Access to navigate to the
User Group - Application Services page for the user group. The page is automatically positioned at the selected application service allowing you to set the access modes and the expiration date.
Parent topic
