To Do Type - Drill Keys
The Drill Keys page defines the keys passed to the application service (defined on the Main page) when you drill down on an entry of a given type.
To maintain this information, select > > and navigate to the Drill Keys page.
CAUTION:
Do not change this information unless you are positive that the process / algorithm that creates entries of a given type stores this information on the entries.
Description of Page
Navigation Option shows the page into which the user is transferred when drilling down on a To Do entry of this type.
The following fields display for each drill key.
Sequence is the unique ID of the drill key.
Table and Field are passed to the application service when you drill down on an entry of a given type.
Owner indicates if this entry is owned by the base package or by your implementation (Customer Modification).
Parent topic
