Defining File Integration Types
This section describes the functionality supported for viewing and maintaining file integration types.
Refer to
Extract Record Processing for an overview of the file integration type functionality provided with
plug-in driven background processes.
To view or add a file integration type, open > >
Once a file integration type record has been selected, you are brought to the maintenance portal to view and maintain the selected record.
The File Integration Records zone lists the record definitions for this integration, in hierarchical order. Use the zone actions to add, maintain or view a file integration record. Press the Record Layout icon to view a pop-up display of the record’s schema.
Parent topic
