Input Data and
Move Data steps can create fields in temporary storage. You specify the name of the temporary storage field in the step's
Field Name. The name of the field must
not begin with % and must not be named the same as the
global variables. Besides this restriction, you can use any
Field Name that's acceptable to JavaScript (i.e., you can name a field in temporary storage almost anything). Keep in mind that field names are case-sensitive.
