Display Text Steps
Note:BPA scripts only. This step type is only applicable to BPA scripts.
Display text steps cause a text string to be displayed in the script area. Steps of this type can be used to provide the user with guidance when manual actions are necessary. In addition, they can be used to provide confirmation of the completion of tasks.
The information you enter in the
Text field is displayed in the
script area when the step is executed.
The text string can contain
substitution variables and
HTML formatting commands. Also note that for debugging purposes, you can display an entire data area (or a portion thereof) by entering
%+...+% where
... is the name of the node whose element(s) should be displayed.
Parent topic
