Invoke Business Object Steps
Invoke business object steps allow you to interact with a
business object in order to obtain or maintain its information.
The following additional fields are required for Invoke business object steps:
Use
Warning Level to indicate whether warnings should be suppressed and if not, how they should be presented to the user. By default, warnings are suppressed. If
Warn As Popup is used, the warning is displayed using the standard popup dialog. If
Warn As Error is used processing is directed to the
If Error, Go To step. This field is only applicable to BPA scripts. Refer to
BO warnings for more information about handling warnings when invoking a BO.
Group Name references the
data area to be passed to and from the server when communicating with the
Business Object. Indicate the
Action to be performed on the object when invoked. Valid values are
Add, Delete, Fast Add (No Read), Fast Update (No Read), Read, Replace, Update.
Fastpath:
Refer to
BO Actions for more information about the various actions.
The business object call will either be successful or return an error. The next two fields only appear when the call is issued from a BPA script, to determine the step to which control is passed given the outcome of the call.
If Success, Go To defines the step that is executed if the call is successful. This field is only applicable to BPA scripts.
If Error, Go To defines the step that is executed if the call returns on error. Please note that the error information is held in
global variables. This field is only applicable to BPA scripts.
Note:Error technique. Let's assume a scenario where a business object is invoked from a BPA script and the call returned an error. If the BPA script is configured to communicate with the user using a UI map, you may find it useful to invoke the map again to present the error to the user. Alternatively, you may invoke a step that transfers control to a script that displays the error message information and stops.
Parent topic
