How To Use Constants In Scripts
Some steps can reference fields called Predefined Values. For example, if you want to compare an input value to the letter "Y", the letter Y would be defined as a Predefined Value's field value.
Special constants are used for fields defined as switches. When you move TRUE to a switch, it turns it on. When you move FALSE to a switch, it turns it off.
You can use a
global variable as a Predefined Value. For example, if you wanted to move the current date to a field, you'd indicate you wanted to move a Predefined Value named
%CURRENT_​DATE.
Parent topic
