Cube Configuration Components
Cube views are supported using a number of standard configuration components.
The system provides a business object for cube views (F1-CubeView) which is used to capture access controls and the settings, such as user parameter values, for a cube view instance. The business object also defines the portal navigation and the base display UI Map (F1-CubeViewDisp) and accompanying display map service script ( F1_​CubeViewD). The display map and service script together drive the functionality supported in the cube viewer.
The system also supplies a UI map fragment (
F1-CubeViewProc) which is used to display a cube view in a process flow panel. Refer to
Process Flows for more information.
The system provides a portal for cube views (F1CUVWM ) that can be configured on the appropriate menu item or other navigation path for your implementation. The portal is linked to the base cube view zone (F1-CUBEVIEW).
In addition, the system supplies a simple query by cube view information (F1-CUBVIWQ1) that is the single entry on a base multi-query zone (F1-CUBVIWQ). The multi-query zone is not linked to the base portal as the expectation is that implementations will need to create searches tailored to their specific use cases for cube views. The base multi-query provides a quick means of configuring a cube view search while in development mode.
Parent topic
