Save Button
Clicking the Save button saves any changes you have made in the data on the current object.
![The Save link The Save link](../MDM_25000/images/BP01SWS_Save_Button.jpg)
Keyboard Shortcut | Alternate Shortcut |
Alt+S | Alt+Shift+S |
The button does not appear unless:
• You enter a page in add mode and default values are loaded.
• You make changes to an object after it is displayed (note that you must tab or click out of the field before the Save button appears).
Parent topic
