Common Maintenance Activities
This appendix lists frequently-used commands that you use to perform common maintenance activities, such as starting and stopping the environment and thread pool worker, modifying the configuration items.
Run the following commands to perform these common tasks:
To Initialize the Environment
1. Navigate to the <install_dir>/bin directory.
2. Run the following command:
UNIX
./splenviron.sh -e <Env_Name>
Windows
splenviron.cmd -e <Env_Name>
To Start the WebLogic Server
1. Initialize the environment.
2. Navigate to the respective domain's bin folder.
3. Execute the WebLogic Domain Startup command.
To Stop the WebLogic Server
3. Execute the WebLogic Domain Stop command.
To Start the Thread Pool Worker
UNIX
$SPLEBASE/bin/threadpoolworker.sh -d Y -p DEFAULT=20 L2OFF=1 -l2
OFF
Windows
%SPLEBASE%\bin\threadpoolworker.cmd -d Y -p DEFAULT=20 L2OFF=1 -l2
OFF
To Stop the Thread Pool Worker
UNIX
./spl.sh -b stop
Windows
spl.cmd -b stop
To Modify the Configuration Values
UNIX
configureEnv.sh
Windows
configureEnv.cmd
The configuration utility launches menu items. Select any Menu option.
3. Change the menu values.
4. After you change the menu values, press P to write the changes to the configuration file.
5. To apply the changes to the environment, run the initial setup script:
UNIX
./initialSetup.sh
Windows
initialSetup.cmd
To Modify the Advanced Menu Option Values
1. Initialize the environment .
UNIX
configureEnv.sh -a
Windows
configureEnv.cmd -a
3. Select any menu option.
4. Change the menu values.
5. To apply the changes to the environment, run initial setup script.
UNIX
./initialSetup.sh
Windows
initialSetup.cmd
