Relationship Between 2.5.0.1.1 and Prior Versions
Version 2.5.0.1.1 supports the following upgrade paths:
If you are installing Oracle Utilities Meter Data Management for the first time, you must install V2.5.0.1.1 available on Oracle Software Delivery Cloud.
If you have Oracle Utilities Meter Data Management V2.1.0.2.0 or earlier installed, you must upgrade to:
V2.1.0.3.0 > V2.2.0.3.0 > V2.3.0.2.0 > V2.5.0.1.1
If you have Oracle Utilities Meter Data Management V2.1.0.3.0 installed, upgrade to:
V2.2.0.3.0 directly > V2.3.0.2.0 > V2.5.0.1.1
If you have Oracle Utilities Meter Data Management V2.2.0.1.0 or V2.2.0.2.0 installed, you must upgrade to:
If you have Oracle Utilities Meter Data Management V2.2.0.3.0 or later installed, you must upgrade to V2.3.0.2.0, and then to V2.5.0.1.1.
If you have Oracle Utilities Meter Data Management V2.3.0.2.0 or later installed, you can install V2.5.0.1.1 directly.
