Linux/UNIX:
If '-a' (apply on staging flag) is passed, it connects to the database as staging schema admin and performs the conversion setup, in addition to creation of the above files, by running the same SQLs present in the create* SQL files.
On-premises:
java com.oracle.ouaf.oem.conversion.ConversionSetup -d ${JDBC_CONN_STRING} -p ${CIS_ADMIN_USR},${CIS_ADMIN_PSWD} -a -s ${STG_ADMIN_USR},${STG_ADMIN_PSWD},${STG_RW_USER}
ADB:
jdbc:oracle:thin:@<tnsname>?TNS_ADMIN=<wallet location> -p ${CIS_ADMIN_USR},${CIS_ADMIN_PSWD} -a -s
If '-r' (revert staging flag) is passed, it connects to the database as staging schema admin and reverts the staging to a state prior to conversion setup, running the same SQLs present in drop_* or restore_* SQL files.
On-premises:
java com.oracle.ouaf.oem.conversion.ConversionSetup -d ${JDBC_CONN_STRING} -p ${CIS_ADMIN_USR},${CIS_ADMIN_PSWD} -r -s ${STG_ADMIN_USR},${STG_ADMIN_PSWD},${STG_RW_USER}
ADB:
jdbc:oracle:thin:@<tnsname>?TNS_ADMIN=<wallet location> -r -s
To generate ONLY the scripts, the program should be invoked with '-s' parameter with no other flags (no '-a' or '-r' ):
On-premises:
java com.oracle.ouaf.oem.conversion.ConversionSetup -d ${JDBC_CONN_STRING} -p ${CIS_ADMIN_USR},${CIS_ADMIN_PSWD} -s ${STG_ADMIN_USR},${STG_ADMIN_PSWD},${STG_RW_USER}
ADB:
jdbc:oracle:thin:@<tnsname>?TNS_ADMIN=<wallet location> -s
Windows:
On-premises:
"%JAVA_HOME%"\bin\java com.oracle.ouaf.oem.conversion.ConversionSetup -d %{JDBC_CONN_STRING}% -p %{CIS_ADMIN_USR}%,%{CIS_ADMIN_PSWD}% -a -s %{STG_ADMIN_USR}%,%{STG_ADMIN_PSWD}%,%{STG_RW_USER}%
ADB:
"%JAVA_HOME%"\bin\java com.oracle.ouaf.oem.conversion.ConversionSetup -d jdbc:oracle:thin:@<tnsname>?TNS_ADMIN=<wallet location> -p %{CIS_ADMIN_USR}%,%{CIS_ADMIN_PSWD}% -a -s
On-premises:
"%JAVA_HOME%"\bin\java com.oracle.ouaf.oem.conversion.ConversionSetup -d %{JDBC_CONN_STRING}% -p %{CIS_ADMIN_USR}%,%{CIS_ADMIN_PSWD}% -r -s %{STG_ADMIN_USR}%,%{STG_ADMIN_PSWD}%,%{STG_RW_USER}%
ADB:
jdbc:oracle:thin:@<tnsname>?TNS_ADMIN=<wallet location> -p %{CIS_ADMIN_USR}%,%{CIS_ADMIN_PSWD}% -r -s
On-premises:
"%JAVA_HOME%"\bin\java com.oracle.ouaf.oem.conversion.ConversionSetup -d %{JDBC_CONN_STRING}% -p %{CIS_ADMIN_USR}%,%{CIS_ADMIN_PSWD}% -s %{STG_ADMIN_USR}%,%{STG_ADMIN_PSWD}%,%{STG_RW_USER}%
ADB:
jdbc:oracle:thin:@<tnsname>?TNS_ADMIN=<wallet location> -p %{CIS_ADMIN_USR}%,%{CIS_ADMIN_PSWD}% -s
It creates the following files in current directory (or output directory if passed as '-o') if '-r' (revert staging flag) is not passed.
After the staging schema has been set up, generate the security for the staging user following the steps in the Configuring Security section.
Linux/UNIX:
• On-premises:
java -Xmx1500M com.oracle.ouaf.oem.install.OraGenSec-d
<STAGING_DBUSER>,< STAGING_DBPASS>, jdbc:oracle:thin:@<DB_SERVER>:<PORT>/
<SID> -u <STAGING_RW_USER> -r <STAGING_RW_USER_ROLE>,< STAGING_R_USER_ROLE> -a A -p
<RW_USERPASS>
• ADB:
jdbc:oracle:thin:@<tnsname>?TNS_ADMIN=<wallet location> -u <STAGING_RW_USER> -r <STAGING_RW_USER_ROLE>,< STAGING_R_USER_ROLE> -a A -p <RW_USERPASS>
Windows:
