Supported Database Platforms
Oracle Utilities Meter Data Management is supported on the following platforms:
Platform
Database Versions
Oracle Linux 8.x/9.x for x86_64
Oracle 19c (64-bit)
on-premises and cloud (ADB)
Oracle Utilities Meter Data Management is tested on both Oracle Database Enterprise Edition and Standard Edition. Some features, such as Advanced Compression and Partitioning, require the Enterprise Edition.
The following Oracle Database Server Editions are supported:
• Oracle Database Enterprise Edition
• Oracle Database Standard Edition
Note: Oracle Database Enterprise Edition and the Partitioning and Advanced Compression options are not mandatory but recommended. Standard Edition should only be considered suitable for very small, pilot projects or development environments where scalability, performance, and database size-on-disk are not important considerations. Oracle Database Enterprise Edition, including the Advanced Compression and Partitioning options, is strongly recommended in all other situations.
Refer to My Oracle Support for additional details.
