Additional Prerequisite Software Information
This section outlines additional information related to installing the prerequisite software, including:
• Setting Up and Using the Additional JAR Directory
The additional JAR directory must be populated if the Web Application Server Home directory is not set.
For example: The environment is for batch only and the server has no WebLogic installed. In this scenario, the Additional JAR Directory must be created prior to the installation and the following list of WebLogic JARs should be copied to that directory (full path from the actual WebLogic location which must be installed in the web server).
The list of Additional files required for Oracle Utilities Application Framework 25.4:
<Web Application Server Home Directory>/server/lib/javaee-api-8.0.1.jar
<Web Application Server Home Directory>/server/lib/wlthint3client.jar
<Web Application Server Home Directory>/../oracle_common/modules/com.fasterxml.woodstox.woodstox-core.jar
<Web Application Server Home Directory>/../oracle_common/modules/gmbal-api-only-4.0.3.jar
<Web Application Server Home Directory>/../oracle_common/modules/jakarta.activation-1.2.2.jar
<Web Application Server Home Directory>/../oracle_common/modules/jakarta.jws-api-1.1.1.jar
<Web Application Server Home Directory>/../oracle_common/modules/jakarta.xml.bind-api-2.3.3.jar
<Web Application Server Home Directory>/../oracle_common/modules/jakarta.xml.soap-api-1.4.2.jar
<Web Application Server Home Directory>/../oracle_common/modules/javax.mail-1.6.2.jar
<Web Application Server Home Directory>/../oracle_common/modules/jaxb-impl-2.3.5-b230912.1728.jar
<Web Application Server Home Directory>/../oracle_common/modules/jaxws-rt-2.3.5.jar
<Web Application Server Home Directory>/../oracle_common/modules/jersey-client-2.45.jar
<Web Application Server Home Directory>/../oracle_common/modules/jersey-common-2.45.jar
<Web Application Server Home Directory>/../oracle_common/modules/jersey-media-multipart-2.45.jar
<Web Application Server Home Directory>/../oracle_common/modules/oauth2-client-2.45.jar
<Web Application Server Home Directory>/../oracle_common/modules/org.codehaus.woodstox.stax2-api.jar
<Web Application Server Home Directory>/../oracle_common/modules/policy-2.7.10.jar
<Web Application Server Home Directory>/../oracle_common/modules/saaj-impl-1.5.3.jar
<Web Application Server Home Directory>/../oracle_common/modules/stax-ex-1.8.3.jar
<Web Application Server Home Directory>/../oracle_common/modules/streambuffer-1.5.10.jar
<Web Application Server Home Directory>/../oracle_common/modules/endorsed/jakarta.xml.ws-api-2.3.3.jar
Please note:
• Refer to this list rather than the additional information shown in the Installation Menu.
• This list may change due to post-release library updates through patches. For the latest updates, consult the relevant patch product fix document on My Oracle Support.
If the Web Application Server Home Directory is populated, the initialSetup process will pull those JARs from that directory. If it is not populated, the initialSetup process will pull those JARs from the Additional JAR Directory.
