Supported Database Platforms
Oracle Utilities Meter Data Management is supported on the following platforms:
Platform
Database Version
Oracle Enterprise Linux 8.x/9.x x86_64 (64-bit) (Based on Red Hat Enterprise Linux (64-bit))*
Oracle Database Server 19c (64-bit) on-premises and cloud (ADB)
Windows Server 2012 R2 (x86_64 64-bit)
Oracle Utilities Meter Data Management is tested and supported on the versions of Oracle Linux specified. Because Oracle Linux is 100% userspace-compatible with Red Hat Enterprise Linux, Oracle Utilities Meter Data Management also is supported on Red Hat Enterprise Linux for this release.
Windows Server is not supported for Production environments. Wherever Windows Server is referenced within this guide, it is supported for Test or Development environments only.
The following Oracle Database Server Edition is supported:
• Oracle Database Enterprise Edition 19c
• Oracle Database Standard Edition
Note: Oracle Database Enterprise Edition and the Partitioning and Advanced Compression options are not mandatory but recommended. Standard Edition should only be considered suitable for very small, pilot projects or development environments where scalability, performance, and database size-on-disk are not important considerations. Oracle Database Enterprise Edition, including the Advanced Compression and Partitioning options, is strongly recommended in all other situations.
Visit My Oracle Support for additional details.
