Oracle Utilities Meter Data Management Installation Guide
Preface
Audience
Related Documents
Updates to Documentation
Conventions
Acronyms
Additional Resources
Overview
Installation Overview
Application Architecture
Tier 1: Desktop/Client or Presentation Tier
Tier 2: Web Application Server, Business Application Server, Batch Server Tier
Tier 3: Database or Persistence Tier
Installation Components
Installation Types
Initial Installation
Demo Installation
Upgrade Installation
Recommendations for Creating a Production Environment
Media Pack Components
Documentation Packages
Installation Packages
Supported Platforms and Hardware Requirements
Software and Hardware Considerations
Operating Systems and Application Servers
Hardware and Web Browser Requirements
Application Server Memory Requirements
Support for Software Patches and Upgrades
Planning the Installation
Before You Install
Embedded vs Native/Clustered Installation
WebLogic Native Installation
Application Server Clustering
Directory Names
Prerequisite Software List
Prerequisite Software for Database Server
Prerequisite Software for Application Server
Installing Pre-requisite Software
Oracle Linux 8.x/9.x or Red Hat Linux 8.x/9.x Operating System
Windows Server 2012 R2 Application Server
Additional Prerequisite Software Information
Setting Up and Using the Additional JAR Directory
Readiness Checklist
Installing Oracle Utilities Meter Data Management - Initial Installation
Before You Install
Initial Installation Procedure
Installing the Database Component
Installing Application Components
After the Installation
Operating the Application
Installing Oracle Utilities Meter Data Management - Demo Installation
Before You Install
Demo Installation Procedure
Upgrading Oracle Utilities Meter Data Management
Before You Upgrade
Upgrade Procedure
Database Component Upgrade
Application Components Upgrade
Additional Tasks
Importing Self-Signed Certificates
Customizing Configuration Files
Centralized Properties Customization
Integrating Existing Customer Modifications
Building Javadocs Indexes
Configuring the Environment for Batch Processing
Customizing the Logo
Domain Templates
Database Patching
Analytics Publisher Report Configuration
Installation Menu Functionality Overview
Installation Menu Functionality Details
Installation and Configuration Worksheets
Application Framework Installation and Configuration Worksheets
Menu Block 1: Environment ID, Roles, Third Party Software Configuration
Menu Block 2: Keystore Options
Menu Block 50: Environment Installation Options
Menu Block 1: Environment Description
Menu Block 2: [WebLogic] Business Application Server Configuration
Menu Block 3: [WebLogic] Web Application Server Configuration
Menu Block 4 - Database Configuration
Menu Block 5 - General Configuration Options
Menu Block 6 - OUAF TrustStore Options
Menu Block 8 - OSB Configuration
Menu Block 9 - SOA Configuration
Menu Block 10 - SOA Configuration Plan (MDM)
Menu Block 11 - Configuration for DataRaker Integration
Menu Block 16 - SOA Configuration Plan (LG)
Menu Block 17 - SOA Configuration Plan (NES)
Menu Block 18 - SOA Configuration Plan (Sensus)
Menu Block 19 - SOA Configuration Plan (SSN)
Menu Block 20 - SSN JMS Source Destination Bridge Configuration
Menu Block 21 - DG Reference Implementation SOA Configuration
Menu Block 22 - SOA Configuration Plan (Itron Openway)
Advanced Menu Options
Oracle Utilities Meter Data Management Installation and Configuration Worksheets
WebLogic OSB Configuration
WebLogic SOA Configuration
WebLogic SOA Configuration Plan
Common Maintenance Activities
Application Framework Prerequisite Patches
Oracle Utilities Meter Data Management Release 25.4 Installation Guide
